Featured Product
Metrology Features
NIST
Breakthrough could help Nobel-winning tech measure distances and timing with pinpoint precision
S. Heather Duncan
Getting the most out of X-ray computed tomography
Elizabeth Benham
They'll make a measurable difference
Mara Strenger
Intelligent packaging with smart indicators could reduce food waste
Mark Hembree
Amazing technology, even greater potential
More Features
Metrology News
Complete NDT solution measures thickness loss on corroded, industrial, complex geometry
Eastern Applied Research now has ISO 17034 certification in addition to ISO/IEC 17025
Features include flexible installation and fast measurement
Approved for use in Class 1, Zone 0, and Zone 2 locations
Guidance for deploying digital twins safely and securely
New model promises high-accuracy, 360-degree spherical image capture
Laser profiling for myriad gear sizes and shapes
More News
Visual Workplace Inc.
Metrology
Quickly Identify Gauge and Inspection Specs With Gauge Marking Label
Perfect for error proofing inspection tools for pressure/vacuum, alignment/measurement
Published: Wednesday, September 26, 2012 - 11:34
(Visual Workplace: Byron Center, MI) -- Visual Workplace Inc. introduces Gauge Marking Label—a simple and cost-effective means for machine operators to quickly identify gauge and inspection parameters and specifications.
Gauge Marking Label is perfect for error-proofing Go-No-Go gauges, pressure/vacuum gauges, alignment/measurement gauges, and other inspection tools to help maximize productivity and quality control. It is also well suited for any number of other applications such as tinting windows, enhancing signage, applying to backlit signage, and reducing lighting glare.
Gauge Marking Label is 2.0-mil thick, and comes in red, yellow, or green 12 in. × 16 in. sheets.
Gauge Marking Label can be applied to most smooth surfaces including glass, metal, PVC, magnet, corrugated plastic, dry erase board, reflective vinyl acrylic, and others. The material promotes optimal cutting, weeding, lifting, and transfer. It is easily cut by hand, or sheets can be fed into the plotter of the Mobile In-House Sign Shop for precision cutting.
Gauge Marking Label has a one-year shelf life. Indoor use is recommended, but it can withstand outdoor use for up to seven years.
Visual Workplace Inc.’s picture
Visual Workplace Inc. specializes in high quality products needed to help implement and sustain a lean work environment and 5S programs—such as the Mobile In-House Sign Shop which is designed for mobility and speed to tackle all 5S projects and to create visual controls quickly and easily at a fraction of the normal cost to purchase signs. Visual Workplace Inc. operates worldwide serving the automotive, consumer products, food and beverage, aerospace, retail, telecommunications, government/defense, pharmaceutical, health care, and educational industries.
