Featured Product
Metrology Features
Ryan E. Day
Plasser American uses FARO laser projection and laser scanner technology to improve efficiency and increase throughput
The world affects your job, and you affect the world. Take pride in your work.
Here’s a sample of some of the stories our readers found most interesting in 2019
NVision Inc.
NVision helps create replica of Dimetrodon limbatus for further study
Ryan E. Day
Plasan chooses the FARO QuantumS ScanArm to inspect for big launches and big parts
More Features
Metrology News
Full range of Starrett force software solutions are now interchangeable with different Starrett frame series
To be held Feb. 11–13, 2020, at Anaheim Convention Center, in the Automation Technology Expo
C-THRU4.0 collects and processes data from multiple machine tools equipped with Artis machine monitoring systems
High-speed Microstar platform takes advantage of infinite positioning and autonomous measuring of the Renishaw system
Facilitates complete automation of the additive manufacturing process chain
New facility in Toronto area will showcase multiple Hexagon product lines
Engineering and design teachers will benefit from enhanced 3D scanning performance
Accurate measurement out of the box
Faster and more powerful than ever before
More News
Nextsense
Metrology
Affordable Profile Measurement Gauge for Steel Rolling, Drawing, and Processing
The profile measurement system has an accuracy of 5 µm and a measuring range of 1 mm to 50 mm diameter
Published: Wednesday, July 10, 2019 - 11:00
(NEXTSENSE: Graz, Austria) -- Continuous monitoring of rolling and drawing mill production has become a critical factor in the steel industry. To keep costs for quality control at bay measurement expert NEXTSENSE developed an affordable profile measurement system, ATON Wire, applicable for long products with round cross-section, like wires, bars and tubes.
There is a vast array of applications for the ATON Wire in your steel mill and most of them are focused on optimizing costs for you. Monitoring dimensional accuracy over the entire coil length allows you to instantaneously inspect and deal with faulty products, thus increasing your product quality standards. Checking roll and die wear will make roll and die changes plannable. Using on-line measurement reduces the time for product changes. Eliminating sample cutting will reduce waste and therefore material costs. Furthermore, full documentation of the whole production process is ensured.
The profile measurement system has an accuracy of 5 µm and a measuring range of 1 mm to 50 mm diameter. The ATON Wire comes in three different versions (Cold, Warm and Hot) depending on the temperature of the material. The maximum temperature for ATON Wire Warm is 200° C and for ATON Wire Hot it is 1,200° C. Both versions use integrated active cooling technology, which keeps the sensor cool in a well-insulated housing. ATON Wire Hot also integrates air purge to keep dust and humidity away from the measurement area. Thus, you don’t have to spend money on expensive pressurized air for air purge or additional air conditioning.
In order to achieve customer-friendly pricing, NEXTSENSE made use of established principles and technologies to develop the ATON Wire. ATON Wire includes two laser shadow measurement sensors in perpendicular orientation to measure diameter and ovality of the contour at the same time. The gauge size allows the use of ATON Wire even in the narrow space between rolling stands.
The ATON Wire is Industry 4.0 ready and can also connect to IBA process data acquisition systems. The production planning systems can remotely control ATON systems and collect measurement data summaries, both through a level 2 interface. ATON Wire always comes with a Touch Panel PC for displaying the measurement result during production, storing quality data for years and for retrieving historic data.
The device also includes excellent global service. Be it on-site training, on-site commissioning, or help with maintenance, the service team of NEXTSENSE is your trusted partner.
Quality control easily comes with high investment for measurement instruments, bringing return only in years. High quality for a reasonable price was the main driver for NEXTSENSE to develop ATON Wire. The system’s return on investment usually only takes 3 to 9 months. Mill operators will definitely benefit significantly from enhanced product quality and higher throughput in their production and increase yield.
Nextsense’s picture
Nextsense
With its unique CALIPRI principle, NEXTSENSE is a world leader in mobile profile measurement and surface inspection, especially in the fields of wear measurement of train and rail, gap and flush measurement in the automotive industry and in the measurement of hot metal profiles. Its customers include all major railway companies, numerous well-known international automobile manufacturers and major steel producers, including Deutsche Bahn, SNCF, China Railways, Daimler, JLR, Audi, BMW, voestalpine and ArcelorMittal. Since May 2018 Nextsense is part of Hexagon AB, a leading global provider of information technologies.
