Featured Product
Metrology Features
Matthew Martin
The established technology of coordinate measuring machines is being challenged by blue-light scanning
Ryan E. Day
Realigning a cornerstone of industry
Willow Ascenzo
N-ray can provide a different, and often useful, perspective from planar X-ray radiography and CT
Do your instruments have the same amount of measurement error?
Matthew Staymates
Visual proof supports the ‘Cover smart, do your part, slow the spread’ slogan
More Features
Metrology News
REVO 2 features 1-meter cubed capacity and automation options
Hexagon Manufacturing Intelligence launches technologies to transform inspection workflows for enhanced productivity
An efficient and cost-saving way of working with materials like plastic, glass and ceramic
Detects and reports on tool breakage, missing tools, overload, tool wear and fluid flow in real time
Collects thousands of data samples within milliseconds
Automated system processes castable metallographic samples for specialty material manufacturers
3D scans help Chicago Jet Group retrofit old Dassault Falcon avionics system
Lloyd Instruments launches the LS5 high-speed universal testing machine
More News
Mahr Inc.
Metrology
Mahr Introduces the Precimar SM 60 Length Measurement System
Provides fast and precise external measurements on manufactured parts
Published: Tuesday, September 10, 2019 - 12:00
(Mahr Inc.: Providence, RI) -- Mahr Inc., a leading provider of dimensional metrology solutions, has introduced the Precimar SM 60, an easy-to-use length measurement instrument for fast and precise external measurements on shop floor parts, with a measuring range of 60 mm.
The SM 60 is configurable with Mahr readouts, such as digital indicators or linear variable differential transformer (LVDT) probes, to provide a system tailored to the performance level required for the measurement application. The SM 60 incorporates a 25 mm sensitive contact and a fixed reference jaw with a 35 mm adjustment to obtain the full 60 mm measurement capacity.
The robust construction of the SM 60 demonstrates its design for use in the production environment—right at the point of manufacture of precision parts. “This system fills the demand for high-performance gauging at the point of manufacture,” says George Schuetz, director of precision gages at Mahr. “It allows a machinist to easily set up and adapt for new workpieces, while allowing the system to act as either a long-range measuring system or as a very high-performance comparator for sub-micron applications.”
The user is provided the ability to select the best readout for level of performance and application of the measurement. Should versatility be the driving factor, a 25 mm MarCator 1086 or 1087 may be the indicator of choice with its large display or analog type dial. Having this range allows for measuring a wide range of size parts without having to adjust the system. If higher resolution and performance are required, a Millimar P2004 LVDT with ±2 mm range and C1200 bench amplifier are able to provide sub-micron performance at the machining process.
The optional measuring instrument, whether it be a long-range digital indicator or high-performance, short-range transducer, is always protected from over-range damage by the integrated coupling.
Hardened contact surfaces on both the sensitive and reference contacts ensure long life, even after measuring high volumes of part dimensions. For increased versatility, a family of measuring attachments for the standard contacts is available. These include contacts with radius surfaces, flat-edge contacts, and flat contacts with various diameters, allowing for plain outside diameter (OD) checks for adding gage pin wires, OD thread checking, and a threaded contact set for adding any of Mahr’s standard M 2,5 threaded contacts.
For easy part positioning, an easy-to-adjust support table is positioned up or down for proper part location and then locked into place. Retraction of the sensitive contact is accomplished with a simple retraction lever that is easy to use by right- or left-handed users. Additionally, if simple shaft OD’s are a requirement, a floating micro-center support option is available to mount shafts up to 160 mm within the measuring contacts of the Precimar SM 60.
Mahr Inc.’s picture
Mahr Inc.
Mahr Inc. a member of the Mahr Group, manufactures and markets a complete range of dimensional measurement solutions from handheld and custom-made gauges to technically advanced measurement systems for form, contour, surface finish and length for the automotive, aerospace, medical products, electrical, plastics, and optical engineering industries. Mahr also provides calibration and contract measurement services. Mahr's calibration laboratories are accredited to ISO/IEC 17025:2005, NVLAP Lab Code 200605-0. Mahr Group is headquartered in Göttingen, Germany. Mahr Inc. is headquartered in Providence, Rhode Island.
