Featured Product
Metrology Features
Dan Hamilton
Identify trace elements and alloys, analyze precious metals, and determine coating weight and plating thickness
Geert Elie
Should you use water or CO2?
Anna Akins
Robots could handle the human-based tasks of thinning and pruning peach trees
Rebecca Jacobson
A ruler for light, the frequency comb has ushered in medicine, electronics, and astrophysics
UC Berkeley NewsCenter
Important confirmation that scale-up will work
More Features
Metrology News
Designed for process cooling applications including industrial cooling circuits
New president brings two decades of executive leadership to metrology manufacturer
Unrivaled quoting system delivers new paradigm in streamlined sourcing and process visibility for North American customers
Feature uses special control algorithms to carry out a step-by-step adjustment of the ram height
Make comparative measurements of very small bores ranging from 1 mm to 20 mm
Modular format makes learning about surface roughness, finish, friction, and wear more affordable and accessible
New and experienced users can easily obtain advanced measurements
PG-Series bore gages require no electricity, air, or special expertise to check honing, grinding, boring, reaming, drilling, screw machine operations
KinAiry system features 2.3-m reference bar custom-tailored to precision requirements of the ISO interim field test
More News
Metrology
Suburban Tool Announces SineSet System
Quickly add magnetic chuck, precision vise, and other accessories knowing that each will be perfectly fit and aligned
Published: Monday, October 18, 2021 - 11:00
(Suburban Tool Inc.: Auburn Hills, MI) -- Suburban Tool Inc., a well-known manufacturer of high-precision, high-quality tools for toolmakers, announces this addition to its line, the SineSet System.
The SineSet System is comprised of a series of SineSet compatible accessories that can be bolted directly to Suburban sine plates, compound sine plates, and 90° conversion plates to create complete working systems.
Starting with a sine plate, quickly add and remove a magnetic chuck, precision vise, precision angle plate, vacuum chuck, Master-Grind spin index fixture, and more, knowing that each accessory will be perfectly fit and aligned each and every time.
The SineSet System:
• Saves time and money
• Gives you the competitive edge
• Allows quick setups
• Requires less investment in tools
• Eliminates clamping
• Needs little or no indicating
• Enables an almost limitless number of tool combinations
All tools can be used independently or as a sine system.
About Suburban Tool Inc.
Suburban Tool Inc. has more than 50 years of experience in manufacturing the highest quality work-holding products and inspection equipment for thousands of satisfied customers from the smallest operations to the largest corporations!
A significant part of Suburban’s quality is due to its experienced craftsmen adhering to precision standards. Suburban’s products are manufactured by using exacting procedures.
Suburban Tool Inc. proudly manufactures products in its 70,000 square foot world headquarters Auburn Hills, Michigan.
Contact sales:
Suburban Tool Inc.
4141 N. Atlantic Blvd.
Auburn Hills, MI 48326
Phone: (248) 391-7800
Fax: (248) 391-7462
Email: tools@subtool.com
https://www.subtool.com/
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
