puuuuuuurrrrrrrrrrrr
Published: Thursday, May 11, 2023 - 12:00 (Dürr: Stuttgart, Germany) -- Togg, Turkey’s global technology brand and first smart and connected EV manufacturer, has an ambitious target for its Technology Campus for electric vehicles: to be one of the most environmentally friendly plants in Europe. Dürr planned and built the paint shop as a general contractor and supplied systems for the final assembly process. NEXT.assembly, Dürr’s bundled technology spectrum for final assembly, was used for the first time, enabling Togg to achieve unparalleled efficiency in vehicle assembly. Annually, 175,000 smart and connected EVs will roll off the production line at Togg’s Gemlik Technology Campus in western Turkey by 2030. The turnkey paint shop project was awarded to Dürr in 2020, and a second order for the final assembly system followed in 2021. Together, they covered all plant engineering and application technology, including fully automatic screwdriving stations and inspection equipment. “The pretreatment and cathodic electrocoating systems are already rated for the final expansion stage, while the plans include provision for doubling up all other power units in the layout,” says Bruno Welsch, CEO and president of Paint and Final Assembly at Dürr Systems AG. “Therefore, Togg can react quickly if the capacity requirements increase, for example, by adding a second oven or an entire line.” Production started in the paint shop only recently, with the final assembly system set to be commissioned shortly. Togg initially opted for a lean painting process to minimize energy demand. The base coat and clear coat of the internal and external paint finish are applied in a single topcoat line with integrated primer application, eliminating one drying phase. The solvent-based paints contain 30- to 35-percent more solid content than standard paints to achieve the required layer thicknesses with lower discharge rates. The EcoDryScrubber dry separation system concentrates the solvents released into the exhaust air automatically and separates the overspray, saving resources in many ways. The system requires virtually no water and very little energy for air conditioning, which is usually one of the highest energy consumption processes in painting. Spray booth air recirculation of up to 95 percent means that heat and electricity consumption are reduced by up to 80 percent and 50 percent, respectively. This reduction also pays off economically, with energy consumption reduced by as much as 60 percent. Togg goes well beyond the legal requirements with one additional measure to protect the environment: The Oxi.X, a regenerative thermal oxidizer (RTO) that can be operated auto thermally—i.e., without a primary energy supply for the burner—disposes of the booth exhaust air. Togg insists on high standards not only for environmental friendliness but also for coating quality. Next-generation Dürr robots apply the paint and include the seven-axis EcoRP E043i, which is mobile enough to paint doors from the inside and open tailgates. A unique technical feature is the EcoBell 3 atomizers equipped with two main needles that apply colored clear coats for particularly shiny surfaces. The second main needle eliminates the time-consuming rinse cycles previously required, reducing detergent consumption and ensuring the fastest color changes within the required cycle time. Togg benefits from NEXT.assembly in the final assembly area. Whereas individual components were previously the focus, the final assembly system is now considered a whole unit to make vehicle assembly as efficient as possible. NEXT.assembly bundles all of Dürr’s technology and consulting portfolio for maximum efficiency in the vehicle assembly process. The result is the most comprehensive final assembly portfolio on the market to date. It’s available as a complete solution or in individual modular parts. “Togg is the first car manufacturer to choose a complete solution from our final assembly offering,” says Andreas Hohmann, vice president of consulting and NEXT.assembly. “We developed a highly customized, resource-conscious solution that results in high synergy and efficiency at all levels along the whole line with precisely coordinated processes.” Dürr’s overhead conveyors ensure efficient processes. A total of 57 lightweight overhead conveyors transport the vehicle doors to a separate door preassembly line. Another 50 heavy overhead conveyors are provided for transporting the bodies. With the potential for future digitalization, subsequent process integration or maintenance analysis tools are possible. One way to save material in preassembly is through precise dosing with the EcoShot Meter, which is suitable for almost all thick matter for sealing and gluing. The dosing unit, with 1K and 2K applications, can also apply polyurethane adhesives for window gluing. At Togg, these are used in the fully automatic gluing of windows and panoramic glass roofs. The automated process happens while the body is being conveyed (line tracking), making it much more efficient than the previous stop-and-go process in which the vehicle conveyor had to be stopped for installation. Togg is ideally equipped for the specific marriage process for electric vehicles with a line divided into seven individual stations, including the automatic x-bolt screwdriving station with six individual spindles. They fasten the front-axle module, the battery, and the rear-axle module automatically with a total of 30 screwing points. A downstream manual screwdriving station fastens another 14 screwing points, which can be easily automated in the future. The ProLine Cube guarantees faster and more high-quality filling for all media. As the technological core of the filling system, the fourth Somac adapter generation—the ergonomic G4 Blue Adapter—determines the fill quality and process time. The battery-powered vehicles are inspected and aligned in two complete end-of-line systems by the wheel alignment stands x-wheel, among others. They are equipped with the new x-3D surface sensors. These provide 3D measurements of axle geometries and align them with precision and reliability. The wheel alignment stands are combined with the headlight measurement and adjustment systems x-light as well as the complicated ADAS calibration systems x-DASalign, which are used for calibrating the SVC (surround view camera), FLC (forward-looking camera), and FLR (forward-looking radar). The roll/brake/ABS test stands x-road for dynamic roll, brake, and ABS testing complete the end-of-line system. “As the principal supplier, we work closely with Togg to meet high environmental and quality requirements,” says Welsch. The service offering is rounded out by the Turkey-based Dürr team, which will take over the ongoing servicing of the system in the future. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.Environmentally Friendly and Complete Solution for EV Manufacturer
Turkey’s EV plant has optimized a lean painting process
Cutting water, electricity, and heat consumption
Latest technology for high-color brilliance
A new way of looking at final assembly
Modern conveyor technology for doors and bodies
Window gluing as part of line tracking
Flexible marriage process, thanks to automation
Next generation of filling
Exact 3D axle-geometry measurements
Quality Digest Discuss
