Featured Product
Metrology Features
Walter Nowocin
Software as a service can help reduce costs and provide a more robust platform
NIST
NIST improves the ability of optical microscopes to measure the volume of microdroplets
Tim Mouw
It might be time to establish digital standards, document processes, and service measurement devices
Dan Hamilton
Identify trace elements and alloys, analyze precious metals, and determine coating weight and plating thickness
Geert Elie
Should you use water or CO2?
More Features
Metrology News
Measures ultra-high temp oils in heating and cooling circuit systems
University acquires the Invizo 6000 atom probe tomography (APT) instrument
Jan. 27, 2022, at 9 a.m. Pacific; Feb. 24, 2022, at 8 a.m. Pacific
Blue light scanners utilize optical noncontact technology to quickly capture millions of accurate points in a single scan
Available in 50 mm and 80 mm FOV, they offer the power, speed, efficiency of digital imaging in a compact package
Detect macro-geometry (nicks, runout) and micro-geometry (gear-mesh excitation, ghost orders) defects
Features low price-for-performance ratio, excellent in-run bias stability, zero cross-coupling by design, and Allan variances from 5 µg
Solutions provider to the world’s leading manufacturers says open data and collaboration is key to industrializing additive manufacturing
High image quality with low doses at fast scanning speeds for enhanced patient safety and experience
More News
Metrology
Mahr Introduces the New Marameter 844 K Inside Diameter Measuring Probes
Make comparative measurements of very small bores ranging from 1 mm to 20 mm
Published: Wednesday, November 17, 2021 - 12:00
(Mahr Inc: Providence, RI) -- Mahr Inc., a global manufacturer of precision measurement equipment used for dimensional metrology, is launching a new, updated version of its Marameter 844 K family of inside diameter measuring probes. This system is used to make comparative measurements of very small bores ranging from 1 mm to 20 mm. When multiple diameters are measured in the bore, the probes can identify form errors such as ovality and taper.
Mahr has invested in a meticulous overhaul of the tried-and-true Marameter 844 K variable plug measuring system, developing new materials, processes, and options to ensure maximum performance, linearity, and accuracy. Because of their constant measuring force to sensitive contacts, the 844 K plugs are self-centering and reduce operator influence. Diameters are determined by zeroing the plug gage with a setting master and then measuring the bore by sweeping the plug through it. The reversal point, or minimum value recorded, provides the bore diameter. Despite the new design and improvement, the new probes and accessories are compatible and interchangeable with the previous generation of Marameter 844 K probes and accessories.
The new Marameter 844 K probes form a comprehensive modular system that includes measuring heads, driving needles, measuring holders for indicators or probes, depth extensions, right-angle attachments and setting rings. Made of hardened steel, the new Marameter probes are ideal for bore measurement at the point of manufacture, offering extremely long life. The Marameter 844 K probes are available in three versions as determined by the application needs.
These include:
• Marameter 844 K—for through-bore applications; with hard chrome-plated measuring surfaces
• Marameter 844 KC—for through-bore applications; with diamond-like carbon (DLC) coated measuring surfaces and inner edges. DLC offers increased corrosion resistance, wear protection, and low friction for sensitive or abrasive surfaces, such as nonferrous metals and aluminum alloys. Its unique color helps to identify these long-wear probes.
• Marameter 844 KS—for blind bore applications; hard chrome-plated measuring surfaces
All 844 K probe measuring surfaces are polished, creating a very low friction coefficient and preventing marring or scratching of precision-machined and sensitive bore surfaces. This helps to prevent potential damage to finished products. Mahr’s 844 KC, with its DLC coating, offers long life even in the highest production run environments. However, should the plug eventually start to wear, the unique dark color of the DLC offers a visual indicator of wear on the measuring surface.
“The Marameter 844 K system of inside measuring probes is versatile enough to be used in a variety of applications, in an inspection room or at the point of manufacture and are designed to improve accuracy, reduce wear and waste,” says George Schuetz, director of precision gages at Mahr. “The redesigned and upgraded Marameter 844 K measuring systems offer longer life and improved performance to this line of plugs that our customers already trust.”
For an image, click here.
About Mahr Inc.
When customers are faced with a metrology need, they turn to Mahr Inc., for unmatched industry expertise. Mahr Inc.’s knowledgeable, experienced team has made the company a leader in precision measurement for more than a century.
Mahr Inc., a member of the Mahr Group, has been providing dimensional measurement solutions to fit customer application needs for more than 160 years. The company manufactures and markets a wide variety of dimensional metrology equipment, from simple and easy-to-use handheld gages to technically advanced measurement systems for form, contour, surface finish, and length. Mahr Inc. is also well-known as a producer of custom-designed gages and a provider of calibration and contract measurement services. Mahr Inc.’s calibration laboratories are accredited to ISO/IEC 17025:2005, NVLAP Lab Code 200605-0 (see our scope of accreditation for accredited calibration processes). For more information, visit www.mahr.com.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
