Featured Product
Metrology Features
Accurate Pattern is able to reduce customer nonconformances by inspecting patterns in-house
Optical Gaging Products OGP
OGP Starlight 150 vision system helps watchmaker measure small, complex watch parts without operator interpretation
John Toon
Detailed 3D data could help improve reliability and performance
Mark Esser
Much of its early work is baked into the U.S. economy, but NIST continues advancing measurement science
Zetec
This nondestructive technology lends itself to leaner, faster testing
More Features
Metrology News
OE720 optical emission spectrometer covers entire spectrum of elements in metal except for gases like oxygen and hydrogen
Digital solution combines real-time, remote insight with continuous monitoring and advanced data analytics
Online software for collecting measurements, visual-defect information, and pass/fail situations
Use X-Rite spectrophotometers to render digital material file for 3D design, production, and quality control teams
Simplifies workflows and enhances ease of use for manufacturing, assembly, and construction
IDS cameras help inspect up to 120 vials per minute for dimensional accuracy or surface condition
Marposs can now offer complete range of solutions for functional testing and end-of-line testing of any type of electric motor
Enables professionals and small businesses to improve product development, shorten time to market, reduce development costs
Inspect nozzle welds using phased array ultrasound testing techniques including ray-tracing, scanner simulation, coverage maps
More News
Metrology
Mahr Introduces the MarForm MMQ 500 Form Tester
Designed for precise measurement of form, featuring new levels of flexibility and speed
Published: Monday, March 1, 2021 - 13:00
(Mahr: Providence, RI) -- Mahr, a global manufacturer of precision measurement equipment used for dimensional metrology, introduces its MarForm MMQ 500, which extends Mahr’s benchtop form-tester portfolio with new levels of speed and flexibility. The MMQ 500 features optimized machine design and construction for the highest stability, precision, and speed. Powerful software enables both setup and measurement to be automated and extremely fast.
The MarForm MMQ 500 is designed for speed. Its Z-axis vertical column allows movements with up to 100 mm/s—more than three times faster than conventional form measuring devices—for minimized cycle times. The newly developed automatic CNC centering and tilting table is a key factor in speeding up the total cycle time as it enables faster alignment than comparable models, thus increasing efficiency and productivity up to 75-percent faster than the market standard. This new centering and tilting table also features a high load-bearing capacity to enable the measurement of heavy workpieces, up to a mass of 80 kg (176 lb).
Another important benefit of the MMQ 500 is the elimination of the need for an air supply by the use of a high-precision mechanical bearing for the rotary table. Mahr has been a leading producer of high-precision bearings for more than 75 years, and the mechanical bearing used in the MMQ 500 is more accurate than most air bearings and up to 70 times stiffer, making the system less susceptible to external forces such as vibration.
The MMQ 500 is also versatile and made to be a master multitasker. The system can measure surface roughness according to applicable standards in the same setup as the form measurements. There is also the option to measure lead, or the fine thread-like microstructure, which may be present on shafts produced by typical turning and grinding methods.
“Getting high-precision, reliable results as quickly as possible is key to support the production processes of today’s challenging manufacturing environments, and the MMQ 500 was designed with exactly this goal in mind,” says Pat Nugent, vice president of product management for Mahr.
Additional benefits of the MarForm MMQ 500 include:
• Measures form, position, roughness, contour, and lead in one setup
• Intuitive, easy-to-use software
• Highest axis accuracy
• Best repeatability, including for difficult measuring tasks
• Shortest floor-to-floor time on the market
• Universally applicable for everything from small workpieces of a few millimeters to heavy workpieces up to 80 kg (176 lb)
The MarForm MMQ 500 is available now. Click here to learn more.
About Mahr
When customers are faced with a metrology need, they turn to Mahr, for unmatched industry expertise. Mahr’s knowledgeable, experienced team has made the company a leader in precision measurement for more than a century.
Mahr, a member of the Mahr Group, has been providing dimensional measurement solutions to fit customer application needs for more than 160 years. The company manufactures and markets a wide variety of dimensional metrology equipment, from simple and easy-to-use handheld gages to technically advanced measurement systems for form, contour, surface finish and length. Mahr is also well known as a producer of custom-designed gages and a provider of calibration and contract measurement services. Mahr’s calibration laboratories are accredited to ISO/IEC 17025:2005 NVLAP Lab Code 200605-0 (see our Scope of Accreditation for accredited calibration processes). For more information, visit www.mahr.com.
Quality Digest’s picture
For 39 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
