Featured Product
Metrology Features
Jamie Fernandes
From design to inspection to supply chain management, AI is transforming manufacturing
NVision Inc.
Scanning plays a role in extending life span and improving design of A/C systems
Patrice Parent
Integral components of an electric vehicle’s structure are important to overall efficiency, performance
NIST
NIST scientists perfect miniaturized technique
The more you know, the easier it becomes to use your data
More Features
Metrology News
Partnership will lead to comprehensive, integrated manufacturing and surface inspection solutions
Enables better imaging in small spaces
Helping mines transform measurement of blast movement
Handles materials as thick as 0.5 in., including steel
Presentation and publication opportunities for both portable and stationary measurement leaders
Accelerates service and drives manufacturing profitability
Improved readings despite harsh field conditions
Designed to meet standards, bolster detection, and mitigate work environment hazards
Machine vision market will return to single-digit growth in 2024 following declines in 2023
More News
Tara Fortier
Metrology
Think You Know What a Second Is?
It will likely change in the next decade
Published: Monday, November 27, 2023 - 12:02
Measuring and keeping track of time has allowed people to plan and coordinate locally with others for millennia.
As the world has modernized and our pace of life has increased, our relationship to time has changed. Time has become a scarce commodity. The standardization of time has also become essential for the stability in power grids, data synchronization over the internet, global travel, and telecommunications.
In 1960, the second was defined as an international standard unit of measurement for time. Since then, the second has undergone multiple redefinitions. These redefinitions may have happened in your lifetime and you probably didn’t notice.
Prior to 1967, the official time reference for the second was the stable but slow rotation of the Earth relative to the cosmos. But Earth’s rotation can slow down and speed up based on the gravitational influence of the moon and the movement of the outer shell of the Earth. This presents a challenge for accurate timekeeping.
That’s why, after 1967, the second’s definition changed to one based on the exquisitely stable energy levels in atoms; hence, the term “atomic clock.”
As an aside, the most recent redefinition of the International System (SI) of units in 2019, more commonly referred to as the metric system, made it such that all units are defined by the unchanging laws of physics and the constants in nature. This did away with the last “artifacts” in the SI. Previously, the standard of mass, the kilogram, was based on a human-made cylinder of platinum and iridium, whose mass was defined to be one kilogram.
The first atomic clocks were developed during the 1940s and became commercially available in the 1960s. Since then, every decade has seen better than a tenfold improvement in timekeeping performance. Now, if you could wait long enough, the best atomic clocks would lose only one second every 15 billion years!
Here, I hope to explain how we define time with atoms, how we use timing in modern society, and whether better timing and a future redefinition of the second might affect our lives and modern technology.
You may have learned to count “one, 1,000” or “two, Mississippi” in school, but the way NIST defines the second with atoms is much more complex.
Prior to the Industrial Revolution, the best timekeepers were pendulum clocks, the mechanical basis for grandfather clocks. First developed in the late 1600s by Christiaan Huygens, pendulum clocks lost only 15 seconds per day.
How do clocks work?
In a grandfather clock, the pendulum swings back and forth, or oscillates, under the force of gravity. Credit: AGCuesta/Shutterstock
All clocks, including grandfather clocks, atomic clocks, and the clocks in your phone, use a periodic oscillation to define time. One second is accumulated by adding together a fixed number of periods of oscillations.
In the grandfather clock, the pendulum swings back and forth, or oscillates, under the force of gravity. If the pendulum takes 0.5 seconds to swing from left to right and back again, then one second is accumulated after the pendulum completes two periods of oscillation.
There are two qualities that make a good clock: How much its period of oscillation changes or “drifts” over time, causing errors in its definition of one second, and how well you can measure the period of oscillation.
For example, measuring one period of rotation of the Earth relative to the cosmos is very different from measuring the periodic swinging of a pendulum clock. Both of these are different from measuring the energetic oscillations of electrons in an atomic clock. Each of the latter systems requires a different system of measurement, which comes with its unique challenges and measurement errors.
Both qualities determine how much timing difference, or error, you will have between different clocks over a specified amount of time. In general, the faster the period of oscillation, or the higher the oscillation frequency, the better the resolution you have in defining one second.
This is similar to how the resolution of a television increases with the number of pixels. The more pixels you have per image, the higher the image quality. If you count every cycle, the more cycles you have per second, the better the timing resolution in a clock.
Importantly, this is just one of the reasons why the very fast oscillations in atoms yield the best definition of time.
How do clocks in laptops and cellphones work?
While physical oscillation keeps time in large grandfather clocks, which were widely used to keep precise time until the early 1900s, a more portable and higher-accuracy clock was developed to meet the more accurate timing needs of modern society.
NIST researcher Tara Fortier. Credit: R. Wilson/NIST
Currently, all portable electronics use specialized quartz crystals to keep time. If you’re looking at a grandfather clock, you can see the physical pendulum moving to keep the time. The oscillations in quartz, however, result from much faster mechanical resonances in the crystal that you can’t see.
In quartz oscillators, the forces between the atoms making up the crystal and other factors determine the tone, or frequency, of the mechanical resonance. It’s similar to a musical instrument. In a piano, for example, the material of the string and how you tension it determine the tone of the musical note. This, combined with the body of the piano, helps determine the quality of the sound.
Like the pendulum or grandfather clock, quartz oscillators in a phone define one second by accumulating many periods of oscillation of the mechanical resonance. The period of oscillation of quartz in a cellphone is 70,000 times faster than a pendulum clock. It’s also about 125 times higher in frequency than middle C on a piano.
Today, quartz oscillators only give timing errors of about one second per day. Their small size, amazing accuracy, and low cost have fueled their ubiquity in modern-day electronics. As a result, quartz oscillators have become a multibillion-dollar global market.
Atomic clocks and their applications in modern society
An unfortunate feature of all mechanical clocks, including quartz oscillators, is that they tend to drift to some extent or another. This means that a clock can slowly or quickly lose time with respect to other clocks.
A timing error of one second in 24 hours might not seem important at first thought. However, timing errors among electronic clocks that keep time across the internet can cause problems as mundane as lag times in gaming or as serious as GPS errors for planes. To operate at their highest performance, the clocks in the modern systems I just described must synchronize themselves to low-drift atomic clocks.
Fun fact: The internet time service at NIST in Boulder, Colorado, which synchronizes electronic devices to U.S. atomic time, receives 100 billion hits per day from devices all over the country. That’s 10 times more hits than the Google search engine servers receive in a day!
Keeping time with atoms
Time is defined using atoms in a remarkably similar fashion to quartz oscillators. I like to think of atoms as the world’s most exquisite and precise musical instruments! In atoms, the interplay between the forces exerted by protons, neutrons, and electrons—as well as gravitational, electric, and magnetic fields—governs the movement and energy of electrons within the atom.
The interaction of these forces dictates the atom’s internal resonances, much like string tension determines the notes of a piano. This makes the resonances, or “notes” of the atom, exquisite expressions of the laws of physics. In fact, atomic resonances are used to expand our understanding of physics. Researchers at NIST have used atomic clocks to search for dark matter particles and to see if our laws of physics are really the same across all space and time. So far, researchers haven’t observed any violations to our current laws of physics. But only time will tell (loving the pun?) what we will find as clocks continue to improve.
In some cases, how well the atom’s environment is controlled determines the quality of its resonances. For atomic clocks, we’re interested in how pure and how stable a single oscillatory resonance can be. These qualities help determine the resolution and level of error with which we can define the second.
In physics terminology, adding energy to a system so it can resonate is called an “energetic excitation.” Gravity provides the energy for a pendulum clock, and electrical signals “excite” resonances in quartz oscillators.
Electromagnetic waves, such as light or radio waves, “excite” atomic resonances. To excite or “play” the extremely pure resonance in an atomic clock requires an equally precise electromagnetic wave. The electromagnetic wave, which keeps the atomic tone resonating, can be kept in tune using a system similar to cruise control in a car.
Because atomic clocks can oscillate 250,000 times faster than quartz oscillators, it takes 250,000 times more cycles to add up to one second of elapsed time. The international unit of time, the SI second, is currently defined as 9,192,631,770 periods of a specific resonance.
This resonance uses a type of cesium (Cs) atom known as Cs-133. (There are several types or “isotopes” of cesium, depending on the number of neutrons in the nucleus; Cs-133 has 55 protons and 78 neutrons.)
If you were willing to watch a clock that would work forever, the best Cs-133 atomic clocks would accumulate a timing error of about one second in about 150 million years.
The definition of a second will change in the coming years. The good news is you’re unlikely to notice; it’ll just be more precise than before. Credit: N. Hanacek/NIST
An improved definition of the second
So, the Cs-133 atomic clock that currently defines the second is very accurate. If a timing error of about one second in about 150 million years is not good enough, clocks based on atoms with resonances at optical frequencies can be used to keep time to a one-second error in 15 billion years!
JILA’s strontium optical atomic clock was made possible by the frequency comb. Credit: The Ye group and Brad Baxley, JILA
As I mentioned previously, clocks that oscillate faster have lower timing error, or better time resolution—just as TVs with more pixels have higher resolution.
Because optical clocks are 100 times more accurate than atomic clocks based on Cs-133, the international time community is considering using optical atomic resonances to redefine the SI second. The target date for redefinition is set sometime around 2030.
The international time community hasn’t decided which kind of atom they would use or whether they might even use a combination of clocks based on several different kinds of atoms. Current optical atomic clocks being developed worldwide use at least 28 different kinds of atomic isotopes.
Implications of redefining the second
The good news is, when the definition does change you’re not likely to notice. The first reason is that, by design, the new definition of the second is supposed to be consistent with the current definition of the second. It will just be much more precise than before.
The second reason is that our current infrastructure to send timing around the globe will need significant upgrades to support the gains in timing from optical atomic clocks. Fortunately, if the upgrades are made to our satellite and optical network infrastructure, your GPS may be able to pinpoint your location even more accurately. We may also one day see improvements in advanced communications and computing.
NIST researcher Tara Fortier is interviewed about NIST’s timekeeping role. Credit: R. Jacobson/NIST
Regardless of whether and when the SI second is redefined to optical atomic clocks, the greatest beneficiaries of improvements in timekeeping and measurement will be fundamental research and science.
It’s a rare occurrence when technology takes a step forward and someone doesn’t find some way to take advantage of it.
As mentioned, the exquisitely pure resonances of atomic clocks have been used to search for dark matter particles. Additionally, these clocks can sense how gravity changes across the Earth as a function of altitude.
That’s because, according to Einstein’s theory of general relativity, time ticks more slowly in stronger gravitational fields. This effect is known as time dilation. The movie Interstellar illustrated this effect when a scientist in a spaceship waited for 23 years for his colleagues who only spent 45 minutes on a planet in the presence of a gravitationally powerful black hole. On Earth, the farther you move from its center, the lower the gravitational field you experience. Amazingly, because we can resolve time so precisely with atomic clocks, we can observe the difference in the “tick rate” for atoms offset in altitude by only one millimeter.
Fun fact: Because GPS satellites are moving fast compared to people on Earth, and experience a different gravitational field, if we didn’t correct the onboard clock’s timing for the effects of relativity, GPS would accumulate positioning errors of 10 kilometers per day, making it pretty much useless.
In 2019, you might have seen in the news that atomic clocks were used to help create the first image of light emitted by a black hole. In this experiment, images from multiple telescopes from around the globe were synchronized to create an effective light-collecting aperture the size of the diameter of the Earth. Importantly, the larger the aperture, the better you can resolve an image.
In the future, atomic clocks on space-based telescopes, separated by millions of miles, could be used to observe much fainter stars and nebulae as well as more distant galaxies than we can see today. And atomic clocks on spacecraft could navigate deeper into space because their onboard clocks won’t drift and will require less frequent calibration to clocks on Earth.
Hopefully when the second is redefined by optical atomic clocks, you won’t notice. However, the continued improvement in timing through clocks and time measurement will allow us to develop a finer and deeper understanding of nature and the universe. We’re a curious species, so scientific advancement will likely be the most important outcome.
Published Nov. 8, 2023, on NIST’s Taking Measure blog.
Tara Fortier’s picture
Tara Fortier
Tara Fortier is a NIST physicist and project leader of the Time and Frequency division. Her research group covers atomic clocks and quantum networks, and she is also on NIST’s Women in STEM executive board. She has won numerous scientific awards for innovation and research.
