Featured Product
Metrology Features
Jamie Fernandes
From design to inspection to supply chain management, AI is transforming manufacturing
NVision Inc.
Scanning plays a role in extending life span and improving design of A/C systems
Patrice Parent
Integral components of an electric vehicle’s structure are important to overall efficiency, performance
NIST
NIST scientists perfect miniaturized technique
The more you know, the easier it becomes to use your data
More Features
Metrology News
Enables better imaging in small spaces
Helping mines transform measurement of blast movement
Handles materials as thick as 0.5 in., including steel
Presentation and publication opportunities for both portable and stationary measurement leaders
Accelerates service and drives manufacturing profitability
Improved readings despite harsh field conditions
Designed to meet standards, bolster detection, and mitigate work environment hazards
Machine vision market will return to single-digit growth in 2024 following declines in 2023
Enables manufacturers to integrate collaborative robots in operations
More News
NIST
Metrology
‘Sí’ on the New SI: NIST Backs Proposal for Revamping Measurement Units
Watt balance experiment contributes to a definition of the kilogram based on physical constants
Published: Tuesday, November 2, 2010 - 04:30
(NIST: Gaithersburg, MD) -- Taking the first steps of what would be a major historical advance in the science of measurement, the National Institute of Standards and Technology (NIST) is participating in a worldwide effort to recommend major revisions to the International System of Units (SI), the modern metric system that is the basis of global measurements in commerce, science, and other aspects of everyday life.
The new SI, which would be based on seven constants of nature, would enable researchers around the world to express the results of measurements at new levels of consistency and accuracy. The seven SI base units from which all others are derived are the second (time), the meter (length), the kilogram (mass), the ampere (electric current), the kelvin (thermodynamic temperature), the mole (amount of substance) and the candela (luminous intensity).
The most significant change in the possible future revision of the SI would be in the kilogram, the only one of the SI’s seven base units still defined in terms of a material “artifact”: a 130-year-old platinum-iridium cylinder maintained at the International Bureau of Weights and Measures in France. The kilogram artifact poses long-term problems because its mass changes slightly over time. The proposed revision “puts the SI on a firm foundation,” says Ambler Thompson, a NIST scientist involved in the international effort. “We get rid of the last artifact.”
In the current SI, it’s not just the unit of mass that depends on the kilogram. The definitions of the ampere, mole, and candela (luminous intensity) ultimately depend on the platinum-iridium artifact. For example, a mole is currently defined as the number of carbon-12 atoms whose total mass is 12 grams.
The new proposal defines the kilogram in terms of the Planck constant h (whose current accepted value is 6.62606896(33) x 10–34 kg m2/s), an important constant in quantum physics that is expressed in units containing the kilogram. Efforts at NIST, such as the watt balance experiment and determinations of the mass of one mole of silicon atoms, offer new ways of determining an accurate value of h, thereby contributing to a more reliable definition of the kilogram.
The new SI would specify agreed-upon values of the seven constants, according to the results of an analysis published by the Committee on Data for Science and Technology (CODATA) of all of the relevant data. Fixed values of constants would then define all base units. For example, the ampere would be formally defined in terms of the electric charge of a proton, the kelvin in terms of the Boltzmann constant, and the mole in terms of the Avogadro constant. The Boltzmann constant relates the change in the temperature of a system (such as a group of atoms and molecules) to the change in its thermal energy. However, before the revised SI could be implemented, additional experiments are needed to obtain more accurate values for some of the constants, especially the Planck, Avogadro, and Boltzmann constants.
The Consultative Committee for Units, of which NIST is a member and which is one of 10 advisory committees of the International Committee for Weights and Measures (CIPM), submitted a draft resolution for a revised SI for consideration by the CIPM during its meeting in Paris, France, earlier this month. The CIPM, whose membership includes Willie May, director of NIST’s Material Measurement Laboratory, approved the draft with only a few minor editorial changes on Oct. 15. The CIPM will soon submit the resolution for consideration at the General Conference on Weights and Measures (CGPM), the international diplomatic body that has the authority under the Meter Convention to adopt such a sweeping resolution during its October 2011 meeting. If the resolution passes and all the technical requirements are in place, a new SI could be in practice later in the decade.
NIST’s picture
NIST
Founded in 1901, the National Institute of Standards and Technology (NIST) is a nonregulatory federal agency within the U.S. Department of Commerce. Headquartered in Gaithersburg, Maryland, NIST’s mission is to promote U.S. innovation and industrial competitiveness by advancing measurement science, standards, and technology in ways that enhance economic security and improve our quality of life.
