puuuuuuurrrrrrrrrrrr
Bryan Christiansen
Published: Tuesday, November 8, 2022 - 12:03 Assets are resources owned and used by a company to generate a positive economic benefit. Assets can be physical items, like equipment or furniture, or they can be intangibles like software, patents, or documents. As a business owner, it’s important to know which assets you own, their location, and their value. Your shareholders would also like to know that company assets are being efficiently used and maintained. All of that can be covered by a good asset management policy. Let’s see how. An asset management policy is an overarching, high-level document that helps businesses meet their governance, quality, and strategic needs. It dictates how a business maintains the integrity and availability of all assets by outlining the company’s requirements for asset ownership, categorization, acceptable use, and ongoing maintenance. In a large organization, the hierarchy of documents begins with the organization’s strategic plan, which prompts the development of an asset management policy. Beneath the policy sits an asset management strategy. Beneath the strategy, you can find the maintenance policy and asset management plans, with the final documents being operational strategies and plans. However, small to medium-size organizations often combine the asset management policy, strategy, and plan into one document. It’s this level of asset management policy we’ll be discussing here. The document assists all employees by: Emphasizing corporate objectives Asset management policies open with a statement from top management that explains why asset management is important and how it supports the business in achieving its goals. Providing guiding principles for asset tracking and control Guidelines in the policy explain the process of recording assets and clarifying how to acquire, manage, maintain, value, and dispose of them. At any stage in an asset’s life cycle, employees can seek clarity from the policy on the behaviors and methods they should use in particular circumstances—from procurement to asset management to disposal. Helping you manage budgets and asset-related expenditures The entire life cycle costs of an asset require capture, not just the purchase price. The policy will outline how to treat maintenance, modification, operational use, depreciation, financing, and end-of-life asset costs. Adhering to a standard process will help you plan a budget for capital projects and calculate returns on investment (ROI). Assigning roles and responsibilities With clearly defined roles and responsibilities, everyone will know whom to approach for additional information or requests regarding asset inventory, allocation, purchase, disposal, or maintenance. If you wish to be aligned or certified against ISO 55001, the global standard for asset management, the standard itself will be your guide. It will tell you which items are “must-have” and recommend those that are “nice to have.” But maybe you don’t care about the certification. You can still use the aforementioned ISO standard as a guide simply because an asset management policy is good to have. Keep the document brief and direct readers to separate documents such as asset lists or management plans. Remember, too much information in one document makes it unwieldy and unlikely to be read. You can structure this document in many different ways. We recommend you start with an introductory section and then outline the policy itself. The paragraphs in the introductory section serve to clarify commonly used terms and describe the scope and purpose of the policy. A quick overview The overview section briefly explains what asset management is and why it’s important. Keep the section short. Its sole purpose is to introduce readers to the concept of asset management. You’ve probably overdone it if it’s more than two paragraphs. The purpose of the policy In this section, you’re explaining what the policy plans to achieve. Explain that the policy’s purpose is to provide guidelines and procedures for the efficient and effective management of organizational assets. Scope of the policy When you write the scope section, you refer to the people, departments, or businesses for which the policy applies. In most companies, this section comprises one line of text that states that the policy applies to all company employees. This section can sometimes be called Applicability rather than Scope. Definitions Always have a definitions section because not everyone who reads your policy will understand all the terms you use. Make sure someone who knows those definitions by heart double-checks this section for accuracy. Clarify terms like assets, tangible, intangible, disposal, and write-off. In this section, you should explain any term that might be open to ambiguity or misunderstanding. This section is the real meat of the document. All preceding sections have simply prepared the reader for the information you will present here. In the policy section, you will explain the following: Responsibilities Clarify who holds accountability for all the different phases of the asset life cycle. Asset owner, purchase orders, disposal, write-off, maintenance, and modification all require decision making, so be sure to identify who is responsible. Where possible, use a role description instead of a person’s name to avoid having to amend the policy document every time someone is promoted or leaves the company. Asset categorization and identification In this paragraph, clarify what counts as an asset. Most companies only capitalizing items over a certain monetary threshold. If you have asset tags or asset subcategories, this is the place to explain how that categorization works within your asset management system. Some companies also use this section to explain asset lives and depreciation rules, although that information may be better suited as a preamble to your asset register. Asset disposal procedures This section usually comprises the largest of all the paragraphs. Lay out everything one needs to know about asset disposal. Identify the forms to complete and the procedure to follow. Touch upon nuances as well—where to include serial numbers, the effective dates in question, etc. Be sure to address any regulatory issues, whom to involve, and the disposal method. For example, some companies use auctions to dispose of their assets, even nominating the auction house that employees are required to use. Be sure to address how to treat scrap or salvage funds, the process for trade-ins, and how to organize and manage tenders. Asset transfer procedures If your business operates in several geographic locations or has multiple departments, identify the correct process to follow before transferring an asset and whom to inform that the transfer has occurred. There will be clear budgetary and financial implications. Asset repair or replacement guidelines This paragraph advises how to decide on whether to repair or replace physical assets. Some policies use the repair cost—as a percentage of the asset’s capital cost—as a threshold between repairing and replacing. Others use complex calculations and decision trees. Most organizations will want their facility or maintenance manager to make the final call. If it is a really expensive asset and requires risk assessment, the maintenance director and other top management roles are likely to be involved in the decision process. General asset maintenance guidelines The maintenance paragraph outlines the management’s position on asset maintenance, its intent, and the guidelines to follow for asset control. Many organizations will have already written maintenance policy documents for their physical inventory, and they can just point to those for more info. What to do in cases of theft and loss Here is where you clarify the steps to be initiated when someone suspects criminal activity. Define who is responsible for deciding whether to involve the police and contact the insurance company. Asset write-off procedures Most companies have strict processes in place for asset write-off. Record those here. Include forms to be used, the sequence of decisions and approvals, and those responsible for updating the asset register. Checklists can be really helpful here. Document status Formalize your new asset management policy by ensuring that a member of the senior management team signs the policy, and that the document version is controlled, showing the issue date. How a business writes an asset management policy is as important as the items it includes. The drafting process requires the agreement and commitment of senior managers to be effective. Step 1: Identify a senior management sponsor The sponsor role is not a figurehead position. The selected person must be fully aware of the contents of the policy, and the decisions and discussions taken to arrive at the final draft. They must also fully endorse and defend it. Step 2: Institute a working group The asset management policy document represents the principles and guidelines from senior management, whether the policy document regards safety, asset management, or human resources. Therefore, the working group that develops the document must include senior managers who reach a consensus on the document’s contents. Be sure to represent the finance and operations departments, and allow sufficient time for the group to discuss everything and reach an agreement. Step 3: Agree on the document structure and what to include The test of a good policy is whether it gets read and understood. Keep the structure simple, and don’t write a book. Avoid jargon and use plain language. If it has a clear structure, is easy to read, covers all the necessary points, and can be understood, then you’ve succeeded in writing a good policy. Step 4: Draft up a skeleton outline for the policy If you have an existing quality system, align the structure, outline, and design of the asset management policy with those quality system documents. It is a simple way to help employees get familiar with and understand the document. If you have a company style guide, apply it to this template. Nominate a writer to ensure a consistent tone and manage version control. Step 5: Circulate the outline for review By circulating the initial outline of the policy to all departments and senior management, you are providing an opportunity for comments and consultations. You may gain interesting perspectives calling for additions or modifications while gaining a degree of buy-in to the process and the final document. Step 6: Seek expert advice There may be financial or regulatory actions your organization must meet regarding records, disposals, notifications, or tax. Be sure your asset management policy aligns with and includes these provisions. Seek expert advice to be sure your policy complies with all relevant legislature. Step 7: Write the policy and circulate the draft document Once complete, be sure there are no lingering issues or concerns from relevant managers. When ready to issue the document, have it signed by the CEO as the official version. Step 8: Distribute the document Issue the document to each manager and ensure copies are centrally available to allow staff members to seek guidance. Ensure each person signs that they have received and read the policy. Hopefully, you will have a digital version that all stakeholders can access through their laptops at their workstations, or through a mobile device. Last but not least, maintain a register of the location of all approved copies to ensure the removal/replacement of old copies when issuing amendments. The asset management policies you will find online are generally from government agencies, colleges, and local councils, as they are all required to publish such documents. Privately owned businesses have no such requirement, which makes examples hard to find. Yet, the contents will not differ greatly; the organization’s size, sophistication, and geographical spread will have the most impact on the policy contents. Here are some examples from organizations of varying sizes and industries to assist in drafting a document that meets your specific context. Some are simple one-page policies, while others go into more depth. Simple one-pagers These examples are admirably terse, although some border on mission statements: You might find a few more pages will better guide your employees by directing them to applicable references. Multi-page examples The asset management policy examples listed below perfectly illustrate how there isn’t one form, style, or scope you need to follow. However, they also show that there is a logical order in which sections should be covered: These examples indicate the norm in asset management policies. Reviewing them will guide you on the style and content appropriate for your organization. Capital assets form a considerable part of an organization’s value. It’s vital to track them and ensure they are correctly managed, maintained, and disposed of. The asset management policy broadcasts the principles that management believes should be applied for handling its capital assets. Writing an asset management policy may not be the most exciting thing you can do with your day. However, paired with a proactive maintenance strategy, it can help you reduce loss, mitigate regulatory exposure, and ensure you maximize the value of your capital investments. First published Sept. 30, 2022, on the Limble blog. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Bryan Christiansen is the founder and CEO of Limble CMMS. Limble is a modern, easy-to-use mobile CMMS software that takes the stress and chaos out of maintenance by helping managers organize, automate, and streamline their maintenance operations.What Is an Asset Management Policy?
And how to write one from scratch
Why do you need an asset management policy?
What should be included in an asset management policy?
Introductory section
Example of an asset management policy Purpose section. Source: City of Sydney
Example of an asset management policy Scope section. Source: University of Dundee
Example of an asset management policy Definitions section. Source: City of Charles SturtThe asset management policy itself
Example of an asset management policy Responsibilities. Source: Asset Services
Example of an asset management policy Disposals section. Source: New York University
Example of an asset management policy Transfers section. Source: Asset Services
Example of an asset management policy Document Status section. Source: City of SydneyHow to write an asset management policy in eight steps
Examples of asset management policies
• Highways England, 2020
• Graham Asset Management, 2022
• Anglian Water, 2021
• University of Dundee, 2018
• City of Charles Sturt, 2022
• Asset Services, 2015
• American University, 2021
• City of Sydney, 2022
• New York University
• Office of the Chief Technology Officer, DC.Gov, 2021Protect your capital investments
Quality Digest Discuss
Bryan Christiansen
