puuuuuuurrrrrrrrrrrr
Published: Thursday, April 15, 2021 - 11:00 (Yaskawa Motoman: Waukegan, IL) -- Offering exceptionally fast and powerful operation for increased production throughput, the four-axis PL190 and PL320 models now join the PL500 robotFour-axis PL190 and PL320 models join the recently released PL500 robot, enabling a wide range of palletizing applications, order picking and other logistical tasks Offering exceptionally fast and powerful operation for increased production throughput, the highly reliable four-axis PL190 and PL320 models now join the PL500 robot, enabling a wide range of palletizing applications, order picking, and other logistical tasks. Ideal for end-of-line or distribution automation, PL-series robots are well-suited for a variety of industries, moving boxes and filling pallets with ease and precision. The PL190 has a 190 kg payload capacity, and the PL320 has a 320 kg payload capacity. Each robot features a 3,159 mm horizontal reach, 3,024 mm vertical reach, and ±0.05 repeatability. A one-piece upper arm reduces mass and increases durability, while parallel-link construction for strength and heavy-duty bearings for smooth arm rotation support the handling of large, heavy payloads. A 75 mm T-axis pass-through facilitates easy connections to the end-of-arm tool, and its high moment of inertia ensures unbalanced loads are handled effectively. The PL190 and PL320 robots can be floor mounted and brakes are included on all axes. Installation is quick and efficient. A single cable is all that is needed to connect the manipulator to the controller, resulting in easy set up and reduced expenses for maintenance and spare parts inventory. Airlines and cables are routed internally from the base to the end-of-arm tool to maximize reliability, and a cable installation tube facilitates field-bus routing to the upper arm and gripper. PL-series robots are controlled by the high-performance YRC1000 controller that is built to a global standard and does not require a transformer for input voltages ranging from 380AC to 480VAC. With a highly compact cabinet (598 W x 490 H x 427 D mm), the YRC1000 uses a lightweight teach pendant with intuitive programming. Fast and easy creation of palletizing patterns for virtually any mix of SKUs can be accomplished offline using PalletSolver software, enabling faster workcell deployment for even the most complex patterns. Founded in 1989, the Motoman Robotics Division of Yaskawa America Inc. is a leading robotics company in the Americas. With more than 450,000 Motoman robots installed globally, Yaskawa provides automation products and solutions for virtually every industry and robotic application, including arc welding, assembly, coating, dispensing, material handling, material cutting, material removal, packaging, palletizing, and spot welding. For more information visit www.motoman.com or call (937) 847-6200. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.High-Speed PL190 and PL320 Palletizing Robots Add Versatility to the PL-Series Line
Four-axis models enable a wide range of palletizing applications, order picking, and other logistical tasks
Incorporating palletizing robots
About Yaskawa Motoman
Quality Digest Discuss
