Featured Product
Metrology Features
Emily Newton
With Industry 4.0 technology, businesses can enable new equipment testing, monitoring, and maintenance techniques
William A. Levinson
The analytical method allows more detailed quantification of the gage standard deviation and bias
Suneel Kumar
Leveraging the strengths of your team members
James Bossert
A review of the fundamentals of a gauge R&R study to remind us why it’s so critical
William A. Levinson
Common sense says it is beneficial to understand the capabilities and limitations of inspections for attributes
More Features
Metrology News
Creaform has optimized its fully integrated 3D software platform that powers the entire fleet of 3D scanning and measurement technologies
Measures EV rotor shafts and cylindrical components
Q&A-style guide addresses common surface texture topics
Work directly on machine tool to rapidly capture a complete picture of a part’s surface
New offering addresses cost efficiency and reliability requirements of urban security screening
Updates improve usability, speed, and accuracy of nondestructive testing, analysis, and geometry repair of parts
3k detector and 225 kV X-ray provides high-contrast, high-resolution measurements, exceptional sharpness of detail
More News
Metrology
Marposs Announces Simple, Turnkey System for Leak Testing of Blood Lines
Compact system provides semiautomatic testing and error proofing, helping reduce operator motion and overall cycle time
Published: Tuesday, June 8, 2021 - 12:00
(Marposs: Auburn Hills, MI) -- Marposs, a world leader in measurement, inspection, and test technologies, has announced the availability of its Tecna T2 leak tester and AV10 test fixture solution developed specifically for verifying the integrity of medical blood lines. Featuring the reliable Tecna T2 pressure decay leak tester with an integrated pneumatic test fixture, this compact system provides semiautomatic testing and error proofing, helping to reduce operator motion and overall cycle time.
The T2/AV10 automatically starts the test when the operator connects the blood line to the system and automatically releases it at the end of the test if the test is positive (passed). In the case of a fail, the fixture will not release until the operator acknowledges the failure. Featuring an easy-to-read 3.5-in. color LCD touchscreen, the “Passed” or “Failed” results are displayed for individual tests as well as totaling the results. The AV10 can be configured with customer-specified connector types and sizes.
The T2/AV10 offers leak test with full scale up to 6 bar and 1 Pa (0.01 mbar) resolution on leak reading. The test pressure can be regulated with a manual precision pressure regulator with pressure indicated on the display.
With individual fill, settle, and measure step times, the T2/AV10 can be programmed for up to 100 tests. It can communicate through digital I/O, Ethernet, USB host/slave, and RS232/R485 serial lines. Data collection is possible via a USB or Ethernet connection.
Pressure decay testing process
The Tecna T2 pressure decay leak test uses three phases. Step 1 is the fill; test pressure is verified to be within tolerance and checks for a gross leak. Step 2 is the stabilize step; the fill valves are shut off to isolate the air supply from the test part and the T2 monitors for a gross leak. Step 3 is the leak step, where the Tecna T2 monitors for a fine leak. Limits can be established around the Δp (pressure change) or with the use of a calibrated leak master, the Δp can be converted to a linear flow rate.
To see this testing system in action, watch this video. For more information on the Tecna T2/AV10, visit https://www.marposs.com/eng/product/equipment-leak-and-flow-testing, call toll-free (888) 627-7677, or e-mail marposs@us.marposs.com.
Marposs Tecna T2/AV10 testing solution designed for leak testing of blood lines.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
