Featured Product
Metrology Features
Tim Mouw
Take these pitfalls into consideration as you develop your color measurement and management procedures
Ryan E. Day
September Speaker Series in review
A brief survey of leading coordinate metrology solutions
Jérôme-Alexandre Lavoie
Unique approach facilitates more proactive CAPA, mitigates cost of quality and recalls
Zach Murphree
Measuring before, during, and after a part build
More Features
Metrology News
Contactless gauging system for measuring steel wire for tires, copper wire for electrical cables, CO2 welding wire, and more
Resolve CMM productivity issues with MetraSCAN-R BLACK|Elite, CUBE-R 3D, and digital twin environment software
Videos address common topics related to surface specification, measurement, and interpretation, in five minutes or less
Scan 99% of parts without touching the scanner exposure
New AVX550 system combines best features of vision and touch-probe inspection
Scan was used to create 80% to-scale 3D-printed replica
Quickly captured complex geometries resulting in optimally designed roof racks and greatly accelerated completion time
Designed for scientists, engineers, technicians working in medical devices, automotive, aerospace, and other fields
New line of micrometers are easy to use, have enhanced features and performance, competitively priced
More News
Marposs
Metrology
Marposs Announces Aeroel MECLAB.T40 Bench-Top Laser Measurement System
Measure carbide tools and metal blanks
Published: Monday, August 3, 2020 - 12:00
(Marposs: Auburn Hills, MI) -- Marposs, a world leader in measurement, inspection and test technologies, announces MECLAB.T40 by Aeroel—a high-precision laser instrument for quick and simple diameter measurement of hard metal blanks and full carbide cutting tools, odd or even edges. This system checks tolerances by comparing the actual dimensions to the programmed limits and is suited for off-line checking of drill bits, end mills, reamers and cutting tools as well as for checking the diameter, ovality and straightness of hard metal blanks and ground pins or cylinders. The MECLAB.T40 does not require a PC, making it ideal for use on the shop floor.
MECLAB.T40 features the Xactum XLS40/1500/B Laser Micrometer, an extremely accurate and repeatable measuring instrument with a measuring field up to 40 mm, linearity of ± 0.5 μm, repeatability of ± 0.05 μm and permanent self-calibration. Additionally, it comes with Aeorel’s exclusive NO-VAR technology which eliminates the potential of measuring drift due to changing room temperature by programming the coefficient of thermal expansion of the part.
The system is offered in either a manual or automated version with objective and highly reproducible results regardless of the operator’s skill. It is a non-contact, flexible measuring device that enables the measuring of different components without gauge re-mastering.
How it works
The part is inserted onto a double V-fixture mounted on a manually driven slide equipped with a magnetic digital readout scale. This displays the displacement of the part itself with the position continuously displayed on the screen. Using a guided procedure, the operator seeks the starting point, moves the part to the measurement position and starts the cycle. During this, the part is manually or automatically rotated to a measurement period set by the computer. During rotation, the laser sensor scans the part at 1500 samples/second and stores all the measurements related to the positions of the upper and lower edge of the part. Data processing software performs accurate and repeatable measurement of the cutting diameter and run-out of the part, for both odd or even fluted parts. The measured results are updated and displayed in real time, giving the operator the information when to stop the check. When measuring round parts, i.e. hard metal blanks, it checks the diameter, the ovality and the end run-out of the part.
For more information on Aerol MECLAB.T40 systems from Marposs, visit https://www.aeroel.it/products/meclab-tools-laser-micrometers-to-check-diameter-of-full-carbide-tools.html, call 1-888-627-7677 or E-mail marposs@us.marposs.com. Follow our company activity at Facebook, LinkedIn or Twitter.
Marposs MECLAB.T40 by Aeroel offers laser measurement of hard metal blanks and full carbide cutting tools.
Marposs’s picture
Marposs
Marposs supplies precision gauging equipment to industries worldwide for measuring to the thousandth of a millimeter in the workshop environment, production lines, and on board machine tools. Main customers are machine tool manufacturers, automotive and their subcontractors, aerospace, bearings, glass, electrical motors, appliances, consumer durables industries, and gauge and fixture makers. Marposs supplies individual gauging components, turnkey machines, or fully automated lines. Headquartered in Bentivoglio, Italy, Marposs’ U.S. office is in Auburn Hills, Michigan.
