Featured Product
Metrology Features
Dan Hamilton
Identify trace elements and alloys, analyze precious metals, and determine coating weight and plating thickness
Geert Elie
Should you use water or CO2?
Anna Akins
Robots could handle the human-based tasks of thinning and pruning peach trees
Rebecca Jacobson
A ruler for light, the frequency comb has ushered in medicine, electronics, and astrophysics
UC Berkeley NewsCenter
Important confirmation that scale-up will work
More Features
Metrology News
Unrivaled quoting system delivers new paradigm in streamlined sourcing and process visibility for North American customers
Feature uses special control algorithms to carry out a step-by-step adjustment of the ram height
Modular format makes learning about surface roughness, finish, friction, and wear more affordable and accessible
Make comparative measurements of very small bores ranging from 1 mm to 20 mm
New and experienced users can easily obtain advanced measurements
PG-Series bore gages require no electricity, air, or special expertise to check honing, grinding, boring, reaming, drilling, screw machine operations
KinAiry system features 2.3-m reference bar custom-tailored to precision requirements of the ISO interim field test
Enables data prep for sheet metal manufacturing, improves PMI exchange, simplifies ACIS multi-threading, and more
With MyMitutoyo, users can request price quotes, find a distributor, request more product information
More News
Metrology
Product Inspection: X-ray Industry Capabilities Increase Two-Fold
ABM Equipment doubles industry-standard capabilities with Eagle Product Inspection technologies
Published: Wednesday, June 9, 2021 - 11:00
(ABM Equipment: Vancouver, WA) -- ABM Equipment is detecting foreign material half the size previously possible for the industry using new hardware and software from Eagle. With a mix of improved detector boards, generators, and algorithms, contaminants as small as 0.3 mm are detectable in some products.
Originally developed for the poultry industry, where bones are becoming finer and less calcified as practices change, the new solution, called “PXT”, was intended to be the best solution for one of the market’s most difficult applications. To do this the generators’ beam geometry was modified and the detection nodes (diodes) were placed closer together—reducing the spaces through which contaminants could slip. With more data to work from, the algorithms were also restructured to more accurately identify contaminants and reduce false rejects.
ABM Equipment PXT detects a variety of contaminants down to 0.3 mm.
Initial tests were surprising, even to ABM Equipment. “We knew it was going to be better, we just didn’t know by how much,” says Jeff Walling, co-owner of ABM Equipment. “We took the [PXT] in a head-to-head against the industry’s other top players and blew them out of the water. Even the smallest test contaminants—the ones meant to make the machines fail—were detected at 100-percent accuracy. We just didn’t have contaminants small enough to see how far it could go. And that’s when the light came on.”
Since its launch, ABM has applied “PXT” to other products and documented the same results. “This is a quantum-leap for the industry,” says John Cassa, co-owner of ABM Equipment. “For the past few decades every player in the space has been pretty comparable. One company may perform better with this contaminant or that product, or they might get real tight specs on a specific application. They might see 0.3 mm stainless steel in cheese, for example, but then that’s all they can see. We’re getting unheard-of specs on everything—metal, bone, glass, plastic, stone, item weight, fill level, whatever. Even mass measurement and item count have improved.”
ABM Equipment is Eagle’s principal distributor and product-development partner. They helped develop a number of applications including the pipeline and meat chub solutions and have produced a software package which simplifies machine validations, product rework, and image retrieval to combat false liability claims.
To learn more visit abmxray.com/pxt/ or contact Sam Cassa at (360) 690-6481 or ncassa@abmequipment.com.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
