Featured Product
Metrology Features
Dan Hamilton
Identify trace elements and alloys, analyze precious metals, and determine coating weight and plating thickness
Geert Elie
Should you use water or CO2?
Anna Akins
Robots could handle the human-based tasks of thinning and pruning peach trees
Rebecca Jacobson
A ruler for light, the frequency comb has ushered in medicine, electronics, and astrophysics
UC Berkeley NewsCenter
Important confirmation that scale-up will work
More Features
Metrology News
Unrivaled quoting system delivers new paradigm in streamlined sourcing and process visibility for North American customers
Feature uses special control algorithms to carry out a step-by-step adjustment of the ram height
Modular format makes learning about surface roughness, finish, friction, and wear more affordable and accessible
Make comparative measurements of very small bores ranging from 1 mm to 20 mm
New and experienced users can easily obtain advanced measurements
PG-Series bore gages require no electricity, air, or special expertise to check honing, grinding, boring, reaming, drilling, screw machine operations
KinAiry system features 2.3-m reference bar custom-tailored to precision requirements of the ISO interim field test
Enables data prep for sheet metal manufacturing, improves PMI exchange, simplifies ACIS multi-threading, and more
With MyMitutoyo, users can request price quotes, find a distributor, request more product information
More News
Metrology
Product Innovations From IDS on Display at VISION 2021
Even cheaper, faster, more convenient: IDS presents solutions for the most diverse requirements
Published: Tuesday, October 5, 2021 - 11:00
(IDS: Woburn, MA) -- From precise monitoring to picking and automation, there are countless applications that benefit from reliable image information. However, what can be done when there is only a tight budget for the realization of such an application? With the introduction of uEye XCP, uEye XLE, and Ensenso S, camera specialist IDS proves that industrial-grade image processing technology does not have to be expensive. For users who need a camera for particularly fast data transfer and also require high-resolution sensors, there will be the uEye Warp10 in the future. The company also has big plans for IDS NXT. The next software update will follow in October, making the embedded vision system even more user-friendly and the AI behind it easier to understand. All innovations will be presented at the VISION show, Oct. 5–7, 2021, booth 8C60 in Stuttgart, Germany, with the help of demo systems.
IDS invites all those who cannot visit the trade fair to take a virtual tour of the booth. On the IDS Vision Channel (www.ids-vision-channel.tech), users can discover the new products at the same time as regular VISION visitors.
uEye XCP: Smallest industrial camera with housing and C-mount
The new uEye XCP camera family from IDS shows that cost-effective industrial cameras with C-mount can also be offered in the industry’s smallest standard format. Initially, the USB3 camera will be launched with the 2.3 MP AR0234 global shutter sensor and the 5 MP AR0521 rolling shutter sensor from ON Semiconductor. Their cost-optimized design makes them ideal for high-volume and price-sensitive projects. The cameras feature a fully enclosed die-cast zinc housing measuring just 29 × 29 × 17 mm. Their C-mount adapter allows the use of common lens sizes and ensures a favorable system price.
uEye XLE: Versatile and consistently cost-optimized
For anyone looking for cameras specifically designed for high-volume and price-sensitive projects, the uEye XLE camera family is also worth considering. Thanks to different housing and lens holder variants, extremely compact dimensions, and USB3 interface, the cameras can be easily integrated into any image processing system. Customers can choose between models with plastic housing and C/CS mount or S-mount and board-level version with or without C/CS mount or S-mount lens holder. Available with the 2.3 MP sensor ON Semiconductor AR0234 and the light-sensitive 5 MP sensor ON Semiconductor AR0521, other sensors will follow.
uEye Warp10: 10GigE high-speed for image data
For users with particularly high demands on resolution, image quality, and transmission speed, IDS will launch industrial cameras with a 10GigE high-speed interface and various sensors under the name uEye Warp10. They are capable of precisely capturing even high-speed processes and forwarding the image information in the network without delay. They excel in sports analysis as well as in high-precision surveying and inspection tasks. The company plans to implement large-format sensors up to 45 MP.
Ensenso S: Compact and budget-friendly 3D camera
Ensenso S has been specially designed for 3D applications that require budget-friendly, easy-to-integrate, and industrial-grade camera technology. Especially price-sensitive projects in logistics, automation, or agriculture can now benefit from industrial-grade 3D imaging. The models are equipped with an ultracompact zinc die-cast housing (IP 65/67), a 1.6 MP Sony sensor, and an infrared LED laser and provide robust 3D information even in low ambient light.
IDS NXT ocean: Embedded vision system with AI becomes even more user-friendly
Artificial intelligence running directly on cameras and enormous flexibility through vision apps—this makes tasks possible where conventional image processing reaches its limits. IDS provides users with all the necessary and perfectly coordinated tools and workflows to realize their own AI vision applications without prior knowledge. The next free software update will be released in October. It will focus on user-friendliness—e.g., new features will be integrated into the IDS NXT cockpit—as well as on making artificial intelligence comprehensible. New helpful tools, such as attention maps, illustrate how the camera AI works and makes decisions.
Learn more at https://en.ids-imaging.com/vision-2021.html.
About IDS Imaging Development Systems GmbH
The industrial camera manufacturer IDS Imaging Development Systems GmbH develops high-performance, easy-to-use USB, GigE and 3D cameras with a wide spectrum of sensors and variants. The almost unlimited range of applications covers multiple non-industrial and industrial sectors in the field of equipment, plant, and mechanical engineering. In addition to the successful CMOS cameras, the company expands its portfolio with vision app-based, intelligent cameras. The novel image processing platform IDS NXT is freely programmable and extremely versatile.
Since its foundation in 1997 as a two-man company, IDS has developed into an independent, ISO-certified family business with more than 300 employees. The headquarters in Obersulm, Germany, is both a development and production site. With branches in the United States, Japan, South Korea, and the United Kingdom as well as other offices, IDS is represented internationally.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
