Featured Product
Management Features
Rebecca Saenz
AI-driven technology should lighten the load for workers, not replace them
Bert Thornton
Enter into a get-get arrangement for success this year and beyond
Josh Wilson
Never let a serious crisis go to waste
Katie Rapp
Benefits, tips, and lessons learned
Prasad Akella
Drishti’s focus on enhancing employee capabilities is a fresh take on technological solutions
More Features
Management News
Strategic move to maintain high quality while innovating and scaling
Initiatives include collaborations with printer manufacturers pro-beam, Sciaky, DM3D, Gefertec, and Meltio
Providing high-quality semiconductors in challenging times
Synergies will further drive adoption of configuration life cycle management solutions
Control System Integrators Association’s certification program demonstrates dedication to continuous improvement
Eiger Fleet to enable more control and automation of distributed manufacturing
Is the future of quality management actually business management?
Sept. 16, 2021, at the Duke Energy Center in downtown Cincinnati
More News
Jason Furness
Management
Identify and Remove Bottlenecks in Your Business
Managers, heed these dangers while en route to a Black Belt
Published: Tuesday, November 14, 2017 - 12:01
You have defined what you want as an outcome of the change program; you have looked at how to understand your financial statements and how to use them to assess options. You have looked at the obstacles that lay in your path. Now we are going to start to look at your business, specifically.
Why your business is like a chain
Within the theory of constraints body of work that was developed originating with Eli Goldratt, there is a commonly used metaphor for a business that is referred to as the “chain analogy.” We are going to use that metaphor to help get started.
Think of your business as a series of operations and activities that each form one link in a chain. The work flows from one link into the next where it is processed, and then ultimately, once the work has progressed through all of the links, it is delivered to the customer and the cash flows back to your company. In a simple form the work may start out with marketing activities that generate an inquiry, that leads to a quote, a sale, then an order, moves into production, dispatch, invoicing, and finally to receivables.
The financial performance of our business is like the load capacity of our chain. The stronger the chain, the stronger the business. What do we all know about chains? When you increase the load on a chain, any chain, the chain is going to break at the weakest link.
How to focus your efforts for the fastest and most profitable improvements
As managers we are always being asked to improve the business, so that is what we work on. However, often we are responsible for only a small section of the business, one link in the chain, so that’s where we focus our improvement efforts.
Think about our chain again. If we’re working on improving a part of the chain that isn’t the weakest link, we aren’t going to strengthen the chain as a whole, therefore we won’t see great improvement in the overall performance of the business. Investment projects are notorious for under-delivering on paybacks to the overall company bottom line. We show performance improvements in our local areas, but the overall company bottom line does not change in a breakthrough fashion.
The invalid assumption we make is that improving performance locally results in improving performance in the global system. Investing to improve performance in anywhere but the weakest link in the chain will not result in the best possible return on investment for your business.
For a company to undertake a companywide improvement program is a waste of money, and indicative of a poor understanding of what drives cash flow. Why would you strengthen all of the links in the chain when it is only the improvement activities on the weakest link that will deliver a solid return on investment?
To achieve the speed and magnitude of results that are required in the rapidly changing and increasingly demanding world of 21st century business, we focus our attention on the weakest link and lift its strength as quickly as we can.
So, where is it, and what do we do when we find it?
The five focusing steps to improvement in any environment
The five focusing steps were also developed as part of the theory of constraints. The steps are quick and simple tools for working out how to begin improving your business.
Step one: identify
Here we identify where in the system the flow of money is being blocked.
Remember, the chain analogy that encourages you to think of the business as the entire system is broken up into departments or processes (links). Some common bottleneck examples include:
• A certain machine within a factory
• A process that produces less output than the rest of the system, e.g., marketing can be a constraint on the money flow of the business if there are insufficient leads flowing into the sales process.
• Policies, e.g., batch sizes in shipping or processing that mean we overproduce some products while being out of stock of products that could be sold immediately.
Some clues to help you find this bottleneck is to look for the most heavily loaded resource, look for where stock piles up, or what piece of equipment everyone is terrified of breaking? It could be a supplier, a skill set, or just about anything.
This not a process that should be buried in weeks of data analysis, it is an intuitive perspective of the group of people who work on the business (chain) you are looking to improve.
Step two: maximize
In the original theory of constraints literature, this stage is called “exploit.” I find that this term has too many negative connotations attached to it and it tends to alienate people with whom we are trying to work to implement the concepts. I do want to be faithful to the original material, however.
In the maximize step, we look to change the way you run the constraint so as to maximize its output. This may include some of the following ideas that we have used with clients when a machine has been the constraint:
• Run it through meal and shift breaks.
• Speed up cycle times.
• Make sure the operator never has to leave the machine, which would cause it to stop.
• More endurance, more performance
• Shorten setup times.
• Ensure the raw materials are always present.
• Ensure all information needed by the operator is provided, and is clear.
Stand by the constraint activity and watch. Look for anything that reduces the output.
Standing by the constraint activity and watching is not a five-minute activity. This activity is described by former Toyota chairman Fujio Cho as “Go see, ask why, show respect.” We want to station ourselves at the constraint, see what is happening, ask why things are being done in that way, and show respect to the human beings that are conducting the activity. We will need to spend hours, possibly a few days, to truly understand all of the issues that are hurting the constraint.
Apply whatever continuous improvement tools and resources (lean manufacturing, total productive maintenance, Six Sigma, or all of them) that you have onto this process, and only this process. There are 24 hours in a day, this equates to 86,400 seconds. Until all 86,400 of these seconds are used productively to generate throughput, you do not have a capacity problem, you have a management problem.
This is good.
Management problems can be changed easily, far more easily than technical design failures, or tolerance stack ups, fatigue test failures, and many other more complex ways that a process can fail.
Step three: subordinate
This is the trickiest part of the process. The whole organization must change its behavior to support the constraint. What is best for the constraint is the most important thing; this often means other parts of the organization may have to wait, share, or give up resources; change operating policies, etc.
For example, they might have to:
• Make more regular and special deliveries to ensure that the constraint never runs out of material.
• Buy more expensive and higher quality tools to reduce breakages.
• Modify forms and paperwork so they are easier and faster for a constraint operator to complete.
• Increase maintenance focus on this machine to reduce downtime.
• Purchase a more expensive raw material in order to improve yield.
In the initial enthusiasm, we will subordinate; maintaining this change in organizational priorities is tricky and requires constant monitoring. They say ‘Old habits die hard’ for a reason. This reversion to old behaviors, or old organizational policies or structures, and move away from the subordination to the constraint is the most common reason I have encountered for an organization to experience deterioration in the rapid improvements that have been achieved. Many of our clients experience this problem (even if we have warned them). They have their learning experience, and then restore the old behaviors and see the performance improvement disappear. This is the hidden killer of organizational change.
Part of subordination is to examine what you should stop doing. Very simply, you stop undertaking any improvement activity, or any activity on a non-constraint, that can be stopped. Redeploy any of this capacity that can usefully be used by the constraint. Eliminate the distraction of anything that does not relate to supporting the constraint and can be stopped without hurting the business. Stop them all. Now!
Step four: elevate
If after having first sweated out all the capacity you can by genuinely following steps one to three, you still need more capacity, you can further elevate it by finding another machine, person, whatever it takes as long as any increase in investment or expense is less than the income generated by the throughput.
Step four is where investing in equipment and software can add value to increase capacity at the constraint. Investing in software, equipment, people, or training is a waste of time and money on a non-constraint as the throughput of the system doesn’t increase. Investing in the constraint before you have implemented the first three steps will probably give you an improvement in throughput but at greater cost than was necessary.
Step five: Don’t let inertia set in
Often steps one to three are sufficient to break the constraint and achieve a breakthrough in performance. To develop and then maintain a sustainable competitive advantage, an organization must always be looking to improve. Go back to step one and repeat the cycle.
Life is better, memories of the bad times fade, the wounds heal somewhat and we can fall victim to the enemy of great human progress, contentment.
The leadership of a company should celebrate the changes, gather the teams, and then define a new compelling future to move to. Contentment will lead to complacency and then decay. A leader who is never happy because that is a proxy emotion for contentment may drive toward great heights but will not have much fun along the way, nor will their people. The paradox for a leader is to be simultaneously discontented with the status quo and happy with the progress made thus far.
Comments are welcome.
This is an excerpt from the book, Manufacturing Money (Amazon Digital Services, 2015) by Jason Furness and Michael McLean. See article on Manufacturship blog.
Jason Furness’s picture
Jason Furness
Jason Furness, CEO and founder of Manufacturship, is an executive coach who provides lean manufacturing training and lean consulting in a pragmatic, hands-on way that gets clients results in a fast and sustainable manner. Furness oversees the development and delivery of Manufacturship’s curriculum, leads the mentoring of business owners and managers, and sponsors all client projects. During his 20-year career he has led 30 transformation projects for small and medium-sized enterprises. Furness is the co-author of Manufacturing Money: How CEOs Rapidly Lift Profits in Manufacturing (Amazon Digital Services, 2015).
