Featured Product
Metrology Features
Aaron Heinrich
An optimal process requires an innovative control algorithm
Harish Jose
Using OC curves to generate reliability/confidence values
Scott Knoche
Choosing the best, most appropriate add-ons makes your work faster and easier
Adam Zewe
Key component for portable mass spectrometers
Peter Büscher
Identify contaminated areas and take steps to optimize them
More Features
Metrology News
Reliable, remote visual inspections and diagnostics in hard-to-reach areas
Ideal for dusty manufacturing environments, explosive atmospheres
Optimized for cured tire runout and bulge measurement
With coupling capacitor approach that eliminates the need for an external sensor
Improving quality control of PCBAs and optimizing X-ray inspection
10-year technology partnership includes sponsorship of quality control lab
MM series features improved functionality and usability
Features improved accuracy, resolution, versatility, and efficiency
More News
NIST
Metrology
Knowing When Poultry Goes Foul
New method of sampling the air above the food
Published: Thursday, April 15, 2010 - 10:06
Researcher, Tara Lovestead, prepares a sample of meat (by excising a few milligrams) for testing with a new sampling method developed by Lovestead and NIST research chemist, Tom Bruno, that can detect trace amounts of low volatility compounds produced when perishable foods such as chicken begin to spoil.
(NIST: Gaithersburg, MD) -- Mom’s trusty nose may be good, but researchers at the National Institute of Standards and Technology (NIST) have gone her one better by designing an instrument that quickly and precisely sniffs trace amounts of chemical compounds that indicate poultry spoilage without damaging the product itself.
The process can detect minute amounts of spoilage compounds and can be used by suppliers during all stages of processing, transport, and storage.
Several proactive measures are used in the United States to keep poultry from going bad between the time it leaves the farm to when it reaches your grocery cart. Antibiotics and other chemical additives are commonly used to keep the product from spoiling, but without invasive and time-consuming tests, it’s hard to determine if the spoilage process has begun or not.
For several years, detection of volatile organic compounds created when lipids or proteins decompose has been used to test for spoilage. The technique developed by NIST research chemist Tom Bruno and Tara Lovestead relies on identifying trace amounts of low volatility compounds that are present early in the decay process, but are much more difficult to detect.
Analyzing such low-volatility compounds used to require impractical, long collection times to get a sample big enough for testing and identification.
The key to detecting minute levels of the low volatility compounds produced when chicken spoils is a new method of sampling the “headspace” —the air above a test sample. Bruno devised a technique using a short alumina-coated tube cooled to very low temperatures to promote the adsorption of low-volatility chemicals, a technique called cryoadsorption. Among other advantages, Bruno’s sampling method is robust and flexible in terms of where and how it can be used, an important feature for the food industry.
Bruno and Lovestead separated and identified six potential chemical markers that could be used to indicate poultry spoilage before it becomes unhealthy. Those markers were found in the air above spoiled chicken breasts, maintained in their original retail packaging and kept at room temperature for two weeks.
Considering that Americans annually consume an average of nearly 84 pounds of chicken per person (according to 2008 USDA statistics, the most recent year available), this improved testing method for spoilage could significantly reduce the cases of food poisoning.
NIST’s picture
NIST
Founded in 1901, the National Institute of Standards and Technology (NIST) is a nonregulatory federal agency within the U.S. Department of Commerce. Headquartered in Gaithersburg, Maryland, NIST’s mission is to promote U.S. innovation and industrial competitiveness by advancing measurement science, standards, and technology in ways that enhance economic security and improve our quality of life.
