Featured Product
Metrology Features
Catherine Cooksey
Ensuring that measurements aid the broader industrial and scientific communities that depend on them
MIT News
They can quickly learn to optimize building microclimates for both energy consumption and user preference
Loretta Marie Perera
3D scanning and printing an impossible-to-find, 100-year-old distributor cap
NVision Inc.
Laser scans of large and small surfaces performed in just three days
Douglas Allen
Removing the random noise component from the observation, leaving the signal component
More Features
Metrology News
Designed for precise measurement of form, featuring new levels of flexibility and speed
Single- and three-axis shop-floor dimensional measuring machines for industrial manufacturers
Precision optical instrument helps ventilator maker increase specialty valve production in response to shortage
Allows team to focus on quality control in dimensional measurements and overall machining process
Contactless sensors measure rotating shafts in industrial benchtop and test and measurement applications
3DCS Design Variation Analyst, 3DCS Viewer, and 3DCS Mechanical Variation Modeler create a scalable solution to tolerance analysis and simulation
Operators can monitor full process, including cooling cycle, which can be altered to change the microstructure of parts to suit needs
Infrared cameras, structured light scanning, and electron imaging provide extensive and detailed data on every part
More News
Marposs
Metrology
Marposs’ Aeroel Wireline Enables 100% Inspection of In-Process Drawn Wire
Contactless gauging system for measuring steel wire for tires, copper wire for electrical cables, CO2 welding wire, and more
Published: Tuesday, October 27, 2020 - 11:00
(Marposs: Auburn Hills, MI) -- Marposs, a world leader in measurement, inspection, and test technologies, announces the availability of its Aeroel Wireline laser measuring system designed for in-line checking of drawn wire diameter and ovality. Wireline is a contactless gauging system well-suited for measuring steel wire for tires, copper wire for electrical cables, CO2 welding wire, and more. By enabling 100-percent inspection, it eliminates any risk of rejects or complaints, helping to improve quality, eliminate scrap, and reduce labor cost.
Using a dual-axis laser gauge, the Wireline  laser measuring system checks the wire tolerance of the wire and stops the drawing machine when the die wear exceeds the pre-set limit. It counts the meters of wire being drawn and provides statistical reports for each spool.
The Wireline system is unaffected by wire vibration and speed, consistently delivering accurate and reliable measurements. It features a patented dust protective jacket that safeguards it from soap and iron dust, making it possible for installation on dry drawing benches.
Wireline systems are available in two styles: the XY13 with a measuring field of 13 × 13 mm, a diameter range of 0.1 to 10 mm and repeatability up to ±0.15 µm, or the XY35 with a measuring field of 35 × 35 mm, a diameter range from 0.2 to 32 mm and a repeatability up to ±0.3 µm. All Aeroel lasers systems are capable of resolution up to 0.01 µm.
Both versions come with the pre-loaded Wireline.XY software that is easy to use and simple to program, even by non-experts. Additional software modules can be added as needed. The weight measuring module computes and displays the length and the weight of the drawn wire, and the statistics module records and prints maximum, minimum, and average values.
The Wireline system can be set up for automatic change of collection-reels or systems to wind spools up to a pre-set weight, as well as offering the ability to link and connect several systems together so that all process information is managed by one computer.
For more information, visit www.marposs.com or www.aeroel.it, call toll-free (888) 627-7677, or e-mail marposs@us.marposs.com. Follow company activity on Facebook, LinkedIn, or Twitter.
The Aeroel Wireline from Marposs provides in-process measuring of wire ovality and diameter.
Marposs’s picture
Marposs
Marposs supplies precision gauging equipment to industries worldwide for measuring to the thousandth of a millimeter in the workshop environment, production lines, and on board machine tools. Main customers are machine tool manufacturers, automotive and their subcontractors, aerospace, bearings, glass, electrical motors, appliances, consumer durables industries, and gauge and fixture makers. Marposs supplies individual gauging components, turnkey machines, or fully automated lines. Headquartered in Bentivoglio, Italy, Marposs’ U.S. office is in Auburn Hills, Michigan.
