Featured Product
Metrology Features
MIT News
They can quickly learn to optimize building microclimates for both energy consumption and user preference
Loretta Marie Perera
3D scanning and printing an impossible-to-find, 100-year-old distributor cap
NVision Inc.
Laser scans of large and small surfaces performed in just three days
Douglas Allen
Removing the random noise component from the observation, leaving the signal component
Lawrence Livermore National Laboratory
Liquid metal jetting is highly stable and repeatable, but extremely challenging to model
More Features
Metrology News
An advanced wireless data collection system for acquiring precision measurement data
All of the manufacturer’s X-ray sources are supported including rotating target technology and 450kV microfocus source
Ideal for measuring large components or multiple small components, quickly, easily, and accurately
Measure workpieces from 25 mm to 42.5 mm with a measuring range of ±100 µm and a repeatability of ≤0.1 µm
Contactless gauging system for measuring steel wire for tires, copper wire for electrical cables, CO2 welding wire, and more
Resolve CMM productivity issues with MetraSCAN-R BLACK|Elite, CUBE-R 3D, and digital twin environment software
Videos address common topics related to surface specification, measurement, and interpretation, in five minutes or less
Scan 99% of parts without touching the scanner exposure
More News
Helmel Engineering
Metrology
Helmel Introduces High-Performance CMM Specifically for 5-Axis PH20 Probe
High-speed Microstar platform takes advantage of infinite positioning and autonomous measuring of the Renishaw system
Published: Wednesday, December 4, 2019 - 12:00
(Helmel Engineering: Niagara Falls, NY) -- Helmel Engineering, a 46-year-old American manufacturer of coordinate measuring machines (CMM), has introduced a new CMM developed to take advantage of the capabilities of Renishaw’s PH20 Probe concept. The Microstar Model 320-185 is an evolution of the company’s venerable Microstar line of durable mechanical bearing CMMs that are proven workhorses in labs, gauge rooms, and on the production floor.
Virtually all moving-bridge CMMs today were developed for slower probe systems that index between limited numbers of locked A-B position angles then measure with 3-axis moves. In contrast, the Renishaw PH20 Probe system with UCCT5 Controller provides true 5-axis functionality with infinite positions throughout the 230° × 360° head range in combination with the X-, Y-, and Z-axis motion of the CMM. The PH20 also includes “head-tap” mode where the probe rapidly acquires data autonomously while the CMM remains stationary.
The new design includes several advances. For improved accuracy, the Z-axis has a larger section for stiffness and stronger bearing separation, and the X-axis carriage employs an innovative dual bearing flexure stabilizer concept combined with new self-aligning mounts for linear bearings. Scales are upgraded to Vionic long-life stainless steel tapes mounted on steel surfaces with 50-nanometer resolution reading heads. Error correction is implemented at the controller, and temperature compensation is offered. These improvements make the 320-185 among the most accurate mechanical bearing CMMs available.
The drive system has been improved as well. The steel and Kevlar reinforced drive belts are larger, and the tach motors are stronger on all three axes allowing much more aggressive motion parameters. The result is a CMM system that can outperform most any other with throughput double to triple measuring speeds of traditional CMMs with indexing probes. Due to the rapid capabilities of this system, the company expects plenty of interest for in-production applications. Added protection for harsh environments is also available.
Initially offered with a measuring range of 20 in. × 30 in. × 18 in., the system includes CMM Manager CAD software as standard. Renishaw’s MODUS software is an option. The system also includes a TCR20 six-port automatic stylus changer.
“To watch how the PH20 probe can fly, it seemed foolish not to have a CMM that rises to that same level of performance to go with it,” says Erwin Helmel, president of Helmel Engineering. “The 320 is our answer. It’s like getting two CMMs for the price of one.”
For more information on the CMM PH20 Probe Kit click here.
Helmel Engineering Products Inc. is a manufacturer of coordinate measuring machines and systems built in the USA.
Helmel Engineering’s picture
Helmel Engineering
