Our landlords thank you.
Exact Metrology
Published: Friday, June 29, 2012 - 16:31 (Exact Metrology: Cincinnati) -- For years, engineers have anticipated the day when a full-color 3-D scanner can be picked up, plugged into a laptop computer, and ready to use. The Eva 3D Scanner from Artec now offers this. Because Eva eliminates any need for marking or calibration, you’ve got a lightweight, portable 3-D scanning solution in the palm of your hand that can capture high-quality data in real time, at up to 16 frames every second or 300,000 points of data. This kind of instantaneous frame alignment has exciting applications for industries such as: Beyond its remarkable speed and accuracy, the Artec scanner can capture motion in 3-D. The part and scanner move simultaneously, so there’s no need to position it on one stationary place to get exceptional motion capture. With its ergonomic design and available battery, Eva can be operated in a variety of remote environments. Eva doesn’t even view the world in the same way as a traditional 3-D scanner does. While a traditional 3-D device will scan an image as separate slices and then reassemble the object, Artec’s Eva model will project a calibrated grid onto the object. As the grid’s squares bend, a camera simultaneously captures 200,000 color pixels every fifteenth of a second. Consequently, Eva can pick up on the slightest of distortions to capture subtle changes in shape, shading, texture, and depth, such as a wrinkle in an article of clothing or an object that’s affected by different light sources. Artec has delivered a scanner that Exact Metrology is already using on a variety of 3-D projects to fully factor in all the elements of the object’s environment. It also allows full editing and data exporting. • Only 850 g (1.9 lb) For more information on Eva or the complete line of Artec 3D Scanners, visit www.exact3Dscanner.com. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Exact Metrology is a full-service measurement services company that provides on-site inspection, reverse engineering, noncontact laser scanning, and 2-D/3-D digitizing services as well as contract programming, software training, part programming, and measurement equipment implementation. Exact Metrology also sells, services, and implements metrology equipment solutions from companies including Artec, ROMER, Leica Geosystems, Breuckmann, Metronor, Surphaser and InnovMetric. Eva 3D Scanner Captures Subtle Changes in Object
Scans 288,00 data points per second without markers, EM tracking, or calibration
• Reverse engineering
• Design
• Heritage preservation
• Medical and biomechanical researchHow else is Eva evolving 3-D?
Eva by the numbers
• Captures 288,00 data points per second
• Frame rate of up to 16 frames per second
• Zero markers, EM tracking, or calibration
• Color information capture at 24 bits per pixel
• Resolution of 1.3 megapixels
• A working distance of 0.4–1 m
• Furthest range of 536 mm × 371 mm
Quality Digest Discuss
Exact Metrology
