Featured Product
Metrology Features
Matthew Staymates
Visual proof supports the ‘Cover smart, do your part, slow the spread’ slogan
NIST
For more accurate time, navigation, communication, and higher-resolution imaging for radar and astronomy
John Smits
These close cousins in the metrology field have distinct specialties
PPE counterfeits endanger lives. Testing ensures real PPE does its job.
NIST
New method for rapidly providing highly calibrated standards
More Features
Metrology News
Lloyd Instruments launches the LS5 high-speed universal testing machine
Measure diameter, ovality of wire samples, optical fibers and magnet wire, including transparent products
Training, tips and tricks, unboxing, and product videos provide additional information for users
Laser scanning also used to help create safety covers for credit card readers
A complimentary webinar for novices to experts on May 27-28, 2020
MetLogix Mx200 DRO is fully featured and easy to use
Automatically controls the die match in form or thread rolling if the dies are not aligned
A versatile FOD solution and effective backup for standard scopes
More News
Digital Metrology
Metrology
Digital Metrology Releases Multi-Band Surface Texture Analysis Software
Instantly separates surface texture into wavelength bands, displays data in highly intuitive, single-screen interface
Published: Wednesday, August 7, 2019 - 12:00
(Digital Metrology Solutions: Columbus, IN) -- Digital Metrology Solutions, provider of measurement software, consulting and training, has released two new products for multi-band surface texture analysis. Bandify and Bandify3D instantly separate surface texture into wavelength bands and display the data in a highly intuitive, single-screen interface.
“To produce surface finishes that both look good and perform well, you need to understand the spatial wavelengths within the surface texture,” explained Dr. Mark Malburg, President of Digital Metrology Solutions. “A roughness number alone can’t tell you whether a paint coat will appear glossy, if a gasket will seal, or if a gear will make noise. Understanding the impact of various wavelength domains leads to a better understanding of these complex functions.”
Bandify is the first software tool designed exclusively to analyze surface texture simultaneously over several user-defined wavelength bands. The software reports wavelength-specific surface parameters, with user-defined tolerance bands to highlight out-of-spec conditions.
Bandify can analyze data from a wide variety of surface measurement instruments, making it a powerful, common platform for all measuring systems. A selection of stylus-based profiling instruments can even be controlled directly from Bandify for “one click” measurement and analysis.
Bandify software shows a cross-section of the surface texture finish (top), and the texture divided into five user-configurable wavelength bands (right). Clicking any band displays that band in the center of the screen, along with surface texture parameters and a graph of the wavelength content.
Bandify3D provides similar information for three-dimensional surface measurement data, also in a single-screen user interface.
Bandify3D image showing the 3D surface texture (left) and short-wavelength texture (center). By focusing on this wavelength, striations across the data from a prior machining process are made apparent. The software makes it possible to analyze whether such aspects of the surface texture will affect the appearance and performance of a surface finish.
Because every application has unique requirements, the wavelength bands are fully customizable in Bandify and Bandify3D, with user-configurable cutoff wavelengths, display parameters and pass/fail limits. All settings can be saved as measurement “recipes” for various types of parts and/or process stages.
Both software packages feature drag-and-drop interfaces that let users analyze data in most standard formats, while batch process enables rapid analysis of hundreds of measurements at a time.
“The most important aspect of Bandify and Bandify3D is that the software lets engineers explore and interact with data,” continued Dr. Malburg. “Many other software packages can analyze surface texture in a general sense, but Bandify makes it exceptionally easy, and extremely fast, to see and understand textures in a wavelength-by-wavelength manner. More importantly, the software can clearly show the relationship between the wavelength domains. It provides the data to describe, specify, track and control the aspects of surface texture that will ultimately yield an excellent finish.”
More information on Bandify, Bandify3D and Digital Metrology Solutions is available at www.digitalmetrology.com.
Digital Metrology’s picture
Digital Metrology
Digital Metrology develops general use and custom measurement software for exploring and understanding data. Rather than just reporting numbers, our software’s easy-to-learn tools let you interact with measurement data, interpret it, and use it to improve processes and products. We also develop custom measurement systems that generate “information” rather than simply reporting “data.” We accomplish this by first gaining a thorough understanding of our clients’ measurement needs, then developing systems that express the required information in the clearest, most reliable format.
