puuuuuuurrrrrrrrrrrr
Mike Thelen
Published: Monday, May 12, 2008 - 21:00
What’s an extremely difficult part of lean? Sustained improvement. Kaizen is best known and most often described as continual, incremental improvement. Kaikaku is perhaps best described as revolutionary improvement. Thus we have two ways to pursue sustained improvement, evolution and revolution. How do we achieve them?
Once the engine is rolling down the lean track, how do we keep it moving? By changing the way we think about the products we make. Before we can implement kaizen or kaikaku, we must understand how we make what we make.
Process management—the traditional approach
Often we fail. Why? A manufacturing cell has two orders due. One is a long run with short setup. The other, while “hot”, is short-run with an expensive setup. An order due later requires the same work. Often, the first order is run, not due to priority, but due to a desire to perform well (after all, no one likes the supervisor bearing down on them).
Let’s look at traditional management through a manufacturing process diagram:
Inventory (in the form of lots) is everywhere, with no structure (or only a perceived structure that isn’t followed). There’s no clear path as any product can and will run anywhere dependent on machine availability at the time of need. People are so busy trying to find, prioritize, and push work through that they have no opportunity for process evaluation and improvement. This same diagram can just as easily (and often does) represent a sales/customer service or engineering department. If we overlay the information side of the process, the diagram can become so cluttered that individual opportunities become impossible to see.
Product management—an alternative approach
Here, the value stream is managed entirely. There are no “silos” of departments. Each product has specific personnel throughout the business who are responsible for that product. Structure is very clear and binary, simple, and direct. Support positions often become overstaffed, due to coverage for absenteeism and knowledge sharing. This can also require extensive training, as maintenance and engineering must be “experts” on a broad range of machines/components. Theoretically, everyone is involved heavily in the value stream and teamwork is highly encouraged. Responsibilities are clearly defined for all employees in the process.
Hybrid management—the Toyota approach
Toyota has an engineering department. It has manufacturing, materials, and support departments. However, Toyota also has project managers. These individuals are taken from their previous roles (often they are well-proven engineers) and are given the responsibility of leading projects (to Toyota, Lexus, and the Prius Hybrid were projects.) These leaders are given little or no authority.
This system allows Toyota to share knowledge across vast numbers of employees. It also maximizes support staffing. Utilizing value stream management techniques allows for clear and binary paths, while having departmentalized groups allows for less demand for specific and detailed knowledge of every component. This system allows specialists to be brought in under a project as needed, while still allowing those specialists to perform necessary job functions in other vital areas of the business.
Management structures—a visual summary:
Process management—vertical structure
Product management—horizontal structure
Raw material
All report to process managers and plant process manager
No overlap or concern
No follow-through from design to delivery
Department-specific goals/ratings
Design – Raw Material – Components – Assembly – Ship
Product provides value to the company, not the process
Components
Assembly
Pack/ship
Toyota management—process management with product management
There's no magic pill for lean initiatives. The lean process requires time, commitment, and determination. Companies that cannot envision the long-term commitment to lean, and only use the tools for short-term gain, will achieve some limited success. However, without the culture supporting those tools, the lean initiative will fail, becoming the flavor of the week that everyone knew would not last.
As Jim Womack once said, “Managers will try anything easy that doesn’t work before they will try anything hard that does work."
Previous articles in this series: Part 1: Roll-out (-through, -by, -over) Part 2: No magic pill Part 3: Lean vs. L.A.M.E.
About the author Mike Thelen is the lean facilitator at Aberdeen, South Dakota-based Hub City Inc., a subsidiary of the Regal-Beloit Corp. in Beloit, Wisconsin. He has led lean initiatives in positions from front-line supervisor to system coordinator in various corporations since 2001.
Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks,Changing to Lean, Part 4
Where does process improvement start?
In traditional facilities, we track the progress of a product through each department—sales, customer service, scheduling, manufacturing, assembly, coating, packing, then through shipping to the transportation company. Each department has specific goals. Each has different day-to-day objectives than the others. How do we monitor and judge the success of a product when there are so many and varied avenues for the product to travel?
Pure product management is also difficult. Perhaps it’s best described by using an organizational chart:
Not everyone has worked at Toyota. Through discussions with past employees of Toyota Motor Manufacturing and Toyota supplier support center, and research conducted by many lean practitioners, it would appear that Toyota takes a “hybrid” approach.
Quality Digest Discuss
