Published: Wednesday, April 28, 2021 - 11:00 (Thomson Industries: Wood Dale, IL) -- Thomson Industries Inc., a leading manufacturer of linear motion control solutions, has announced the availability of a 48-volt option for its Electrak HD electric actuator. The added voltage capacity designed into this actuator provides motion control designers with new flexibility in integrating heavy-duty actuators with onboard electronic systems that draw less current. “Greater controllability is one of the main reasons that motion control system designers have been replacing hydraulic systems with heavy duty electric actuators,” says Travis Gilmer, product line specialist of linear actuators at Thomson. “ And the 48-volt capacity of our Electrak HD family adds even more control. Designers can now more efficiently integrate equipment that draws less current.” The Electrak HD linear actuator platform provides robust lifting performance up to 16 kN and has onboard electronics, which eliminates the need for standalone controls. The 48-volt Electrak HD has all of the robustness and performance capability of the standard line but can reduce current draw through the wires by half when compared to 24 Vdc and four times less current when compared to 12 Vdc. This enables designers to configure applications that can provide maximum power while drawing minimal current. It also reduces space demands for everything in the system, including wiring and transistors. In a typical configuration, instead of deploying one 48-volt battery, the designer might string two 24-volt batteries, or a 24-volt and two 12-volt batteries in series. With the new Electrak HD option, they have up to 48-volt capacity if needed and can also integrate accessories that might need only low-level power switching. The 48-volt Electrak HD is designed to perform heavy-duty applications and will benefit automation capabilities in automated guided vehicles, forklifts, agricultural equipment, factory automation, and any application with lifting requirements of up to 16 kN and a need to integrate other electronic equipment that requires low current. The 48-volt Electrak HD is available immediately. For more information, download the new Electrak HD technical brochure at https://www.thomsonlinear.com/downloads/actuators/Electrak_HD_Actuator_bren.pdf. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.Thomson Industries Announces 48-Volt, Heavy-Duty Electrak HD Linear Actuator
All-in-one package reduces complexity and overall cost of use
Quality Digest Discuss
