Featured Product
Operations Features
Bryan Christiansen
Actualizing your company culture
Sébastien Breteau
How digital supply chains offer a competitive advantage
Robert Sanders
New initiative plans to scale up bioengineering to create polymers, materials, films, and other products
Amitava Chattopadhyay
How one company redefined ‘win-win’ by creating a sustainable and scalable supply chain
Eric Whitley
Purple deploys lean execution system to improve maintenance and production metrics
More Features
Operations News
Provides improved thermal stability for stored materials, risk mitigation advantages, and processes that are documented and repeatable
This book is a tool for improvement and benchmarking
Automated system processes castable metallographic samples for specialty material manufacturers
Real-time data collection and custom solutions for any size shop, machine type, or brand
How to develop an effective strategic plan and make the best major decisions in the context of uncertainty and ambiguity
What continual improvement, change, and innovation are, and how they apply to performance improvement
Incorporates additional functionality and continuing improvements to the product’s existing rich features
Make it simple and direct
More News
Gwendolyn Galsworth
Operations
Motion and Your Value Field
Any time you leave your value field, you are automatically in motion and not adding value
Published: Wednesday, July 10, 2019 - 11:03
We have been examining motion and moving without working, the footprint of the invisible enemy: missing information. Added up, motion—in all its thousand and perverse forms—can steal 10 percent to 30 percent of our usable workday. Its impact is huge. We know the cure: Replace recurrent questions with visual answers, and motion dissolves because information deficits disappear. Do this by implementing visual workplace technologies, and the gain is companywide.
To conquer motion, we need to understand it even better than we do now and go beyond the power of information deficits to trigger struggle in the guise of seemingly innocent interruptions. In this article, I widen our definition of motion so you gain insight into the more deeply hidden triggers of motion—those tied directly to the physical work environment—and a work location I call the “value field.”
• The wider definition of motion: Motion is anything you have to do or you are unable do your workbut it is not your work.
• An explanation of the term value field: The actual physical location where you do your work.
• And let’s also define “work,” so there’s no guessing. Work means: moving and adding value.
So that means that motion is moving and not adding value. Yes, motion is the opposite of work. And when and where do you add value? When—and only when—you are in your value field. As we peel back the layers, like skin on an onion, we see that the connection between these three elements—motion, value field, and work—is as exact as it is useful. And here’s another layer: there are two types of value field. There’s a single, primary value field and several secondary value fields (i.e., functions that support your primary work).
Here’s an example. What is the primary value field of a surgeon? If you say the operating room (OR), you are only partly right. Think of this: Even though the surgeon’s instruments are in the OR along with vital life-support equipment, the surgeon’s primary value field is not exactly the OR. Her prime value field is the patient on the operating table. All other OR functions support that; they are indispensable but still secondary.
If you are an assembler and work on a bench, you are in motion the moment you leave it because your bench is your primary value field. So think about this as you determine your own primary and secondary value fields. The difference between the two clears up over time as you practice. Once defined, your prime value field becomes a powerful anchor point for pinpointing and measuring your motion. Why? Because any time you leave your value field, you are automatically in motion—because you cannot do your work.
If you are a machinist, you are instantly in motion the moment you physically move away from the machine because your machine is your primary value field. If you are a manager, well, we’ll discuss that in a later issue of The Visual Thinker.
Track your motion based on your value field. Here are three tools or ways to calculate your motion.
1. Clip on a pedometer each time you leave your value field, and take it off when you return. The number at the end of the shift may surprise, even shock, you. It motivated Janette Simone, who traveled 6.7 miles in a single shift. (I didn’t believe it either, but she clocked just about the same three days running.)
2. Use a stopwatch the same way. Turn it on when you leave, turn it off when you return. Buzz Alder clocked 2.5 hours outside his primary value field in a single shift. “No wonder I can never get my work done,” he said in amazement.
3. Use a memo pad (maybe the same as you used for tracking interruptions). Track frequency: the number of times you leave your value field. Six times a day? Nope, more like 16. Or in Mary Beal’s case, 26. Note the reasons!
Do your own study, using your value field as the anchor point. Become a scientist of motion. If you are a manager or supervisor, enlist two or three volunteers to take this on. The invisible enemy is sneaky, and you need powerful weapons to wrestle it to the ground. Are you ready? Let’s go! Let the workplace speak!
First published on the Visual Thinking website.
Gwendolyn Galsworth’s picture
Gwendolyn Galsworth
Gwendolyn Galsworth, Ph.D., has been implementing visuality for more than 30 years. She’s focused on codifying the visual workplace concepts, principles, and technologies into a single, coherent sustainable framework of knowledge. Galsworth founded Visual Thinking Inc. in 1991, and in 2005 she launched The Visual-Lean Institute where in-house trainers and external consultants are trained and certified in the Institute’s nine core visual workplace methods. Two of the seven books Galsworth has written received the Shingo Research and Professional Publication Award.
