Featured Product
Metrology Features
Catherine Cooksey
Ensuring that measurements aid the broader industrial and scientific communities that depend on them
MIT News
They can quickly learn to optimize building microclimates for both energy consumption and user preference
Loretta Marie Perera
3D scanning and printing an impossible-to-find, 100-year-old distributor cap
NVision Inc.
Laser scans of large and small surfaces performed in just three days
Douglas Allen
Removing the random noise component from the observation, leaving the signal component
More Features
Metrology News
Designed for precise measurement of form, featuring new levels of flexibility and speed
Single- and three-axis shop-floor dimensional measuring machines for industrial manufacturers
Precision optical instrument helps ventilator maker increase specialty valve production in response to shortage
Allows team to focus on quality control in dimensional measurements and overall machining process
Contactless sensors measure rotating shafts in industrial benchtop and test and measurement applications
3DCS Design Variation Analyst, 3DCS Viewer, and 3DCS Mechanical Variation Modeler create a scalable solution to tolerance analysis and simulation
Operators can monitor full process, including cooling cycle, which can be altered to change the microstructure of parts to suit needs
Infrared cameras, structured light scanning, and electron imaging provide extensive and detailed data on every part
More News
BEA Lasers
Metrology
BEA Lasers Expands MIL Series With New Laser Alignment Modules
MIL RA Alignment Modules feature low profile 3/8 in. rugged laser housing with a M12 connector
Published: Tuesday, January 2, 2018 - 12:00
(BEA Lasers: Elk Grove Village, IL) -- BEA Lasers, a manufacturer of rugged laser modules and assemblies, introduces two new additions to their MIL Series of Laser Diode Modules for alignment applications.
Both new MIL RA Alignment Modules feature a low profile 3/8 in. rugged laser housing, fitted with a M12 connector. A PVC jacketed cable 2 meters long, integrated power supply and optional mounting bracket complete this sturdy ready-to-use system. The optional mounting bracket is available in sensor style, or as a multiadjustable “LB” bracket. The modules can be obtained in straight or right-angle configuration.
The MIL RA Series Laser Diode System is available in standard 520 nm (green) or 635 nm (red), with 1 mW or 5 mW output. Other outputs are available upon request.
The MIL RA Series includes the industry’s first rugged right-angle alignment system. The Alignment Modules feature a 3/8 in. brass, nickel-plated laser housing. This Laser Diode Module occupies only 1.5 in. of space, allowing it to fit in tight spaces, which is a much smaller profile than other alignment lasers intended for industrial use.
The MIL RA Series Laser Modules are typically used for alignment and leveling applications. They are ideal for counting, machine vision, edge detection, paper web, riveting, and water-jet cutting alignment, to name just a few.
Stock is immediately available. Inventory is located at BEA Lasers headquarters in Elk Grove Village, Illinois, and can be shipped within 24 hours. BEA Lasers will also provide custom modifications, which take an additional four weeks lead time. Customizations include laser pattern options (e.g., lines, crosses, dot patterns), flash options, other outputs and more.
All models are FDA compliant.
For more information on BEA Lasers visit www.bealasers.com, or call (800) 783–2321. In Canada or Mexico, call (847) 238–1420.
BEA Lasers’s picture
BEA Lasers
Since 1980, BEA Lasers has provided innovative laser module solutions to industry and research, leveraging the staff’s expert knowledge of photonics and electro-optic components. BEA Lasers offers a full line of standard ruggedized laser diode modules with green and red lasers for varying applications and customer requirements. These applications are typically for alignment and leveling functions in customer operations or production. BEA Lasers also provides customization of laser modules. Many BEA Laser products conform to and surpass CE Marking standards and FDA regulations.
