Featured Product
Quality Insider Features
Master Gage and Tool Co.
Why it matters for accurate measurements
Ian Wright
MIT and ETH Zurich engineers use computer vision to help adjust material deposition rates in real time
Scott A. Hindle
Part 4 of our series on SPC in the digital era
Etienne Nichols
It’s not the job that’s the problem. It’s the tools you have to do it with.
Lee Simmons
Lessons from a deep dive into 30 years of NFL and NBA management turnover
More Features
Quality Insider News
Exploring how a high-altitude electromagnetic pulse works
High-capacity solution using TSMC’s 3DFabric technologies
EcoBell paints plastic parts with minimal material consumption
August 2023 US consumption totaled $219.2 million
New KMR-Mx Series video inspection system to be introduced at the show
Modern manufacturing execution software is integral for companies looking to achieve digital maturity
Study of intelligent noise reduction in pediatric study
Results are high print quality, increased throughput
More News
NIST
Quality Insider
Nanopower: Avoiding Electrolyte Failure in Nanoscale Lithium Batteries
Size of electrolytes affects battery performance, say NIST researchers
Published: Wednesday, March 21, 2012 - 10:11
It turns out you can be too thin—especially if you’re a nanoscale battery. Researchers from the National Institute of Standards and Technology (NIST); the University of Maryland, College Park; and Sandia National Laboratories built a series of nanowire batteries to demonstrate that the thickness of the electrolyte layer can dramatically affect the performance of the battery, effectively setting a lower limit to the size of the tiny power sources. The research was reported in a recent article in Nano Letters ("Electrolyte stability determines scaling limits for solid-state 3D Li-ion batteries," Nano Letters 12, 505-511, 2011).
The results are important because battery size and performance are key to developing autonomous microelectromechanical machines (MEMS), which have potentially revolutionary applications in a wide range of fields.
MEMS devices, which can be as small as tens of micrometers (that is, roughly one-tenth the width of a human hair), have been proposed for many applications in medicine and industrial monitoring. MEMS devices generally need a small, long-lived, fast-charging battery for a power source. Present battery technology makes it impossible to build these machines much smaller than a millimeter—most of which is the battery itself—which makes the devices terribly inefficient.
NIST researcher Alec Talin and his colleagues created a veritable forest of tiny—about 7 micrometers tall and 800 nanometers wide—solid-state lithium ion batteries to see just how small they could be made with existing materials and to test their performance.
Starting with silicon nanowires, the researchers deposited layers of metal (for a contact), cathode material, electrolyte, and anode materials with various thicknesses to form the miniature batteries. They used a transmission electron microscope (TEM) to observe the flow of current throughout the batteries and watch the materials inside them change as they charged and discharged.
The team found that when the thickness of the electrolyte film falls below a threshold of about 200 nanometers, the electrons can jump the electrolyte border instead of flowing through the wire to the device and on to the cathode. Electrons taking the short way through the electrolyte—a short circuit—causes the electrolyte to break down and the battery to quickly discharge.
“What isn’t clear is exactly why the electrolyte breaks down,” says Talin. “But what is clear is that we need to develop a new electrolyte if we are going to construct smaller batteries. The predominant material, LiPON, just won’t work at the thicknesses necessary to make practical, high-energy-density rechargeable batteries for autonomous MEMS.”
Using a transmission electron microscope (TEM), NIST researchers were able to watch individual nanosized batteries with electrolytes of different thicknesses charge and discharge. The NIST team discovered that there is likely a lower limit to how thin an electrolyte layer can be made before it causes the battery to malfunction. Credit: Talin/NIST
NIST’s picture
NIST
Founded in 1901, the National Institute of Standards and Technology (NIST) is a nonregulatory federal agency within the U.S. Department of Commerce. Headquartered in Gaithersburg, Maryland, NIST’s mission is to promote U.S. innovation and industrial competitiveness by advancing measurement science, standards, and technology in ways that enhance economic security and improve our quality of life.
