Featured Product
Metrology Features
MIT News
They can quickly learn to optimize building microclimates for both energy consumption and user preference
Loretta Marie Perera
3D scanning and printing an impossible-to-find, 100-year-old distributor cap
NVision Inc.
Laser scans of large and small surfaces performed in just three days
Douglas Allen
Removing the random noise component from the observation, leaving the signal component
Lawrence Livermore National Laboratory
Liquid metal jetting is highly stable and repeatable, but extremely challenging to model
More Features
Metrology News
An advanced wireless data collection system for acquiring precision measurement data
All of the manufacturer’s X-ray sources are supported including rotating target technology and 450kV microfocus source
Ideal for measuring large components or multiple small components, quickly, easily, and accurately
Measure workpieces from 25 mm to 42.5 mm with a measuring range of ±100 µm and a repeatability of ≤0.1 µm
Contactless gauging system for measuring steel wire for tires, copper wire for electrical cables, CO2 welding wire, and more
Resolve CMM productivity issues with MetraSCAN-R BLACK|Elite, CUBE-R 3D, and digital twin environment software
Videos address common topics related to surface specification, measurement, and interpretation, in five minutes or less
Scan 99% of parts without touching the scanner exposure
More News
L.S. Starrett Co.
Metrology
Starrett Introduces Flexible Force Testing Systems Design
Full range of Starrett force software solutions are now interchangeable with different Starrett frame series
Published: Wednesday, January 8, 2020 - 12:00
(The L.S. Starrett Co: Athol, MA) -- The L.S. Starrett Co., a leading global manufacturer of precision hand tool gauges, a broad range of force testing solutions, metrology equipment, and more, has introduced a flexible selection architecture that enables the range of Starrett force and material testing software programs to be compatible with its different test frame series. This interchangeable system architecture increases application versatility, providing users a wider range of solution options from basic to advanced, for their specific force and material testing needs.
Starrett L2, S2, L2 Plus, and L3 software are now compatible and interchangeable with all Starrett frame/stands series (FMM, FMS, FMD, MMS, MMD). In addition, Starrett L1 and S1 software is compatible with FMM Series frames.
Starrett FMM frame testers are compact and ideal for high volume, lean manufacturing production. Starrett FMS and MMS frames accurately determine simple load, distance and break, or more complex material testing applications such as Young’s Modulus, tensile strength, stress, or strain. Starrett FMD and MMD Series test frames are suitable for simple force and distance measurements, as well as more complex material testing applications.
Starrett Force and Material Testing software programs enable a full range of testing solutions. Starrett L1 Software is ideal for quality control and incoming inspection. Engineered to meet the requirements for fast, efficient, high-volume production testing, L1 combines functionality with affordability. Starrett L2 software is well suited for demanding force measurement testing to create complex testing methods or when using standard Starrett test templates, for all types of force measurement applications. Starrett L2 Plus software provides engineering and quality personnel with an easy-to-use, yet comprehensive solution for complex force analysis and measurement. Starrett L3 software is optimal for users involved with material testing and characterization, research and design engineers, quality control, test technicians, and others.
Starrett S1 software represents a basic digital testing solution for compression and extension springs. S1 is ideal for high-volume production testing and individuals looking for more consistent testing results. Starrett S2 software is an application-specific solution for testing compression and extension springs, enabling spring rate, spring constant, initial tension, free length and more, fast and efficiently.
For more details on Flexible Force System Design Solutions from Starrett visit starrett.com/forceflexibility.
L.S. Starrett Co.’s picture
L.S. Starrett Co.
The L.S. Starrett Co., founded in 1880, manufactures more than 5,000 variations of precision tools, gauges, measuring instruments, and saw blades for industrial, professional, and consumer markets worldwide. Starrett, a company that has set the standard for fine precision tools in industry for more than 123 years, has rightfully earned the title “World’s Greatest Toolmakers.”
