Featured Product
Operations Features
Davis Balestracci
Even innovation and growth eventually create waste and inefficiencies
Clifton B. Parker
‘We need a deeper debate about which tasks need to stay in the hands of the public, and out of the market.’
Ryan E. Day
Plasan chooses the FARO QuantumS ScanArm to inspect for big launches and big parts
Thomas R. Cutler
Now, small direct-to-customer businesses have access to high-end inventory tools
Pawel Korzynski
Organizations can persuade employees to post more company-related content willingly
More Features
Operations News
Serving as a Baldrige examiner—an unparalleled professional development experience
Floor symbols and decals create a SMART floor environment, adding visual organization to any environment
Help drive team productivity with customizable preprinted templates
A guide for practitioners and managers
Examine nine ways to help understand context, diffuse politics, heal relationships, and find the right work at the right time
Provides eight operating modes and five alarms
Making lean Six Sigma easier and adaptable to current workplaces
Deep Reality Viewer creates stereo, high-definition 3D images without using a monitor
April 25, 2019 workshop focused on hoshin kanri and critical leadership skills related to strategy deployment and A3 thinking
More News
Jody Muelaner
Operations
Understanding Capability of Production Processes and Measurements
A primer for quality professionals
Published: Tuesday, August 6, 2019 - 11:03
In a general sense, capability is the ability to do something. Within manufacturing, capability is given a much more specific definition. It is an expression of the accuracy of a process or equipment, in proportion to the required accuracy.
This can be applied to production processes, in which case any random variation and bias in the process must be significantly smaller than the product tolerance. It can also be applied to measurements, where any uncertainties in the measurement must be significantly smaller than the product tolerance or process variation that is being measured.
Capability may be expressed as a capability index, which is the ratio of the required accuracy to the actual accuracy. When expressed in this way, a bigger value means a more capable process. Capability may also be expressed as a capability ratio, which is the ratio of the actual accuracy to the required accuracy. Expressed in this way, smaller values are better, and the capability might be expressed as a percentage of the tolerance consumed by the accuracy. In both cases, additional factors are often introduced so that the index is some multiple of the raw ratio.
The level of capability that is deemed to be sufficient is different in different industrial standards. In reality, there is a trade-off between the increased cost of improving capability and the costs involved with rework, scrap, and defects reaching the customer. Making an optimal trade-off therefore depends on other parameters and not simply the capability. However, for simplicity, acceptable levels for capability are often used as a major decision-making tool within manufacturing.
When the random variation in the production process is greater than the product’s specification limits, a defective product will be produced; the process is not capable.
Process capability
The capability of a production process to produce parts that are within tolerance is normally expressed as a capability index, involving the ratio between the part tolerance and the process variation. The part tolerance may be represented as the total range between the upper specification limit and the lower specification limit (USLLSL). Tolerance may also be combined with bias in the process so that the lower tolerance is given by the difference between the process mean (µ) and the lower specification limit (µ-LSL). Similarly, the upper tolerance is given by USL-µ.
The two most common process capability indices are Cp, sometimes referred to as the potential capability; and Cpk, which considers bias and so can be considered the actual capability. The process variation is normally represented as the standard deviation (σ). In both cases, the process variation is multiplied by a factor, such that a process capability of one would correspond to plus-or-minus three standard deviations falling within the tolerance.
The equation for Cp is:
It is clear that Cp is simply the ratio of the total tolerance to six standard deviations in the process. A Cp of one therefore means that plus-or-minus three standard deviations of the process would fit within the tolerance limits, assuming the process is centered about the nominal value. A Cp of one is typically regarded as a bare minimum value for capability. A Cp of two means that plus-or-minus six standard deviations of the process would fit within the tolerance limits. This is often the ultimate goal in quality engineering and is where the name for the Six Sigma methodology comes from.
Cp ignores bias. This means that a process could have very little variation but consistently produce parts that are either too big or too small.
The equation for Cpk is:
By considering the available tolerance as the difference between the specification limits and the process mean (µ), Cpk takes into account bias in the process. Therefore, if the Cpk is acceptable, we can be fairly confident that most products will be within tolerance.
Both Cp and Cpk assume that the process output is approximately normally distributed, and that the process is in control. In other words, the process should behave in a consistently random way. If a fault has developed, or there is some other significant nonrandom effect that is causing the process to behave in a way that is not random, then these calculations will not be valid. Note that, strictly speaking, µ should be used for the population mean and x-bar for the sample mean. However, these are often used interchangeably within capability indices.
Multiplying Cp or Cpk by three gives the sigma level (z). This is a way to remove the essentially arbitrary factors added into the equations and get back to something with a more fundamental statistical meaning. Personally, unless I have to, I don’t bother with Cp or Cpk; I’d rather just work with sigma levels. From the sigma level, it is possible to calculate the number of defective parts that can be expected, using the cumulative distribution function (CDF) for the normal distribution. For example, this can be calculated in Excel using the following formula:
=2 – 2*NORM.S.DIST(Z,TRUE)
A sigma level of two (z = 2) would, therefore, result in a defect rate of 4.5 percent for a perfectly centered process. Dividing by three gives Cp = 0.66.
Cpk of 1.4 equates to a sigma level of 4.2 and a defect rate of less than 0.0027 percent. If there is significant bias then only one tail of the distribution will be causing a significant chance of defects, and so the defect rate may be only half this value.
Gauge capability
Another form of capability commonly used in manufacturing is gauge capability. This might be used to decide whether a measurement is capable of determining whether a part is within specification. Alternatively, it might be used to decide whether a measurement has sufficient accuracy to provide meaningful information about process variation. These are distinctly different requirements, and it is important to consider the purpose of a measurement before considering whether it is capable.
When using a measurement for product verification, we are concerned with the ratio between the product tolerance and the measurement uncertainty. When the measurement is used to monitor process variation, it is the ratio of the process variation to the measurement uncertainty that must be considered.
Gauge capability for product verification
Determining capability for product verification is somewhat easier to understand and will therefore be considered first. If the measurement variation is larger than the product tolerance it is clear that the gauge is not capable. If this is the case, then even if every product is produced to exactly the nominal dimensions, the measurement results would show the parts as being randomly in or out of tolerance. At the same time, products that are well outside of tolerance could be shown to be perfect.
At the other extreme, a measurement system with no bias or random variation would provide 100-percent confidence in every measurement result’s ability to distinguish between conforming and nonconforming products.
In reality, measurement systems will usually fall somewhere between these extremes. Gauge capability can provide a way to assess what is good enough. The most fundamental way to express this is as a simple capability ratio between the accuracy of the measurement system and the product’s tolerance. Typically, a ratio of 10 percent to 20 percent is regarded as acceptable. Alternatively, using the ratio between the precision and the tolerance gives the potential capability, assuming corrections are made for bias.
It is also common to use a gauge capability index, which involves the ratio between the tolerance and the accuracy, together with some additional factors. The most common gauge capability indices are Cg and Cgk, as defined in the Automotive Industry Action Group (AIAG) MSA Manual (AIAG, 2010). Cg involves the ratio between the measurement’s precision and the product tolerance, and is therefore the potential capability-ignoring bias. Cgk involves the ratio between the measurement’s accuracy and the product tolerance; this is the actual capability. As with Cp and Cpk, the gauge capability indices introduce some essentially arbitrary factors that can prevent understanding and subsequent statistical analysis. For example, Cg is given by:
The essential ratio in this equation is given by the product tolerance (Tol) and the measurement precision (σ). If no additional factors were present then this ratio would be a sigma level (Z), which would enable further analysis to be carried out easily. However, a number of additional factors are added that have essentially arbitrary values. K is the percentage of the tolerance that is regarded as acceptable, typically 20 percent. This is divided by 100 to convert K from a percentage to a proportion. L is the number of standard deviations thought to represent the actual or target process spread; typically, a value of six is used.
The more recent VDA-5 standard takes a somewhat different approach to measurement capability. It is also concerned with the capability of measurements for product verification. However, it makes a distinction between the measurement instrument and the measurement process. It recommends that a number of evaluations are carried out in sequence to decide whether measurements are capable of proving that the product conforms to the specification. It starts by evaluating the instrument and then moves on to consider the process.
The first step is to check that the instrument’s resolution is less than 5 percent of the parts tolerance. The uncertainty of the measurement instrument’s calibration should then be evaluated using a capability ratio. If the instrument is capable, then an uncertainty evaluation should be carried out for the measurement process and this evaluated using a capability ratio. Finally, regular checks should ensure the measurement process is stable.
The capability ratios (Q) for both the instrument calibration and the measurement process are the ratios between the expanded uncertainty of the instrument or process (U) and the product tolerance (T). The tolerance is expressed as a total range (T = USLLSL), while uncertainty of measurement is a plus-or-minus value. Therefore the uncertainty is multiplied by two to provide a consistent ratio. The expanded uncertainty is given at 95-percent confidence, which means that the standard uncertainty is multiplied by two. This is done before substituting the value into this equation and shouldn’t be confused with the factor of two. The fact that an expanded uncertainty is used is the only arbitrary factor added into this equation. The ratio is multiplied by 100 to give a percentage:
VDA-5 recommends that the capability ratio for the measurement instrument (QMS) should be less than 15 percent, and for the measurement process (QMP) it should be less than 30 percent.
Using these recommended limits, and rearranging the equation, it is also possible to express the capability of a measuring system or process as the minimum tolerance or maximum uncertainty. For example, for a measurement process:
Gauge capability for process monitoring
A measurement used to monitor the variation in a production process should have considerably less variation than the process being monitored. This is essentially about signal to noise. If random variations in the measurement system are similar in size to the random variations in the process, then it is very difficult to observe what the process is doing.
This type of gauge capability is typically monitored using a gauge R&R study. This involves measuring a number of parts, typically 10, representing the normal variation of the production process. Each part is measured a number of times by a number of operators. Analysis of variance (ANOVA) is then used to separate out actual part-to-part variation from measurement variation.
AIAG guidelines state that measurement variation (i.e., total gauge R&R standard deviation) should ideally be less than 10 percent of the study variation. Up to 30 percent may still be acceptable if it cannot be easily improved. A major weakness with this approach is that it depends on a sample of 10 parts to determine the process variation.
Beyond capability: optimized processes
Achieving acceptable levels for capability indices, according to particular standards, does not infer that optimal selections of instruments and machines have been made. In practice, industrial engineers are frequently required to select from several instruments or machines, all of which may either be capable or may not be capable. This involves subjective judgments about what is “good enough,” and what level of expenditure is justified. It is, however, possible to make optimal trade-offs between cost and quality. This can be achieved by using sigma levels and Bayesian statistics to calculate the probability of false decisions. Costs associated with scrap and defects reaching the customer can then be used to calculate a quality-adjusted cost per unit of product sold. Optimal instrument and machine selections, as well as product acceptance decisions, can then be made so as to minimize this cost. I’ll look at this state-of-the-art approach to quality in more detail in a future article.
First published July 10, 2019, on engineering.com.
Jody Muelaner’s picture
Jody Muelaner
Jody Muelaner, is a mechanical engineer with expertise in metrology and advanced manufacturing. Muelaner’s website provides information on topics ranging from the basics of metrology and measurement systems analysis to specific guides such as how to perform a gauge R&R study in Excel.
Process capability
I must take exception on your first two sentences.
Capability means what it means, “the extent of someone's or something's ability.” Please do not try to add QA concepts to the word when we already have a phrase to cover it, “Process Capability.” Even process capability is too restricting for what you are attempting to explain. “Capability Ratio”, and “Capability Index” both are specific to the concepts you use.
In today’s manufacturing world no one can take a risk and attempt to satisfy a customer’s new order is the equipment will not be capable to produce it. Note, I said “will not,” future tense.
Businesses need to know now, what their processes are capable of to a capability index that is at least acceptable to industry standards. It is far too late to be awarded the contract and find the Cpk is only 0.43.
The better way to start is to keep track of all the feature variances of all the processed orders run on the machine. These can be pooled into like groups, very similar to group technology coding, to define the pooled variance of this feature, in this material, using these controls. Using this pooled variance, a standard deviation can be calculated.  This multiplied by 6 + (1.33 x 2) provides a true capability for that process in particular.
How, you ask? By working the Cpk calculation backwards. All processes may drift 1.33 standard deviations from the mean in regular process mode. This represents the Cpk of 1.33 that most businesses’ expect. It also means higher AND lower, so we have to allow for it twice. Hence 1.33 x 2. Most industries expect 6Σ (± 3 µ) performance from their vendors and suppliers, so we have 6 + (1.33 x 2) or 8.66.
This not gives a full capability range to judge new work against before quoting.  If the work is in Aerospace change the multiplier from 8.66 to 14.66 for ±12Σ. If the industry isn’t that critical, maybe go with 6.66. Do what makes sense for YOUR industry and customer expectations.
If your capability is not robust enough to satisfy either your industry or (more importantly) your customers, undertake a CI program to find the critical points that improve the outcome and control them.
World class manufacturers know these things ahead of time and make their managerial and business decisions based on them. That is why they have world class profits too.
