Our landlords thank you.
Taylor Brown
Published: Monday, December 13, 2021 - 13:02 For medical device manufacturers, finding success means setting ourselves up for success with repeatable processes that not only ensure quality but also mitigate future risk. This drive for quality is the reason we have such hyper-specific language in our standards. It’s what demands the stringent expectations from our regulatory bodies before products hit the market. It’s also why any examination of internal processes in our quality management systems focuses on the idea of continuous improvement. Correcting mistakes means more than meets the eye. We’re not only undoing a wrong when it comes to an internal error; we also are preventing this or other similar mistakes from occurring again. This spirit is paramount to achieving quality, reliability, and success in an industry that demands all three as a bare minimum for entry. The same can be said for our relationships with suppliers. Whether they’re manufacturing our devices, creating specialty parts, or just helping deliver the raw materials used in our manufacturing processes, a mistake on their side has the same effect as one on ours. Luckily, we have a documented method of dealing with these kinds of issues thanks to the corrective action request process. Let’s take a look at how this is put into practice, as well as some high-level tips about how to approach corrective action requests with your external suppliers. A corrective action request (CAR) is a formal change request regarding a nonconformity issue within an organization. These generally occur following an audit of a quality management system (QMS), with the CAR used as a method for noting the nonconformity and documenting the action used to correct it. Corrective action requests are part of a corrective and preventive action (CAPA) system. They are considered to be “reactive” because they occur after a compliance issue is discovered. However, the intent of a corrective action request is to prevent it from happening again in the future. It’s all about finding ways to be proactive while tackling a reactive issue. Although corrective action requests are rooted in the requirements of ISO 13485:2016, the international standard for medical-device quality management systems, a CAR can also represent the need for further risk assessment. This is particularly true when nonconformities occur with suppliers, resulting in a supplier corrective action request. When a nonconformity requires a supplier corrective action request (SCAR), there are specific steps that must be taken. SCAR resolution requires that the supplier not only correct the issue but also document how they will prevent it from happening again. There are four phases of a SCAR process: The request phase establishes the importance of documentation with a formal notice that captures vendor and product information as well as a clear description of the nonconformity and expected response. The response may include documentation requirements and due dates. Once the supplier corrective action request has been issued, the real work begins with the supplier collaboration and response phase. Collaborating with a supplier incorporates all the main elements of the CAPA process. These include: After these steps are taken, it is time for the disposition phase, in which internal personnel assess whether the vendor’s responses are sufficient. If not, the SCAR may be sent back for clarifications and further responses. If the response is unacceptable or determined to be irreparable, disciplinary action may be taken against the vendor, like removing them from a manufacturer’s approved supplier list (ASL). Hopefully, the request is handled efficiently and is then passed on for the final stage of the SCAR process: the supplier review board approval phase. Once approved, each SCAR should be documented within its respective CAPA workflow within the QMS for the medical device. An eQMS is beneficial in documenting the SCAR process and ensuring documentation is reviewed, and records are maintained. The interconnectivity of an eQMS like Greenlight Guru will help manufacturers demonstrate the cause of the SCAR (e.g., nonconformances, audit findings) to the effect (updated procedures, removal from the ASL). Although CAR and SCAR are often used interchangeably, a supplier corrective action request refers specifically to nonconformance issues with an external supplier. Much like with an internal or regulatory CAPA investigation, SCARs should be taken seriously by all parties involved. This is when it really pays off to have a good system for managing supplier relationships. Ultimately, medical device manufacturers are responsible for quality issues related to a product; that extends to the steps taken in qualifying, choosing, evaluating, and monitoring the performance of suppliers. When nonconformities from external sources are found, a medical device company has two choices: to SCAR or not to SCAR. If the nonconformity causes major manufacturing interruptions or has to do with a larger, more systemic issue, it certainly warrants a formal supplier corrective action request. However, if the issue is minor or appears to be a one-off occurrence, you may choose to first speak directly with the supplier about the issue before escalating it into a formal SCAR. If this is sufficient, it may very well be a sign you’ve found a trusted supply partner. That being said, a true partner in quality should never balk at the need for a formal SCAR, either. Many medical device companies make the mistake of focusing their efforts on corrective actions first, rather than taking preventive actions as a starting point. This is to no fault of their own, as most quality systems aren’t capable of preventive actions. As a result, manufacturers are forced to be reactive because they simply don’t have the tools to gather the data they need to make more informed decisions. That’s where a robust software solution like Greenlight Guru comes in. The Medical Device Success Platform (MDSP) from Greenlight Guru integrates a risk-based approach throughout the entire quality ecosystem. CAPA Management Software offers a dedicated workflow that lets you easily manage your risk-based CAPA process in a fully traceable system, giving you the visibility and ability to assess and identify quality issue trends in real time and prevent them from manifesting into systemic problems. First published Nov. 14, 2021, on the Greenlight Guru blog. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Taylor Brown is a Medical Device Guru, certified Lead Auditor for ISO 13485, and a card-carrying Quality Nerd. She got her start in the industry as a technical writer and quickly became an audit readiness and support specialist, traveling around the United States to establish ISO 13485 compliant quality systems. She enjoys working with customers to establish the right sized eQMS while improving the quality of life.How to Approach Corrective Action Requests With Medical Device Suppliers
Looking upstream for improved efficiency
What is a corrective action request?
How does the supplier corrective action request (SCAR) process work?
1. Request phase
2. Supplier collaboration and response phase
3. Disposition phase
4. Supplier review board approval phase
• Containment of issue
• Investigation of issue
• Root cause analysis
• Corrective and preventive actions
• Verification of completionCorrective action request (CAR) vs. supplier corrective action request (SCAR)
Reduce the need for corrective action by addressing and preventing issues early on
Quality Digest Discuss
Taylor Brown
