Featured Product
Quality Insider Features
Jennifer Chu
High-speed experiments help identify lightweight, protective ‘metamaterials’
James Chan
Start the transition to preventive maintenance
Mark Rosenthal
The intersection between Toyota kata and VSM
NVision Inc.
Scanning plays a role in extending life span and improving design of A/C systems
Patrice Parent
Integral components of an electric vehicle’s structure are important to overall efficiency, performance
More Features
Quality Insider News
Enables better imaging in small spaces
Helping mines transform measurement of blast movement
ACE 2024, March 4–7, 2024, Fort Worth, Texas
Handles materials as thick as 0.5 in., including steel
Presentation and publication opportunities for both portable and stationary measurement leaders
HaloDrive Omnidirectional Drive System for heavy-duty operations
For companies using TLS 1.3 while performing required audits on incoming internet traffic
Accelerates service and drives manufacturing profitability
Improved readings despite harsh field conditions
More News
Stanford News Service
Quality Insider
What Can Cool Buildings in Full Sunlight Without Electricity?
A reflecting, radiating ultrabroadband photonic structure
Published: Friday, April 19, 2013 - 10:42
Homes and buildings chilled without air conditioners. Car interiors that don’t heat up in the summer sun. Tapping the frigid expanses of outer space to cool the planet. Science fiction, you say? Well, maybe not any more.
A team of researchers at Stanford has designed an entirely new form of cooling structure that cools even when the sun is shining. Such a structure could vastly improve the daylight cooling of buildings, cars, and other structures by reflecting sunlight back into the chilly vacuum of space. The team’s paper describing the device, “Ultrabroadband Photonic Structures To Achieve High-Performance Daytime Radiative Cooling,” was published March 5, 2013, in Nano Letters.
Electrical engineering professor Shanhui Fan (center) and graduate students Aaswath Raman (left) and Eden Rephaeli (right) have developed a solar cooling device that may be able to supply air conditioning without using electricity to poor and off-the-grid areas.
“People usually see space as a source of heat from the sun, but away from the sun outer space is really a cold, cold place,” explains Shanhui Fan, a professor of electrical engineering and the paper’s senior author. “We’ve developed a new type of structure that reflects the vast majority of sunlight, while at the same time it sends heat into that coldness, which cools manmade structures even in the daytime.”
The trick, from an engineering standpoint, is twofold. First, the reflector has to reflect as much of the sunlight as possible. Poor reflectors absorb too much sunlight, heating up in the process and defeating the goal of cooling.
The second challenge is that the structure must efficiently radiate heat (from a building, for example) back into space. Thus, the structure must emit thermal radiation very efficiently within a specific wavelength range in which the atmosphere is nearly transparent. Outside this range, the thermal radiation interacts with Earth’s atmosphere. Most people are familiar with this phenomenon. It’s better known as the greenhouse effect—the cause of global climate change.
Two goals in one
The new structure accomplishes both goals. It is an effective broadband mirror for solar light: It reflects most of the sunlight. It also emits thermal radiation very efficiently within the crucial wavelength range needed to escape Earth’s atmosphere.
Radiative cooling at nighttime has been studied extensively as a mitigation strategy for climate change, yet peak demand for cooling occurs in the daytime.
“No one had yet been able to surmount the challenges of daytime radiative cooling: cooling when the sun is shining,” says Eden Rephaeli, a doctoral candidate in Fan’s lab and the co-first-author of the paper. “It’s a big hurdle.”
The Stanford team has succeeded where others have come up short by turning to nanostructured photonic materials. These can be engineered to enhance or suppress light reflection in certain wavelengths.
“We’ve taken a very different approach compared to previous efforts in this field,” says Aaswath Raman, a doctoral candidate in Fan’s lab and the co-first-author of the paper. “We combine the thermal emitter and solar reflector into one device, making it both higher performance and much more robust and practically relevant. In particular, we’re very excited because this design makes viable both industrial-scale and off-grid applications.”
Using engineered nanophotonic materials, the team was able to strongly suppress how much heat-inducing sunlight the panel absorbs while it radiates heat very efficiently in the key frequency range necessary to escape Earth’s atmosphere. The material is made of quartz and silicon carbide, both very weak absorbers of sunlight.
Net cooling power
The new device is capable of achieving a net cooling power in excess of 100 watts per square meter. By comparison, today’s standard 10-percent-efficient solar panels generate about the same amount of power. That means Fan’s radiative cooling panels could theoretically be substituted on rooftops where existing solar panels feed electricity to air conditioning systems needed to cool the building.
To put it a different way, a typical one-story, single-family house with just 10 percent of its roof covered by radiative cooling panels could offset 35 percent its entire air conditioning needs during the hottest hours of the summer.
Radiative cooling has another profound advantage over other cooling equipment, such as air conditioners. It is a passive technology. It requires no energy. It has no moving parts. It is easy to maintain. You put it on the roof or the sides of buildings and it starts working immediately.
A changing vision of cooling
Beyond the commercial implications, Fan and his collaborators foresee a broad potential social impact. Much of the human population on Earth lives in sun-drenched regions huddled around the equator. Electrical demand to drive air conditioners is skyrocketing in these places, presenting an economic and environmental challenge. These areas tend to be poor, and the power necessary to drive cooling usually means fossil-fuel power plants that compound the greenhouse gas problem.
“In addition to these regions, we can foresee applications for radiative cooling in off-the-grid areas of the developing world where air conditioning is not even possible at this time. There are large numbers of people who could benefit from such systems,” Fan says.
Article by Andrew Myers, associate director of communications for the Stanford School of Engineering. This article was first published by Stanford News on April 15, 2013.
Stanford News Service’s picture
The Stanford News Service is part of Stanford University’s Office of University Communications. It provides assistance to reporters and disseminates much of the university’s news. It also serves as a liaison between scholars and media outlets. Stanford University is recognized as one of the world's leading research and teaching institutions.
