Our landlords thank you.
Earth Institute
Published: Tuesday, September 28, 2010 - 05:00
Researchers analyzed high-resolution video to determine the volume of the Deepwater Horizon spill.
(The Earth Institute, Columbia University: New York) -- BP's leaking oil well in the Gulf of Mexico was conclusively sealed during the week of Sept. 20, but even now questions remain about the amount of oil that actually came out of it. Initially after the April 20 explosion, officials claimed that the flow could not be measured. Then, as public pressure for information mounted, they looked for ways to measure it and started producing estimates: at first, 1,000 barrels a day, then 5,000, then 12,000 to 19,000, then upward from there.
Now, in the first independent, peer-reviewed paper on the leak’s volume, scientists have affirmed heightened estimates of what is acknowledged as the largest marine oil accident ever. Using a new technique to analyze underwater video of the well riser, they say it leaked some 56,000 to 68,000 barrels daily—maybe more—until the first effective cap was installed on July 15. Their estimate of the total oil escaped into the open ocean is 4.4 million barrels, close to the most recent consensus of government advisors, whose methods have not been detailed publicly. The paper appears in this week’s early online edition of the leading journal Science.
“We wanted to do an independent estimate because people had the sense that the numbers out there were not necessarily accurate,” says lead author Timothy Crone, a marine geophysicist at Columbia University’s Lamont-Doherty Earth Observatory. After BP and government officials downplayed the possibility or importance of measurements, a wide spectrum of scientists, environmental groups, and legal experts pointed out that the information was needed to determine both short- and long-term responses, and monetary liability. This baseline number is also essential to address the continuing scientific controversy over where the oil has gone.
The new study divides the flow rate into two periods: April 22 to June 3, when oil spurted from a jagged break in the riser; and after June 3, when the riser was cut and oil temporarily spewed into the ocean unimpeded. Crone and his co-author, Lamont marine geophysicist Maya Tolstoy, used a visual analysis technique Crone recently developed called optical plume velocimetry, an optical flow technique using intensity data in the time direction. The technique will soon provide important constraints on the fluxes of fluids, heat, and chemicals through black smoker vents, and may help define and understand the links between mechanical processes such as tidal loading and plate tectonics, and other processes such as subsea-floor biological productivity.
They say video from the earlier period indicated a flow of about 56,000 barrels a day (a barrel is 42 gallons). After the pipe was cut, they say, the rate went to about 68,000. After accounting for time elapsed, the authors subtracted 804,877 barrels collected by BP at the site, to come up with a total of 4.4 million barrels that escaped. Given the study’s stated 20-percent margin of error plus or minus, this roughly agrees with the federal government’s Flow Rate Technical Group’s most recent comparable estimate of 4.1 million barrels (after subtracting the oil collected by BP).
Study author Timothy Crone (left) prepares to deploy an underwater camera to record flow from natural hydrothermal vents off the U.S. Pacific northwest. Techniques used on the vents were adapted to measure oil flow in the Gulf.
Attempts to get a handle on the size of the release have been fraught with high-profile problems. A week after the initial 1,000-barrel-a-day assertion, it became apparent that BP was collecting more than that, and far more was escaping. On April 28, the National Oceanic and Atmospheric Administration hastily produced an estimate of 5,000 barrels, using a conventional formula to extrapolate this from the size of the surface plume. But scientists and journalists soon attacked this figure (for instance in a May 13 New York Times report) because the spill was occurring far below the surface. Crone became involved when National Public Radio asked him and other experts to come up with their own estimates; a May 14 NPR story based on their observations suggested that the rate was actually five or 10 times higher. On May 21, the Times published an op-ed piece by Crone and colleagues from three other institutions outlining the case that existing scientific techniques could be used to form a realistic picture. On May 27, the government raised the estimate again, to 12,000-19,000 barrels per day. A variety of techniques went into this and the later, even higher, official estimates, but the government and its advisors have released only limited information on their techniques—again, raising criticism from the scientific community. This new study is the first to lay out the details of an analysis publicly in a report independently reviewed by other researchers.
Crone started developing optical plume velocimetry in 2006 to study natural hydrothermal vents—volcanically-driven cracks and holes in the sea floor that shoot out buoyant, superheated jets of mineral-laden water. A jet from a leaking oil pipe is similar. The technique uses high-resolution video from underwater cameras to track the motion of turbulent billows and flows in the water, breaking down the movement pixel by pixel. Under a grant from the U.S. National Science Foundation, Crone tested it first in the lab, then at deep-sea vents in the eastern Pacific, and the Juan de Fuca ridge off the U.S. Pacific northwest. He is currently developing a network of automatic cameras that will track vent activity on the Juan de Fuca. “This is a great example of how basic research that doesn’t seem to have any immediate value suddenly gains huge immediacy for society,” says Crone.
Flow from the damaged well June 3, 2010, overlain by image velocity field computed by optical plume velocimetry
The scientists say their study is just a start. Other researchers have been trying to get at the same question using separate visual and acoustic techniques. Crone and Tolstoy say their conclusions rest on just a few short clips of high-resolution video—almost all that has been released by BP and the government so far and made available by members of Congress to the scientists. (A live, publicly accessible webcam showing the leak as it continued week after week had extremely low resolution, insufficient for analysis.) The researchers point out that the flows could have varied day to day. And the analysis did not include video of several other leaks from smaller holes further up the pipe, which are thought to have grown with time; thus, the true figures may be larger, if anything, says Crone. “We clearly acknowledge the limits of our technique; we’re unlikely to ever know the exact figure,” he says. “This is not the last word. It is the first peer-reviewed word. But we think it’s a really good ballpark,” Tolstoy adds.
The researchers say they hope they and others will be able to refine their estimates if the government and BP release more video and other information to independent researchers. “This is a welcome paper in that it opens the door onto how the oil spill flow-rate estimates have been calculated,” says Ian MacDonald, a Florida State University oceanographer who has also studied the leak but was not involved in the study. “It provides a transparency of method and a foundation for peer review for what has until now been a confusing and uncertain process.”
Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, The Earth Institute’s overarching goal is to help achieve sustainable development primarily by expanding the world’s understanding of Earth as one integrated system. Earth Institute works toward this goal through scientific research, education, and the practical application of research for solving real-world challenges. With 850 scientists, postdoctoral fellows, staff, and students working in and across more than 30 Columbia University research centers, the Earth Institute is helping to advance nine interconnected global issues: climate and society, water, energy, poverty, ecosystems, public health, food and nutrition, hazards, and urbanization. With Columbia University as its foundation, the Earth Institute draws upon the scientific rigor, technological innovation, and academic leadership for which the university is known.Measuring the Size of the Gulf Oil Spill
First independent measure of well employs new imaging method
Courtesy U.S. Senate Committee on Environment and Public Works
Photo by Carlos Sanchez, OOI-RSN Enlighten'10 Cruise, University of Washington
Tim Crone, Lamont-Doherty Earth Observatory
Quality Digest Discuss
Earth Institute
