Featured Product
Metrology Features
Oak Ridge National Laboratory
Hafnium oxide key to novel applications
David Suttle
What is breakthrough technology really capable of?
Eric Whitley
Robotic efficiency coupled with human intuition yields a fast, accurate, adaptable manufacturing system
InnovMetric Software
One software capable of operating portable metrology equipment and CMMs within the same user interface
Vivian Lam
Four essential reads on how scientists bring the microscopic world into plain sight
More Features
Metrology News
Air-extend/spring-retract moves probe out of the way
Expanded offering includes Smartscope E-series for 3-axis video measurement
Accelerates CAM programming time 80% to make U.S. manufacturers more productive
Enables scanning electron microscopes to perform in situ Raman spectroscopy
Certified for use in Class 1, Zone 0, Zone 1, and Zone 2 locations
Smart-manufacturing data platform collects, presents, and initiates accurate process and metrology data
Supports back-end process control
Quantum nanometrology just got a step closer
Produces clearer images of samples of any shape in which dense areas mask less dense areas
More News
Metrology
Titan Tool Supply Introduces Industrial Micro Fiberscope Series
Reliable, remote visual inspections and diagnostics in hard-to-reach areas
Published: Thursday, June 8, 2023 - 12:01
(Titan Tool Supply: Buffalo, NY) -- Titan Tool Supply, a worldwide supplier of optical instrumentation and precision micro-finishing tools, introduces its L-Series of family of rigid, industrial-grade micro fiberscopes, also known as fiberoptic borescopes.
The L-Series is designed to perform accurate and reliable remote visual inspections and diagnostics in hard-to-reach, remote, or otherwise inaccessible areas—all without machinery and equipment disassembly or disruption. The series is offered in two unique models: the Model L-1, featuring a 1-mm diameter, 42° field of view, and a 6-in. working range; and the Model L-2, featuring a 2-mm diameter, 50° field of view, and a 12-in. working range. The overall focal length range is 0.118 in. to 0.236 in. (3 mm to 6 mm).
The durable construction of both L-Series models features a long, thin, and rigid stainless-steel tube body. The tube features a lens on one end and a light source (sold separately) on the other. The tube also contains an optical fiber bundle that transmits light from an external light source, thereby illuminating the area under inspection. The image is then transmitted by the fiberscope lens to an eyepiece or camera for remote viewing and diagnostics.
To ensure superior optical resolution for the chosen diameter size, the Model L-1 is offered with a 6K element imaging bundle, while the Model L-2 features a 10K version. Both models can be fitted with an optional 90° viewing tube, resulting in only a small increase in the overall tube diameter. Both feature 30X eyepiece magnification for optimal resolution.
Optional accessories for the L-Series, sold separately, include a fiberoptic illuminator with a 150W quartz halogen lamp, a fiberoptic bundle for connecting the illuminator with the borescope, a 3W LED battery-powered handle, and a video adapter.
Titan Tool Supply L-Series Rigid Industrial Micro Fiberscopes are ideal for a variety of applications: industrial machinery and equipment and their related internal component inspections; automotive maintenance (including interior inspections of engines, cylinders, and other hard-to-reach areas of the vehicle, as well as the detection of leaks, cracks, or blockages); aerospace maintenance (for the inspections of aircraft engines, fuel lines, and other critical components and equipment); and pipeline monitoring. The series is suited to virtually any other general-purpose, industrial-grade, remote visual inspection and diagnostic application in which an end user seeks to identify potential defects, damage, and sources of wear and tear, and especially in hard-to-reach, remote, narrow, or otherwise inaccessible spaces. All of this prevents costly downtime.
For more information about the L-Series or other industrial-grade optical instrumentation offered by Titan Tool Supply, contact the company at 716–873–9907, via email at info@TitanToolSupply.com, or visit www.TitanToolSupply.com.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
