Featured Product
Metrology Features
Emily Newton
With Industry 4.0 technology, businesses can enable new equipment testing, monitoring, and maintenance techniques
William A. Levinson
The analytical method allows more detailed quantification of the gage standard deviation and bias
Suneel Kumar
Leveraging the strengths of your team members
James Bossert
A review of the fundamentals of a gauge R&R study to remind us why it’s so critical
William A. Levinson
Common sense says it is beneficial to understand the capabilities and limitations of inspections for attributes
More Features
Metrology News
Creaform has optimized its fully integrated 3D software platform that powers the entire fleet of 3D scanning and measurement technologies
Measures EV rotor shafts and cylindrical components
Q&A-style guide addresses common surface texture topics
Work directly on machine tool to rapidly capture a complete picture of a part’s surface
New offering addresses cost efficiency and reliability requirements of urban security screening
Updates improve usability, speed, and accuracy of nondestructive testing, analysis, and geometry repair of parts
3k detector and 225 kV X-ray provides high-contrast, high-resolution measurements, exceptional sharpness of detail
More News
Sabine Terrasi
Metrology
Nondestructive Testing of Composite Materials
NDT imaging coupled with board-level, real-time image easily locates faults in composites
Published: Wednesday, May 12, 2021 - 12:01
In yacht and boat building, the most commonly used materials are composites. By combining the positive properties of at least two components, composites often have outstanding features—some of them even specially adapted to their respective areas of application.
It is hardly surprising that they are also used for high-performance applications in the aerospace industry, power engineering (e.g., wind turbines), medical technology, sports equipment manufacturing, and in the automotive industry.
However, wherever there are bindings, these can “break”—be it through external influences or material fatigue. Regular tests are therefore indispensable. The iX-600 portable inspection system from UNX Technologies in Taiwan provides contactless inspection of multilayer composites, even for large surfaces. It uses image processing to detect weak points that are invisible to the human eye. In addition to a thermal imaging camera, a uEye board-level camera with autofocus from IDS Imaging Development Systems is used.
Especially in maritime applications, the demand for composites is continuously increasing. In addition to floor elements, side walls, ceiling paneling, or doors, they are used in toilet compartments and separation units. Moreover, load-bearing parts such as floors, walls, or roof panels are possible and provide considerable weight savings. A classic example of a composite material used here is carbon fiber-reinforced plastic (CFRP). It has both high stiffness and light weight. Another composite is glass fiber-reinforced plastic (GFRP), a material made of plastic and fiberglass. It is cost-effective and yet high quality.
With composites, the individual components are not combined into a single material but are laminated. Therefore, damage such as bubbles, pores, foreign inclusions, and delamination (peeling off of layers) can occur due to manufacturing processes. Even during operation, i.e., while the vehicle is moving, the strength of the material can be impaired—for example, by an impact event. An impact against a composite panel can leave no visible damage on the outside, but inside there might be damage that can lead to a reduction in compressive strength.
Regular testing of the materials is therefore not only sensible but also vital for safety. Yacht manufacturers usually use the ultrasonic or impact-echo method to detect defects. This is based on the use of sound waves. It was developed during the 1980s for testing reinforced concrete components and is currently widely used. However, this process requires contact between the parts and is time-consuming.
Portable inspection system iX-600
Application
UNX Technologies offers a real alternative. The portable inspection system iX-600 enables a noncontact and therefore guaranteed nondestructive inspection (NDI) of composite materials. The equipment can test for detachment, delamination, or porosity. The material properties are analyzed beneath the surface, and thus defects in the interior of the material are detected. The system also captures large inspection areas or curved structures effortlessly, without requiring a material sample in advance.
For composite materials with multilayer structures, the iX-600 can also be used in addition to the manual sequential ultrasonic scanning described above to replace point information with area information.
With the iX-600, a fault location can be determined quickly and precisely. In addition to the infrared thermal image for evaluating the general temperature distribution on the test surface, the UNX system receives parallel image information from the integrated industrial camera. Thus, it determines the exact defect status of the material. It’s this combination of board-level camera with autofocus from IDS, paired with a built-in industrial computer with a 7-in. touchscreen and the associated software that makes the iX-600 unique in its functionality. The instrument, patented in Taiwan, is mobile and does not require an additional external computer.
Inspection of the outer skin of a yacht
Using the example of the outer skin of a motor yacht, the procedure can be explained in simple terms. The board level camera records an image of the area to be inspected, exactly overlaid to the thermal imaging camera during the inspection. With the help of image processing technology, the system can quickly detect defective areas by analyzing and matching the image data and display their relative position. All measurement results are clearly displayed and documented in the image. The delamination defect, for example (green frame in the picture), can then be easily located for repair.
Industrial camera with autofocus
UNX Technologies was looking for a compact camera for the mobile system that would also allow quick changes between different focal planes. “The iX-600 is a portable device,” explains Yu-An Lai of UNX Technologies. “It must therefore be small and light. The same applies to its components, of course. In addition, the integrated camera must have a computer-controlled autofocus function due to the different working distances.”
The uEye LE AF USB 3.1 Gen 1 board level camera from IDS meets all these criteria. It is suitable for the use and control of liquid lenses and offers a practical autofocus function. This allows for optimally focused images at variable object distances. The automatic system is based on an “active” liquid lens control and can be easily triggered by software. Depending on the application, the autofocus can be individually configured and ensures perfectly sharp images quickly. UNX has specifically chosen the model UI-3881LE AF with S-mount lens mount. The camera is equipped with the 1/1.8-in. rolling shutter CMOS sensor IMX178 from the Sony STARVIS series and has a resolution of 6.41 megapixels (3,088 px × 2,076 px) at a frame rate of up to 58 fps. In addition to its high resolution, the sensor scores with speed and sensitivity, so that excellent images are achieved even under low light conditions.
Evaluation result of the iX-600
The UI-3881LE AF has a twist-proof USB Type-C connector as well as USB power delivery and can be easily integrated into embedded systems. Due to its compact design (36 mm × 36 mm × 20 mm), it can be installed in the smallest space and is perfectly suited for classic machine-vision applications and tasks in the fields of microscopy, medical technology, metrology, and traffic monitoring.
The Taiwanese company uses the IDS software development kit to integrate the camera. IDS Software Suite is a free software package that works with uEye industrial cameras (model designation “UI”) and can easily handle a mixed operation of USB 2.0, USB 3.0, and GigE uEye cameras. In addition to the camera drivers, it contains sample programs in various programming languages, such as .NET. “This shortened our development time considerably,” explains Yu-An Lai.
Outlook
The iX-600 inspection system focuses on the market for noncontact and thus nondestructive testing of composite components, a market that holds a lot of potential. This is because the areas of application for composites are often sensitive. Whether in maritime applications, as described here, or in space travel, medical technology, or sports equipment construction, the load-bearing capacity of the materials used is essential and makes regular testing indispensable.
However, UNX Technologies is also considering applications that will require industrial cameras with higher resolution or C-mount lens connection in the future. Here the company has the “sister camera” UI-359xLE AF in mind. Just like the UI-3881LE AF model used in the iX-600, it offers the possibility of focusing liquid lenses conveniently via the camera, using software. On the sensor side, however, it is equipped with a 1/2-in. rolling-shutter CMOS color sensor from ON Semiconductor, which delivers an extremely high resolution of 18.10 megaixels (4,912 px × 3,684 px, 20.0 fps), 4K Cinema (4,096 px × 2,304 px, 38 fps), and Ultra HD (3,840 px × 2,160, 40 fps).
No matter which variant is used, the compact and powerful industrial cameras open up countless application possibilities. In mobile solutions, such as the iX-600, they make everyday work easier for the user in every regard and at the same time ensure greater safety.
Sabine Terrasi’s picture
Sabine Terrasi
Sabine Terrasi manages corporate communications for German camera manufacturer IDS Imaging Development Systems.
