Featured Product
Metrology Features
Fred Miller
University of Arkansas Division of Agriculture leads USDA-NIFA research partnership
Daniel Croft
Noncontact scanning for safer, faster, more accurate, and cost-effective inspections
National Physical Laboratory
Using Raman spectroscopy for graphene and related 2D materials
Keith Irwin
Pros and cons of X-ray and CT techniques
Peter Büscher
Best practices for fluid sampling in cleanliness analysis
More Features
Metrology News
Allows end-users to bring 3D measurement close to the production line
Strengthens data analysis and AI capability
Makes it easy to perform all process steps, from sample observation to data analysis
General, state-specific, and courses with special requirements available
New features revolutionize metrology and inspection processes with nondimensional AI inspection
Engineering and computer science students receive new lab and learning opportunity
Supports robots from 14 leading manufacturers
Ultrasonic flaw detector now has B/C scan capability, improved connectivity, and an app to aid inspection
Tapping tooz for AR/VR competence center
More News
Metrology
In-Line Testing Solutions for EV Lithium Battery Production
Designed to help avoid scrap and rework, improve quality, and save money
Published: Monday, January 31, 2022 - 12:59
(Marposs: Auburn Hills, MI) -- Marposs, with more than 60 years’ experience in developing solutions for quality control during the production process, has announced its solutions for monitoring the roll-to-roll (R2R) production process of electrode foils (cathode and anode) used in lithium-ion batteries (LIB) critical to the electric vehicle industry. These solutions incorporate several of Marposs’ noncontact measurement and inspection technologies to provide fast, high-resolution film thickness and width gauging across the electrode production process, helping to avoid scrap and rework to improve quality and save money.
Confocal measurement during electrode coating and calendaring
For electrode formation, copper or aluminum foil and slurry are mixed with a solvent and coated roll-to-roll on the metal substrate as a liquid film. During the drying process, it’s critical to control the homogeneity and uniformity of the coated electrode. Once dried, the films go through a calendaring process where the electrode coil is passed through a roll press to decrease the film thickness and the porosity to increase energy density and flatten its surface. If compressed too much, the electrode porosity could be reduced to a level where the electrolyte can’t penetrate in its structure, so deviations in the electrode thickness must be carefully controlled.
Marposs’ STIL Chromatic Confocal technology enables high-frequency sampling by providing geometrical measurement and inspection during these critical process steps to measure and identify any film width or thickness aberrations. Confocal uses white light and reflected optical beams from surfaces of the object being measured, which are sent to a spectrometer for electronic processing to determine the thickness values of the web.
Laser micrometer inspection during electrode slitting
After film production, the electrode mother roll is split into smaller daughter rolls using ceramic blades. Geometric measurement is required to identify the wrong position of the blade or the electrode being slit. Marposs’ AEROEL laser scanners can be used to provide quick, accurate, and efficient measurement of the daughter roll width during this R2R process. These laser gauges feature patented technologies that make them accurate and reliable because they are impervious to variations in temperature, vibration, product movement, dust, and other environmental conditions that would normally influence measurement results.
In-line machine vision inspection during electrode notching
To produce the pouch cell requires separating the anode, cathode, and separator sheets from the roll material. This process, also known as notching, is usually performed with a shear cut (punching tool) or laser cut in a continuous process. Marposs’ patent-pending in-line machine vision system identifies the existence of burrs, folds, and delamination of the electrode profile during this process. This system uses a high-resolution linear camera that frames the edge of the electrode to acquire a series of digital images, which are analyzed to check for the possible presence of metal burrs. The system also includes a matrix camera, which detects a change in distance between the edge of the electrode and the linear camera.
Complete information about measurement, inspection, and test solutions for R2R can be found at here or by contacting Marposs Corp. by phone at (248) 370–0404 or by emailing marposs@us.marposs.com.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
