Featured Product
Quality Insider Features
Naphtali Hoff
Sharing information effectively
Ian Hesketh
Are we endorsing a tech-enabled, 24–7 work culture?
William A. Levinson
It is possible to raise wages, lower prices, and make more money
Casandra Robinson
Improving soldiers’ footwear could lead to better shoes for us all
Jennifer Chu
Next-generation devices made with new “peel and stack” method may include electronic chips worn on the skin
More Features
Quality Insider News
Start with higher-value niche markets; don’t cross the valley of death
Features include One-Click GD&T extraction and automatic ballooning using advanced AI-driven OCR
Michigan Metrology’s upcoming short course will be held April 1–2, 2020, in Livonia, MI
Florence Community Plaza features life-size statues of a firefighter, a public service worker, and a police officer
Program to provide tools to improve school performance and enrollment
Full range of Starrett force software solutions are now interchangeable with different Starrett frame series
To be held Feb. 11–13, 2020, at Anaheim Convention Center, in the Automation Technology Expo
Liquid-entrenched smooth surface (LESS) coating repels bacteria that stink and infect
More News
David L. Chandler
Quality Insider
When Is It Worth Remanufacturing?
MIT study shows sometimes it saves energy, sometimes it doesn’t—and sometimes it makes things worse
Published: Wednesday, May 18, 2011 - 05:00
It seems like a no-brainer: Remanufacturing products rather than making new ones from scratch—widely done with everything from retread tires to refilled inkjet cartridges to remanufactured engines—should save a lot of energy, right?
Not so fast, says a new study by researchers at the Massachusetts Institute of Technology (MIT).
In some cases, the conventional wisdom is indeed correct. But out of 25 case studies on products in eight categories done by a team led by MIT professor of mechanical engineering Timothy Gutowski, there were just as many cases where remanufacturing actually cost more energy as cases where it saved energy. And for the majority of the items, the savings were negligible, or the energy balance was too close to call.
Why are the new results so different from what might have been assumed? The MIT team looked at the total energy used over the lifetime of a product—a life-cycle analysis—rather than just the energy used in the manufacturing process itself. In virtually all cases, it costs less money and less energy to make a product from the recycled “core”—the reusable part of the product—than to start from scratch. But the catch is that many of these remanufactured products are less energy efficient, or newer versions are more energy efficient, so the extra energy used over their lifetimes cancels out the savings from the manufacturing stage.
A simple and familiar example is retread tires. They do indeed require less energy to make than new tires, but their rolling resistance might turn out to be just a bit higher, which would mean their energy advantage is eaten up by the extra gas used while driving on them.
The study, published in the journal Environmental Science & Technology, is the latest from Gutowski and his students that, as he puts it, “takes what appears to be a simple, straightforward problem and shows that the world is a far more complicated place than people thought.” The paper was co-authored by MIT materials science and engineering graduate student Sahil Sahni; Avid Boustani, a recent graduate from the Department of Mechanical Engineering; and Stephen Graves, the Abraham J. Siegel Professor of Management in the MIT Sloan School of Management. The work was supported by the MIT Energy Initiative and the Singapore-MIT Alliance.
What often turns out to be the case, Gutowski says, is that “new technology shows up that is so much more efficient, from an energy point of view, that you should get rid of the old device” rather than having it fixed or buying a remanufactured version. For example, the efficiency of many new appliances—such as refrigerators and washing machines—are so much improved over older models that, in terms of energy use, a new model is almost always the better choice.
Unfortunately, that is typically not the way people and businesses make their choices. “The decision is always on cost, not energy,” Gutowski says. For example, a remanufactured electric motor, in which the metal core is reused but wound with new wires, is typically 0.5- to 1-percent less efficient than a newer motor. “There is still a cost advantage [to the remanufactured motors], but from an energy point of view, it’s the opposite,” he says.
Other effects stem from remanufactured products going to different markets than their original destinations. For example, old cell phones can be remanufactured, but the remanufactured phones tend to be sold in developing countries. “If it goes to a different market, it leads to an expansion of the market,” Gutowski explains, so the overall level of cell phone usage globally—and the energy needed to power them—ends up increasing.
For some kinds of products, the benefits of remanufacturing are unequivocal. It clearly makes sense to remanufacture anything that consumes an insignificant amount of energy when it is being used, he says—for example, furniture.
Julian Allwood, a senior lecturer and leader of the Low Carbon Materials Processing Group at the University of Cambridge in the United Kingdom, says this is a very original analysis and the findings are of high quality because they are “carefully informed with real numbers.” He adds that while the results seem to be valid for the product categories the team studied, “My only concern is that their product catalogue was mainly consumer products—i.e., not buildings, infrastructure, industrial equipment—which are probably all more significant categories as drivers of global environmental impacts.”
Gutowski emphasizes that this research does not necessarily suggest a specific course of action. For any given product, there may be other reasons for preferring the remanufactured version even if it produces a net energy penalty. For example, remanufacturing may reduce the burden on landfills, reduce use and disposal of some toxic materials, or produce needed jobs in a particular area. And the expanded use of cell phones may have important social benefits, such as contributing to the recent wave of revolutions in North Africa and the Middle East. “We’re not saying you shouldn’t do it,” he says—just suggesting that it’s worth understanding the decision’s effects in their entirety.
“You think you’re doing the right thing, it sounds so simple,” Gutowski says. But when it comes to understanding the true impact of purchasing decisions on energy use, “things are far more complicated than we expect.”
Reprinted with permission of MIT News.
David L. Chandler’s picture
David L. Chandler
David L. Chandler is an award-winning freelance writer and a photographer. Chandler began writing about science in 1975 and since then has authored two books and written thousands of published articles circulated in newspapers and magazines including the Chicago Tribune, Baltimore Sun, San Francisco Examiner, and the Boston Globe magazine, NewScientist, Smithsonian, Innovation, Wired, and many more. Forbes listed Chandler as one of the 500 most influential journalists and he has been included on three Who’s Who lists. Chandler has made numerous television, radio, and public-speaking appearances; participated on several universities’ panel discussions; and serves as a judge for the fellowship’s application process at Massachusetts Institute of Technology (MIT).
