Featured Product
Standards Features
Megan Wallin-Kerth
MasterControl’s Matt Lowe talks competition, data, and what quality does for a company
ISO
Using the CASCO Toolbox to repair and restore
Todd Hawkins
Good documentation is worth the effort you put into it
Rupa Mahanti
With data as the fuel of the digital economy, data governance is the much needed brake
Bryan Christiansen
Workplace policies that reduce accidents and enhance safety
More Features
Standards News
Creates one of the most comprehensive regulatory SaaS platforms for the industry
Yotrio and SunVilla to provide interactive, 3D-enabled assembly via BILT app
KCP25C grade with KENGold coating sets new standard for wear and productivity in steel turning
Takes action to mitigate risk of medical devices shortage
Standards, testing help autonomous vehicles drive safely
Offering production versatility and throughput with increased detection sensitivity and low energy consumption
New lines improve software capability and analysis
Automotive cybersecurity on Feb. 9, and AS9145 on Feb. 28
More News
Denise Robitaille
Standards
Counting What Matters
Think before you count.
Published: Tuesday, July 10, 2007 - 22:00
What data are the best to gather? What processes should you be tracking? What are your metrics telling you?
In observing various organizations’ attempts to fulfill ISO 9001 requirements around subclause 8.4—“Analysis of data,”–I’ve noticed a recurring problem. Companies allow the requirements of the standard—ISO 9001 or any comparable quality management system (QMS) model—to drive the activity. They put together what appears to be a reasonable list of what to monitor and then proceed to amass enormous amounts of data.
There are some perennial heavy hitters, such as on-time delivery, customer returns, and scrap. There’s no denying that in the typical organization these are always fairly good indicators. Are they the best indicators for your organization?
Gathering data you don’t care about expends precious resources, clogs the information network, and diffuses focus from important issues. In short, it’s a waste of time. Looking at the wrong data also risks ignoring real issues that are at the root of serious problems, while you fiddle and diddle with pretty charts you think will make an auditor happy. Over the long haul, it can erode commitment to consistent use of monitoring and analytical methodologies that really can benefit your organization.
Analysis of data should be driven by one question: “What is it that you need to know?”
The answer to that question is as diverse as the myriad organizations that populate the globe. What you need to know depends on who you are. That is, it depends on the nature of your organization, including such factors as products, market, size, and complexity of processes.
For example, a company for which I did some consulting work several years ago calculated their production yield by determining how much power was used per unit. The time it took to manufacture a part was negligible and the base cost of raw materials per unit was a fraction of a penny. The most significant cost associated with producing a part was the cost of energy—electricity and fuel. The prorated utilities costs expended whenever the production machinery was engaged was an accurate indicator of resource expenditure. When divided by total salable pieces produced per hour, it provided the best metric of production efficiency.
Calculating the lost time per unit or the scrapped raw material may have been a legitimate metric, but it wasn’t reflective of the biggest drain on the organization’s resources. In this scenario, focusing on scrap would have been nonsensical. It would have also perpetuated the notion that QMS requirements are a pencil-pushing exercise. To address inefficiencies, the organization is better served investigating the root cause of machine failures that result in nonsaleable units.
I’ve put together a chart below, with organizations on the left and appropriate metrics on the right. The challenge is to match the column on the right to the best choice for most critical performance indicator in the other column.
Medical lab
Zero defects
Software design firm
Incident-free days
Medical device manufacturer
Successfully resolved customer issues
Nuclear plant
On-time delivery of test results to medical facilities
Call center
Units sold
Mass producer of widgets
Projects completed on target
While an argument can be made that several metrics will matter to any organization, it’s fair to conclude that zero defects is a much larger concern in the medical device industry than it is in the widget business. In the former, the risk of even one bad unit, especially if it’s an implantable device, is a dead customer.
In the latter example, zero defects could put the widget maker out of business. They may have determined an acceptable quality level (AQL) of 1-percent defective parts. The cost to get closer to zero would erode the already tight margins found in many commodity industries.
Similarly, software developers are in a fast-paced industry, where it’s almost impossible to put out a product that is 100-percent bug-free. If they tried, the competition would beat them to the marketplace every time. The best they can do is release a product that has no major glitches and only insignificant hiccups that may not ever be detected by the casual user.
Finally, a metric like “parts per billion” is laughable if you produce only two units—such as aircraft carriers—per year.
It’s also important to consider that what organizations need to know may change over time. If there’s a focused project to decrease turnaround time for quoting new jobs, the need to actively monitor and analyze data may disappear once the process stabilizes.
So, deciding what to measure and how to measure it requires as much diligence as the actual activity, if the information you’re going to derive is to be meaningful and beneficial. Think before you count.
As to the matching exercise, these are my results. Yours may differ—you get to decide.
Medical lab
Zero defects
Nuclear plant
Incident-free days
Call center
Units sold
Denise Robitaille’s picture
Denise Robitaille
Denise Robitaille is the author of thirteen books, including: ISO 9001:2015 Handbook for Small and Medium-Sized Businesses.
She is chair of PC302, the project committee responsible for the revision to ISO 19011, an active member of USTAG to ISO/TC 176 and technical expert on the working group that developed the current version of ISO 9004:2018. She has participated internationally in standards development for over 15 years. She is a globally recognized speaker and trainer. Denise is a Fellow of the American Society for Quality and an Exemplar Global certified lead assessor and an ASQ certified quality auditor.
As principal of Robitaille Associates, she has helped many companies achieve ISO 9001 registration and to improve their quality management systems. She has conducted training courses for thousands of individuals on such topics as auditing, corrective action, document control, root cause analysis, and implementing ISO 9001. Among Denise’s books are: 9 Keys to Successful Audits, The (Almost) Painless ISO 9001:2015 Transition and The Corrective Action Handbook. She is a frequent contributor to several quality periodicals.
