puuuuuuurrrrrrrrrrrr
Steve Moore
Published: Monday, April 24, 2017 - 11:03 When I entered college in the fall of 1970, I had a nice slide rule (or “slipstick” as some of us called it) that I proudly carried in a leather case to my engineering and chemistry classes. Virtually everyone at North Carolina State University had a slide rule then, but by the time I was a senior, if you didn’t have an electronic calculator, you would have a hard time competing. Unfortunately, the demise of the slide rule brought with it the demise of “significant digits.” The topic of significant digits was actually taught in many classes because the scales on a slide rule did not allow one to make calculations that would result in three or more digits after a decimal point. As a result, answers to homework or test problems were rendered in “scientific notation” such as 7.13 x 10^3. The electronic calculator would give the answer as 7,132.435674... wow! The calculator is “more accurate” than the slide rule! Or is it? I actually had professors who would deduct points if you gave answers that looked like the latter example and exceeded the proper number of significant digits. As a somewhat absurd but illustrative example, suppose a geology professor takes an old fossil to class and announces, “This fossil is two million years old.” The following year, is the professor going to bring the same fossil to class and announce, “This fossil is two million and one years old”? Well, it depends on what the professor meant. Does “two million years old” mean 2,000,000 years or 2,000,000.00 years? In the former case, the fossil is 2,000,000 years old with just one significant digit (the 2). All other digits are essentially random numbers. Depending on rounding conventions, the fossil could be anywhere between one and a half million and two and a half million years old. In the latter case, we have nine significant digits, and the fossil was having its “two millionth birthday” while being presented to the class for the first time. The following year the professor would be justified in adding one year to the fossil’s age. As a more practical example, suppose a test lab measures some physical property of a sample submitted to it by a manufacturer, and the test is repeated five times. The test results are: 25.3, 24.9, 25.1, 24.9, and 25.0. The lab reports the average as 25.040 because sometime in the past, someone wanted to know the value to three decimal places to be “more accurate” or “more precise.” The best value for the answer is 25.0; 25.040 is neither more accurate nor more precise. The 4 and the last zero are random numbers. The following are the most commonly used rules for determining the number of significant digits: When adding or subtracting quantities, the answer should contain no more decimal places (not significant digits) than the least number of decimal places found in any of the numbers being added or subtracted. When multiplying or dividing by a whole number, the whole number is considered to have an indeterminate (or infinite) number of significant digits. For example, if two identical paper clips weigh 1.02 g, then their total weight is computed as 1.02 g x 2 = 2.04 g. The advent of calculators and high-speed computers have caused many of us to ignore the simple fact that a calculated quantity cannot be more “accurate” or “precise” than the least accurate or precise quantity used in the calculation. Is it just human nature to deliver an answer like 2.34543 to appear intelligent, when the best answer is just 2.3? Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, After 47 years, Steve Moore is retired from the pulp and paper industry. He is a graduate of North Carolina State University with a pulp and paper degree, and holds a master's degree from the Institute of Paper Chemistry in Appleton, Wisconsin. He has held various research and development, technical, engineering, and manufacturing positions in the paper industry. He has been a student, teacher, and practitioner of statistical methods applied to real-world processes for the past 35 years. The Lost Art of Significant Digits
More digits don’t always mean more accuracy
• All nonzero digits are significant (e.g., 87 and 56.98 have two and four significant digits, respectively).
• All zeroes between nonzero digits are significant (e.g., 12.012 has five significant digits).
• Leading zeroes are not significant (e.g., 0.0123 has three significant digits).
• Trailing zeroes after a decimal point are significant (i.e., 108.0200 has seven significant digits).
• Trailing zeroes in a number without a decimal point can be ambiguous in terms of the number of significant digits. As a general rule, do not count the trailing zeroes as significant (e.g., 2,000,000 has one significant digit).
• Scientific notation can be used to eliminate some ambiguity by denoting 1300 as either 1.3 x 10^3 (two significant digits) or 1.300 x 10^3 (four significant digits), depending on the context of the number 1300.
• When computing (multiplying, dividing, trig. functions, etc.), the number of significant digits in the computed value may only be equal to the least number of significant digits in any number used as input to the computation (e.g., 4.4 x 6.64 = 29.2, not 29.216).
Quality Digest Discuss
Steve Moore
don' forget von Neumann
Good article. Another aspect of performing arithmetic with numbers having significant digits is that von Neumann demonstrated that the errors tend to cancel out. That is, it is OK to perform very lengthy (computer) calculations. The number of significant digits is not lost - you also don't gain.
A definitely important subject
I also used a slide rule in high school, and this made us set up the problems to include units of measurement as well as powers of 10. We had to add the powers of 10 manually, and were also told that the units had to cancel out to give the correct units for the answer. If they didn't, something was missing. This is a good way to error-proof many science and engineering problems.
Reporting a dozen figures is not a good idea but, on the other hand, there is a huge difference between 99% and 99.3% (30%, or 0.3 out of the 1% tail area) if one is in fact entitled to the figure in the 0.1 place. It is always important to pay attention to exactly what one is rounding off.
