Our landlords thank you.
Published: Wednesday, December 1, 2021 - 13:00 (Sandvik Coromant: Sandviken, Sweden) -- Leader in metal cutting, Sandvik Coromant, has launched CoroCut QI, a range of internal and face grooving inserts designed for smaller diameters. Optimized to enable a lighter cutting action and reduced cutting forces, CoroCut QI ensures high process security, reliable grooving operations, and precise chip evacuation, resulting in high surface quality grooves. The addition of CoroCut QI completes the CoroCut Q platform, which already consists of CoroCut QD for parting off and CoroCut QF for secure face grooving. CoroCut QI provides a comprehensive selection of optimized tools for numerous parting and grooving applications, designed specifically for smaller diameters. All inserts fit both internal and face grooving tool holders, making it easier for users to select the right tool. CoroCut QI is divided into internal grooving and face grooving application areas and is an upgrade of the T-max Q-Cut 151.3 program. The improved design allows for greater chip control, a 10-percent productivity increase, 20-percent improved tool life aided by tighter edge-rounding tolerances, and internal coolant for both internal and face grooving tools. Key features of the CoroCut QI include: “Grooving can be a difficult technique to master,” says Angélica González, product manager of the CoroCut Q platform at Sandvik Coromant. “Long overhangs, difficult chip evacuation and stuck chips are frequent problems when machining internal and face grooves. CoroCut QI has been developed to tackle these challenges to help achieve optimal results. Besides this, most CoroCut QI tools have internal coolant channels that deliver coolant directly to the cutting zone to enable efficient chip evacuation with minimum damage to the surface. “The smaller the groove, the harder it is to machine. To combat this difficulty, the CoroCut QI inserts are specifically designed for small diameters that require great precision. For example, the minimum hole diameter for internal grooving is between 12 and 60 millimeters (mm) with a cutting depth of 2 and 11 millimeters. Face grooving inserts can be used in a first cut diameter between 16 and 102 mm, with a cutting depth of 5.5 to 20 mm.” The insert geometries vary from -GF, a ground sharp insert for internal grooving, -TF with direct pressed geometry for face grooving and internal grooving and turning, plus -RM, ideal for nonlinear turning such as internal and face profiling. “CoroCut QI is the upgrade from our previous grooving system,” continues González. “In fact, performance tests compared with competing tools have demonstrated better process security and chip evacuation for a higher quality surface finish.” Part of global industrial engineering group Sandvik, Sandvik Coromant is at the forefront of manufacturing tools, machining solutions, and knowledge that drive industry standards and innovations demanded by the metalworking industry now and into the next industrial era. Educational support, extensive R&D investment, and strong customer partnerships ensure the development of machining technologies that change, lead, and drive the future of manufacturing. Sandvik Coromant owns more than 1,700 patents worldwide, employs more than 7,700 staff, and is represented in 150 countries. For more information visit www.sandvik.coromant.com or join the conversation on social media. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.Sandvik Coromant Launches CoroCut QI
New grooving tools optimized to enable lighter cutting action and reduced cutting forces
• Optimized tip seat angle for lighter cutting action and cutting forces that aid vibration free machining
• A rail insert seat for a stable and precise insert position for minimal insert movement
• Screw clamped tool holders to ensure stability and high process security
• Inserts with high edge line quality to increase tool life and surface qualityAbout Sandvik Coromant
Quality Digest Discuss
