Our landlords thank you.
Corey Brown
Published: Thursday, January 2, 2020 - 13:02 Many manufacturers see reducing changeover time as a golden opportunity to improve operational efficiency and reduce waste. For good reason, a simple reduction in changeover time can increase output, reduce inventory, reduce work in progress, and improve responsiveness to customer demand. Yet, the most effective method for standardizing and reducing changeover time is often overlooked—standardized work instructions. Say, for example, that your current changeover takes an hour. Assuming you’re running five to seven days per week, that’s nearly one day a week spent running changeovers. At a minimum you could be wasting 32 days on changeover time per year. Imagine what you could do if you got even half of that time back? Those familiar with lean manufacturing concepts know that changeover time is machine downtime, a nonvalue-adding process (called muda). Reducing changeover time not only has a direct time-saving benefit, but the flexibility of shorter changeover times also allows for more nimble and reliable production cycles. When it’s easier to switch between production runs, a higher variety of parts can be made, and lead times become more predictable—meaning lower inventory, shorter production runs, and higher customer satisfaction. Changeovers can mean a range of procedures depending on your production requirements, but the concept applies to all industries. Most commonly, changeover time is defined as the time elapsed from the last good part of the previous run, to the first good part of the following run. The important part of the definition is the qualifier “good,” because a successful changeover is not complete until the new part run is meeting quality standards. After all, it’s not much value to do something fast if the end result is poor. The two terms, ‘“changeover time” and “setup time” are frequently used interchangeably, but they are not the same thing. Setup time is simply a component of the changeover process. The entire changeover time also includes clean-up procedures for the previous run as well as start-up procedures for the next run. Taiichi Ohno was famous for using standardized work to make monumental reductions in changeover times—sometimes by a factor of 20. With the help of Shigeo Shingo, they revolutionized how automotive manufacturing and other industries pushed themselves to become more efficient. In conjunction with standardized work, Shigeo popularized the single-minute exchange of die (SMED) method as two tactics to reduce changeover time. SMED refers to a reduction in changeover time to fewer than 10 minutes. The basis of this methodology is to convert as many changeover steps to the “external,” or while the previous run is still active, and streamline/simplify the remaining steps as much as possible. “External” means outside of the current changeover procedure. At its core, SMED is about standardizing and then improving. Standardizing your changeover procedures via work instructions is the most effective way to reduce changeover times and train new employees consistently. Before you improve any part of the changeover process, it’s best to get an audit of the current state. By using standard work procedures to document current best practices, you can create a baseline to measure efficiency gains and make improvements. 1. Breakdown 2. Record Pro tip: Record a video of the process in addition to the in-person observation. Video footage can be helpful down the line when you need clarification on a step or help describing a particular technique. This also helps in resisting the temptation to “interview” the operator during the changeover, which interrupts the process and inflates your time analysis. 3. Divide into steps The best way to think about steps or elements is as individual actions. A typical changeover process can average about 30 to 50 steps/elements, but this can vary based on your production needs. 4. Track cycle times 5. Improve, document, repeat Electronic work instructions (EWI), such as Dozuki, are ideally suited to quickly document changeover procedures because they are more accessible, easy to use, and promote a continuous improvement culture. Streamlined process improvement Increased accessibility Bonus: Using quick response codes, operators can scan machines to instantly access the relevant setup procedures. Standardized document control Built-in cycle timing and data collection For longer changeovers, digital sign-offs can be inserted throughout the procedures to allow for quality checks along the way. Using these data, you can assess where bottlenecks in the process are and streamline, or move steps externally to the changeover. Standardize, improve, repeat First published Nov. 26, 2019, on the Dozuki blog. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Corey Brown is the lead researcher and editor for manufacturing resources on Dozuki.com. With a background in engineering and technical communication, Corey specializes in quality management, standard work, and lean manufacturing.How to Reduce Changeover Time With Standard Work Instructions
How many labor hours are your changeovers costing you annually?
The benefits of reducing changeover time
What is changeover time?
Changeover time vs. setup time
Single-minute exchange of die (SMED) and standardized work
How to create standard work instructions for changeover procedures
Start by breaking down the changeover procedure into its three main components: clean-up, setup, and start-up.
Observe and document the process. Much like a time observation, be objective and record the work as clearly and concisely as possible.
Once you’ve specified the three main procedures of the changeover, break down each procedure into individual steps. Similarly, the SMED process begins by breaking down the procedures into individual elements.
Record the cycle time for each individual procedure, as well as the entire changeover process. This step is crucial to understanding the impact of your improvements. Remember, the timing begins at the last good part of the previous run and ends at the first good part of the next run.
Now that your process is documented and standardized, improvements can begin to take place. Start by considering which steps of the process can be moved to the “external” of changeover process. Then, brainstorm which steps can be streamlined and error-proofed (poka-yoke). As these improvements are made, make sure to document the process changes and communicate the updates to the workers on the floor.The benefits of EWI for changeover procedures
Traditional methods for collaborating on standards via emails and PowerPoint files are disorganized and inefficient. EWIs make it easy to author and revise documentation and automate approval processes before changes to the procedures are released to the floor.
When changeover procedures exist only in paper binders, referencing and using the standards become a burden. EWIs can be used on tablets or smartphones; with the addition of rugged cases, these devices can be used in just about any environment. Without the obstacle of binders, mobile tablets encourage workers to utilize standards during changeover procedures, and they also promote a culture of continuous improvement.
Unlike their paper counterparts, electronic work instructions ensure that old standards aren’t floating around the production floor for operators to use. This ensures that operators are working from the current best practices for your changeover procedures.
Additionally, EWIs allow you to ditch the stopwatch and create more detailed time observation reports. Digital forms can capture data during the process to ensure standards are followed.
Reducing changeover times is similar to other process improvement strategies because any plan-do-check-act (PDCA) methodology is built on standardization. Standard work instructions are the best method not only for reducing changeover times, but also improving procedures across your operation.
Quality Digest Discuss
Corey Brown
