Featured Product
Metrology Features
Eric Whitley
Robotic efficiency coupled with human intuition yields a fast, accurate, adaptable manufacturing system
InnovMetric Software
One software capable of operating portable metrology equipment and CMMs within the same user interface
Vivian Lam
Four essential reads on how scientists bring the microscopic world into plain sight
Chandrakant Isi
Experts in design and manufacturing describe the role of augmented and virtual reality
Jennifer Chu
Findings point to faster way to find bacteria in food, water, and clinical samples
More Features
Metrology News
Enables scanning electron microscopes to perform in situ Raman spectroscopy
Certified for use in Class 1, Zone 0, Zone 1, and Zone 2 locations
Smart-manufacturing data platform collects, presents, and initiates accurate process and metrology data
Supports back-end process control
Quantum nanometrology just got a step closer
Produces clearer images of samples of any shape in which dense areas mask less dense areas
For processed, frozen, and preprocessed vegetables, confections, and more
Three new single-column models with capacities of 0.5 kN, 1 kN, and 2.5 kN
At Pack Expo Las Vegas, Las Vegas Convention Center, Sept. 11–13, 2023
More News
NIST
Metrology
Laser Frequency Comb on a Chip
NIST’s compact laser frequency comb could go places
Published: Monday, October 31, 2011 - 11:54
During the past decade, laser frequency combs—extraordinarily precise tools for measuring frequencies (or colors) of light—have helped propel advances in timekeeping, trace-gas detection, and related physics research.
Although typical lasers operate at only a single or handful of frequencies, laser frequency combs operate simultaneously at many frequencies, approaching a million for some combs. These combs have very fine, evenly spaced “teeth,” each a specific frequency, which can be used like hash marks on a ruler to measure the light emitted by lasers, atoms, stars, or other objects. But frequency combs are usually bulky, yet delicate, lab instruments—about the size of a typical suitcase—and challenging to operate, which limits their use.
https://lh4.googleusercontent.com/XhQEkeSoBgaDdpfeibsD_lhcTRdQy7994qTcPLAhAYaWvDeL87QulJkRzDmBoPxDvWDLWHJtHPfqEz0CJtrbHuZIOpsGswB8OgqDSFyjqkOSqNJxJas
Stack of quartz optical “cavities” for use in NIST’s compact laser frequency comb.  A low-power, infrared laser produces light that travels in a loop inside one of the cavities (only one is actually used.). Each cavity is 2 mm wide and shaped like a flat ellipse. (Credit: S. Papp/NIST.) View high-resolution image
Now, researchers at the National Institute of Standards and Technology (NIST) have developed a compact laser frequency comb, a step toward user-friendly and ultimately chip-based combs that could enable new applications in astronomical searches for Earth-like planets, high-capacity telecommunications, and—if other components are miniaturized as well—portable versions of the most advanced atomic clocks. Large-frequency combs are best known as the “gears” in today’s room-sized versions of these clocks.
NIST’s prototype micro-comb consists of a low-power semiconductor laser about the size of a shoebox and a high-quality optical cavity just 2 mm wide. A miniature laser like those in DVD players might be substituted in the future to squeeze the whole comb apparatus onto a microchip.
Compact frequency combs have been developed recently by a number of other research groups, but NIST’s is the first to use a cavity made of fused silica, or quartz, the most common optical material. This means it could be integrated easily with other optical and photonic components, NIST researcher Scott Papp says.
A full-size frequency comb uses a high-power, ultrafast laser (see background on “Optical Frequency Combs”). By contrast, the new compact version relies on a low-power laser and the cavity’s unusual properties. The cavity is designed to limit light dispersion and confine the light in a small space to enhance intensity and optical interactions. The infrared laser light travels in a loop inside the cavity, generating a train of very short pulses and a spectrum of additional shades of infrared light. The small cavity, with no moving parts, offers insight into basic processes of frequency combs, which are difficult to observe in large versions.
Among its desirable features, NIST’s compact comb has wide spacing between the teeth—10 to 100 times wider than that found in typical larger combs. This spacing allows scientists to more easily measure and manipulate the teeth. Of particular interest to project leader, Scott Diddams, the widely spaced teeth can be individually read by astronomical instruments. Portable frequency combs can thus be used as ultrastable frequency references in the search for Earth-like planets orbiting distant stars, as reported in the University of Colorado-Boulder news release “Nobel Prize-Winning Science From Boulder Serves as Springboard for Planet Hunting.”
Portable frequency combs can also have many other important applications. For example, because a frequency comb can simultaneously generate hundreds of telecommunication channels from a single low-power source, a micro-comb might eventually replace individual lasers now used for each channel in fiber-optic telecommunications.
“We hope this is just the beginning and look forward to bigger and better developments,” says Diddams. “In the short term we want to learn if this new type of comb can one day replace ultrafast, laser-based combs used with NIST’s best atomic clocks. And if not, its small size will likely lead to other opportunities.”
The research was supported in part by the Defense Advanced Research Projects Agency.
NIST’s picture
NIST
Founded in 1901, the National Institute of Standards and Technology (NIST) is a nonregulatory federal agency within the U.S. Department of Commerce. Headquartered in Gaithersburg, Maryland, NIST’s mission is to promote U.S. innovation and industrial competitiveness by advancing measurement science, standards, and technology in ways that enhance economic security and improve our quality of life.
