Featured Product
Metrology Features
NIST
Tracking changes in fluorescence from ultracold atoms is a super-sensitive indicator of pressure
Prashant Kapadia
Aid root cause analysis by detecting wear and tear in advance
Mike John
How metrology can bring the medical-device design and manufacturing process together
Steven Brown
21st-century standard candles at NIST
More Features
Metrology News
For light-duty industrial weighing applications
Precision manufacturers can monitor Universal Robots in real time and over time
New technology will allow customers to grow capacity, improve profit margins and gain efficiencies
Demonstrating a commitment to keeping people safe and organizations running
Meet the latest generation of LC xx6 encoders
On-demand pipe flow measurement, no process interruptions
Q-Span Gauging Systems improve efficiency, capacity, and real-time reporting of quality departments
More News
Samuel Lesko
Metrology
Integrating Measurement and Analysis Can Power Quality Control 4.0
Surface metrology tools must both measure and automatically generate and save reports
Published: Tuesday, June 14, 2022 - 12:03
The manufacturing and production industries have rapidly evolved during the past 10 years, faced with significant challenges both in finding resources to run production and in manufacturing under tighter tolerances for surface texture and 3D feature dimensions.
The strict tolerances required in advanced manufacturing increases the need to have very repeatable metrology systems as part of the manufacturing line. Often a robot is used to exchange parts between the production tool and metrology equipment, leading to a fully automated process that removes some of the variability found with human operators.
Through the same automation path, results from a metrology tool are transferred to a central server that keeps track of trends or abnormalities using statistical process control (SPC) or other methods. This evolution is often referred to as Industry 4.0, where manufacturing is highly automated and directly integrated with metrology.
Features for quality control
The advanced precision engineering industry manufactures various parts ranging from medical (e.g., orthopedic hip cup, knee joint) to automotive (injector, cylinder). In any of these applications, areal texture and roughness, local flatness, as well as topographic defects or deviation of 3D features play a critical role in meeting the certification compliance requirements for medical devices or the efficiency and functionality of mechanical parts.
Industry 4.0 requires surface metrology tools that not only measure but also automatically generate and save reports with dynamic naming, log results in a database together with batch ID and part number, and apply advanced 3D dataset processing to achieve the exact parameters required.
Integrating measurement automation and software analysis
To meet these requirements, Bruker and Digital Surf collaborated to enable the full integration of measurement software, which acquires data from a white light interferometry (WLI) optical profiler, with Mountains analysis software.
Robot inputs, such as part serial number or measurement conditions (e.g., objective, measurement mode) are transferred to Bruker’s Vision64 measurement software, and results such as diameter variation or classification of defects are obtained by direct communication with Vision64 Map analysis software (see figure at right).
The measurement software seamlessly communicates with Digital Surf’s advanced surface and contour solutions in both directions. Through this bidirectional data exchange, the measurement software can automatically save and print a report for each measured part. It’s also capable of reporting results to an SPC server via a comma separated variable (CSV) file.
Bruker’s WLI optical profiler contributes to the high throughput requirements with fast, large areal topography measurement that combines subnanometer vertical and submicron lateral resolutions. Paired with the particle analysis, defect classification, and advanced contour capabilities of Vision64 Map, the optical profiler provides a powerful analysis solution that meets metrology automation demands.
Automotive injector inspection
One example of this fully integrated process is the analysis of an automotive injector. This application requires the control of many aspects that are all equally critical for the part’s quality, based on a single measurement.
Diameter size and roundness with quantified deviations are automatically assessed using advanced contour tools, while flatness and vertical defects are screened by the parameters table and particle analysis features. Ranking of top surface defects is further established via the classification tool, thus flagging scratches, which can be responsible for leak paths.
A picture containing building material, businesscard, stone  Description automatically generated
Table  Description automatically generated
Automotive injector inspection report with scratch and pits defect analysis on top surface
Finally, the relative shift between top and bottom diameter is automatically calculated with the advanced contour tool.
Diagram  Description automatically generated
Deviation vs. desired diameter
Conclusion
The full integration of Bruker’s WLI optical profiler acquisition system and Mountains software analyses addresses demanding quality control in advanced manufacturing processes. The success of this solution is based on a unique combination of flexible and robust analysis toolkits, such as particle analysis and advanced contour, with high metrology performance. All together, these elements provide a sustainable, agile solution to the challenges raised in Industry 4.0.
Samuel Lesko’s picture
Samuel Lesko
Samuel Lesko is director of technology and applications at Bruker.
