Featured Product
Management Features
Chris Caldwell
Significant breakthroughs are required, but fully automated facilities are in the future
Dawn Bailey
Helping communities nurture the skilled workforce of the next generation
Brent Simpson
Even if it works in your favor
Mike Figliuolo
Stay cool. It all works out.
Gad Allon
Aligning timing, leadership, and strategy is complicated
More Features
Management News
A tool to help detect sinister email
Developing tools to measure and improve trustworthiness
Manufacturers embrace quality management to improve operations, minimize risk
How well are women supported after landing technical positions?
Adds increased focus on governance
Survey shows 85% of top performers rely on it to achieve business objectives
Key takeaways from Marcum’s 2023 National Manufacturing Survey
More News
Steve Daum
Management
Five Costly Mistakes Applying SPC
Avoid these and amplify your QA efforts
Published: Wednesday, June 21, 2017 - 11:02
I have daily conversations with manufacturer plant managers, quality managers, engineers, supervisors, and plant production workers about challenges when using statistical process control (SPC). Of the mistakes I witness in the application of SPC, I’d like to share the five most prevalent; they can be costly.
No. 1: Capability before stability
Capability is a critical metric, and capability statistics are often an important part of your supply chain conversation. Your customers want assurance that your processes are capable of meeting their requirements. These requirements are usually communicated as tolerances or specifications.
Customers frequently specify a process capability index (Cpk) or process performance index (Ppk) value that you must meet. Because they put such importance on this value, capability statistics may become your primary concern in quality improvement efforts. They may be important, but sole reliance on Cpk values is premature.
The first issue to be addressed is getting to a stable, predictable process. Building control charts into your analytical process on the front end can prevent costly mistakes such as producing scrap, shipping unacceptable product, or even setting the stage for a dreaded recall.
No. 2:  Misuse of control limits
Producing control charts doesn’t guarantee accurate process feedback. There are many subtleties with the application of control limits that are easy to get wrong. Here are a few common errors.
Computing wrong limit values with a home-grown tool. Time and time again I have seen examples where the numbers are just wrong, often resulting in audit failures. If you use a home-grown tool for SPC, proceed with caution.
Never computing static control limits. The decision to compute control limits should be a deliberate one, even if your SPC software automatically computes limits for you.
Never re-computing control limits. If you reduce variation over the course of a year, then the control limits you computed in January will not reflect how the process is running the following December. A deliberate re-computing of the control limits to establish the “new normal” is in order.
Waiting to have enough data to compute control limits. Whether you have a small amount of data or a great deal of data, computing “baseline” control limits will almost always provide benefits. There are many guidelines, such as waiting until you have at least 25 subgroups gathered over a normal course of production. If you don’t have much data yet, reasonable control limits can be computed even with small amounts of data.
Confusing specification limits with control limits. Specifications, aka tolerances, tell you what your customer requires. Control limits reflect how your process behaves. I often see line charts with horizontal specification lines at the upper and lower specification values. This type of chart might provide value in some situations, but it should never be confused with a control chart.
No. 3: Measurement system issues
If you are applying SPC, you’re measuring things. Do you know how well you are measuring? This is a critical factor that is easily overlooked when you are focused on SPC. Even the best application of SPC tools can be undermined when the ability to measure things is uncertain.
In addition to having measurement systems analysis tools, you need to properly manage your measuring devices. How well do you manage your measurement equipment? What is the calibration interval? What steps are checked during a calibration? What’s the history of calibration for a given device? What master gauges are used for the calibration, and have those devices been calibrated?
Software applications designed for this purpose, such as PQ Systems’ GAGEpack, can help to assess and manage measurement systems.
No. 4: Delegating SPC work to one employee or a small group of employees
In many organizations, SPC is not yet internalized and normalized as a part of doing business. This becomes a problem when the person tasked with SPC leaves. The system they put in place may get less attention, and charts on key quality metrics may not get refreshed.
No. 5: Not leveraging technology to scale your SPC efforts
Technology has made it easier to create and deploy SPC charts on anything and everything. While advantages to this abound, the amount of time spent by valuable employees doing nonvalue-adding, repetitive, SPC-related work can be costly.
If you need to monitor dozens or even hundreds of SPC charts, you need to seek methods of scaling your SPC application. Consider the time it might take to do these steps:
1. Find the chart of interest.
2. Display the chart.
3. Analyze the chart.
4. Decide whether action is needed.
Why invest an employee’s time and attention to look at hundreds of charts—most of which are stable or in control? Utilizing an automated approach can amplify your ability to pay attention to key metrics without dragging quality workers away from more important activities.
Often, when I see the five mistakes listed in this article, the root cause is too much focus on the tools of SPC and not enough focus on the SPC way of thinking. The common thread among these mistakes is an underlying need for more education. Through continuing education, this SPC way of thinking can become embedded in the manufacturing culture.
Editor’s note: Join PQ Systems on Thursday, June 29, 2017, for the webinar, “Five Costly Mistakes Applying SPC and How to Avoid Them.” This 1-hr webinar begins at 11 a.m. Pacific/2 p.m. Eastern.
Steve Daum’s picture
Steve Daum
M. Stephen Daum is director of development for PQ Systems. Prior to assuming responsibility for development, Daum was the lead programmer on PQ’s statistical software products, a position he took in 1985. Daum has more than 20 years of experience with control charts and control charting software and has shared that experience through presentations, training, and educational sessions for organizations throughout the United States, England, and South Africa.
Question
Steve,
This is some great insight to how careful you need to be when applying SPC in a plant. As a student near graduating and looking into working in a manufacturing environment soon, I now know to be mindful of these considerations. I think each of the 5 points is very important. If a process isn't predictable or stable, pushing it to maximum capacity is a huge risk. If you're using the wrong numbers to create the control limits, the control limits are useless; and control limits and specification limits need to both be considered to get the best results from both metrics, as both are important to successful production. SPC is also best utilized when practiced organization-wide, not just by a few individuals. That's when you'll start to see real impact. Also, with technology being so dominant in the manufacturing now, people are very reliant on these measurement machines and devices, so you made a great point about regularly checking if these machines are even accurately calculating is vital.
Clearly your 20+ years working with control charts and limits has impacted your knowledge of SPC. At what point in your career did you begin piecing these together and implementing them into your practices? Also, what are your thoughts on outsourcing consultants to come into the plant and implement these SPC practices? Have you found a lot of reluctancy in employees to listen to someone who doesn't work there?
Quality Digest is in the recycling business
This is much the same article as one from two years ago. Recycling is fine, but why not just reprint the one from 2015 and update the webinar info? Ditto for the recent articles from a columnist about "Gauging Gage ..." (I don't think the biography of that columnist is accurate now, as they are no longer at Minitab.) As for this article, the notion that "Time and time again I have seen examples where the numbers are just wrong, often resulting in audit failures" makes sense to me. A typo in a formula, treating a blank entry as a zero, copy/paste errors, SQL commands that aren't so structured, macros gone awry -- we could make a long list of possible hiccups.
Errors
The statement "Computing wrong limit values with a home-grown tool" is very misleading. As long as any "home grown" tool follows the guidelines laid down by Dr Wheeler, there is nothing to worry about.  By contrast, many "professional" tools make blatant errors such as drawing meaningless and distracting distributions over histograms.  Rather than warn about "home grown" tools, Steve should have warned about tools promoting "Six Sigma Analysis".  This is simply farcical.  https://www.linkedin.com/pulse/six-sigma-psychology-part-2-tony-burns    Unlike his competitor, Steve's product does not fall into this bear trap.
