Featured Product
Quality Insider Features
Bryan Christiansen
Theory and steps
Knowledge at Wharton
Technology companies aren’t equipped to dislodge traditional automakers from the driver’s seat and must learn to share the controls
Jim Benson
Don’t just set and forget KPIs or other metrics. Understand the true narrative of the work you do.
John Baldoni
John Baldoni interviews Garry Ridge about clarity and hope amid crisis
George Schuetz
Hand gauges at the point of manufacture are commonplace, but this doesn’t mean just any gauge can be used
More Features
Quality Insider News
Offset-aware programming of spindle transfers and bar pulls helps manufacturers drive multichannel CNC machinery
Delivers curved-surface analysis tools, helps deploy PolyWorks|Inspector as a standard offline CNC/CMM sequencing solution
Includes global overview and new additive manufacturing section
Address equipment issues before a catastrophic failure occurs
ISO 37301 provides everything needed to develop, implement, maintain, and improve an effective compliance management system
All-in-one package reduces complexity and overall cost of use
Extant ornament pieces scanned using the Artec Leo 3D scanner in HD mode
Multiple measurement and statistical displays with numeric and graphic layout, trend limits, data traceability, batch management, part counters, data storage
True 3D holographic displays are practical with only moderate computational requirements
More News
Quality Insider
Digitalization of Mechanical Pumps: Timmer’s IoT Solution Enables Live Monitoring
Location-independent real-time monitoring, predictive maintenance even for purely mechanical pumps
Published: Wednesday, April 14, 2021 - 12:00
(Timmer GmbH: Neuenkirchen, Germany) -- Pioneering work in the field of paint delivery pumps: With timIOT, Timmer GmbH launches a digital solution that for the first time allows a location-independent real-time monitoring and predictive maintenance even for purely mechanical pumps. timIOT consists of a retrofittable sensor for data acquisition and the timIOT smartbox. It connects the pump with the timIOT cloud platform. Operators benefit, among other things, from a significantly higher process reliability, a minimization of downtimes, and considerable cost savings due to better planning. Timmer will launch its timIOT digital solution on May 1, 2021.
Modern industrial systems, for example for the supply of paint, are highly complex, and numerous parameters are already being monitored—often with the exception of the pumps. Yet they are the heart of the system and thus a decisive element in the process chain. Failures can result in considerable economic losses. Until now, operators have had to rely on experience when it comes to maintenance or replacement. Especially for purely mechanical double diaphragm pumps, no operating data could be collected so far. “With our new IoT solution timIOT we are facing this challenge and creating a high data availability”, explains Frederic Engels, market development at Timmer. “The solution enables the readout and statistical evaluation of comprehensive process data and can be integrated into Timmer’s double diaphragm pumps and electric piston pumps, among others.”
The system design of timIOT is quite simple: The pump must first be equipped with an intelligent sensor. This sensor is already integrated as standard in most of the Timmer double diaphragm pumps. Then the sensor is linked to the timIOT smart box, which transmits the data to the cloud by means of a secure transmission, for example via a separate LTE router that is independent of the company network. The visualization and evaluation of the data is done on end devices such as PCs, smartphones,or tablets. Clearly structured histograms, tables, and statistics can be viewed from any location. In the case of error status or exceeding set values a notification in the IoT platform or to a defined e-mail address is made.
Reliable real-time monitoring of pumps
With the help of comprehensive data, plant operators can organize their processes more efficiently and make informed decisions. Parameters such as pump frequency, number of strokes or pressure curves are permanently visible. Predictions on wear and tear as well as the planning of repair measures become much more precise; this ensures optimum use of the pumps over their entire lifetime. “The statistical evaluation of the operating data also makes it easier to calculate operating costs and the optimization of system utilization,” emphasizes Engels. “After all, operators often replace all pumps at the same time, even though some of them have only reached a fraction of their maximum lifetime—this costs money in the long run.” Furthermore, predictive maintenance minimizes downtime and damage, while process stability and machine availability are increased.
The intelligent Timmer software provides users with additionally useful tools. These include intuitive maintenance planning, a maintenance calendar, as well as a user-friendly administration of service reports and pump-specific documentations. Timmer is offering the IoT solution based on a moderate annual license model. Regular updates and future functional expansions are planned.
For further information visit www.timmer.de/en.
The digital solution timIOT allows a location-independent real-time monitoring and predictive maintenance even for purely mechanical pumps.
About Timmer GmbH
Timmer GmbH, located in Neuenkirchen, Germany, is a manufacturer of products and special solutions in the fields of pneumatics, pumps, vacuum technology, and vacuum lifting technology. Timmer is also an expert in the field of industrial paint supply of painting lines and printing machines by means of piston pumps and double diaphragm pumps. In the vacuum lifting technology segment, the company produces vacuum lifters and tube lifters for transporting heavy, bulky loads. Furthermore Timmer offers a wide range of accessories and spare parts for all areas. Founded in 1978, the company employs more than 130 people at its two plants in Neuenkirchen.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
