Featured Product
Metrology Features
Anna Akins
Robots could handle the human-based tasks of thinning and pruning peach trees
Rebecca Jacobson
A ruler for light, the frequency comb has ushered in medicine, electronics, and astrophysics
UC Berkeley NewsCenter
Important confirmation that scale-up will work
Open software platform enables nonspecialists to code and control any industrial robot to democratize industrial automation
Emily Newton
Consumers want to know that EVs are safe and reliable
More Features
Metrology News
Designed to reduce complexity and increase flexibility in design workflow
Quickly add magnetic chuck, precision vise, and other accessories knowing that each will be perfectly fit and aligned
HP-L-10.10 noncontact laser line scanner takes on broadest scope of CMM inspection tasks with speed, accuracy, flexibility
Award is for development of high-resolution SWIR electro-optical seeker
Partnership embeds quality assurance at every stage of the product life cycle, enables agile product introduction
A total of 152 Go and No-Go ring gages
Even cheaper, faster, more convenient: IDS presents solutions for the most diverse requirements
New design offers low-noise measurements on up to three orthogonal axes
Update offers primary support of QIF 3.0 with bi-directional translation and validation of the MBD portion
More News
Metrology
Ultracompact Ensenso S10 3D Camera Is Universally Applicable and Cost-Effective
20 point clouds per second, maximum deviation of 0.6 mm at object distances of 50 cm
Published: Wednesday, August 18, 2021 - 12:00
(IDS: Woburn, MA) -- Camera manufacturer IDS Imaging Development Systems shows that the use of industrial-grade 3D technology does not have to be expensive.
The Ensenso S 3D camera is particularly suitable for 3D applications that require budget-friendly, easy-to-integrate and industrial-grade camera technology. The new Ensenso S10 has an ultracompact, IP65/67-protected housing and generates 3D data using laser point triangulation, supported by artificial intelligence. This makes the camera suitable for a wide range of applications—and delivers robust 3D information even in low ambient light.
https://www.mymepax.com/pressdoc_files/44020/image/ids-ensenso-s-dimension-size-comparison_300dpi.jpg_ico400.jpg
The Ensenso S10 is equipped with a 1.6 MP Sony sensor and operates on a laser-based 3D process. A narrow-band infrared laser projector creates a high-contrast dot pattern—even on objects with difficult surfaces or in low-light environments. The camera’s laser point triangulation is accelerated by a neural network and enables reliable mapping of the captured pattern points to the hard-coded positions of the projection. This results in robust and geometrically precise 3D data with high depth accuracy. At object distances of 50 cm, the maximum deviation is only 0.6 mm. At full projector power, the Ensenso S10 3D system achieves up to 20 point clouds per second with consistently high quality and resolution.
With a rugged zinc die-cast housing, a 60-degree field of view, and a working range of 0.5 to 3 meters, the 3D camera can be used universally and is suitable for industrial applications with high cost efficiency.
Combined with the proven flexibility of the Ensenso SDK, it is also quickly and easily integrated into many applications where, for example, a variety of objects need to be safely gripped in large numbers or obstacles need to be detected for collision-free movements of robots and UAVs. The Ensenso S10 is also at home in logistics automation as well as in robotics or in the agricultural sector. Especially high-volume and price-sensitive projects can now benefit from 3D image processing in industrial quality.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
