Featured Product
Lean Features
Gleb Tsipursky
Belief that innovation is geographically bound to office spaces is challenged by empirical evidence
Jamie Fernandes
From design to inspection to supply chain management, AI is transforming manufacturing
James Chan
Start the transition to preventive maintenance
Mark Rosenthal
The intersection between Toyota kata and VSM
Erin Vogen
Eight steps to simplify the process
More Features
Lean News
New video in the NIST ‘Heroes’ series
Embrace mistakes as valuable opportunities for improvement
Introducing solutions to improve production performance
Helping organizations improve quality and performance
Quality doesn’t have to sacrifice efficiency
Weighing supply and customer satisfaction
Specifically designed for defense and aerospace CNC machining and manufacturing
From excess inventory and nonvalue work to $2 million in cost savings
Tactics aim to improve job quality and retain a high-performing workforce
More News
Bruno Scibilia
Lean
A DOE in a Manufacturing Environment, Part 2
A pragmatic and accurate approach to adjusting and optimizing processes
Published: Tuesday, April 26, 2016 - 10:17
In yesterday’s column, I discussed how a DOE was chosen to optimize a chemical-mechanical polishing process in the microelectronics industry. This important process improved the plant’s final manufacturing yields. We selected an experimental design that let us study the effects of six process parameters in 16 runs.
Analyzing the design
Now we’ll examine the analysis of the DOE results after the actual tests have been performed. Our objective is to minimize the amount of variability (i.e., minimize the Std Dev response) to achieve better wafer uniformity. At the same time, we’d like to minimize cycle times by increasing the removal rate of the process (maximize the V A°/Min response).
Therefore, we’re dealing with a multi-response DOE.
From the DOE data shown above, we first built a model for the removal rate (V A°/Min): Down force, carrier velocity, and table velocity had a significant effect, as the Pareto chart below clearly shows. The down force*carrier velocity and the carrier velocity*table velocity two-factor interactions were also significant. We therefore eliminated the remaining parameters, which were not significant, from the model, gradually.
A process expert later confirmed that such effects and interactions were logical and could have been expected from our current knowledge of this process. The graph below shows the main effect plots (i.e., removal rate response).
We had chosen a fractional DOE, so several two-factor interactions were confounded with one another. However, the down force*carrier velocity and the carrier velocity*table velocity interactions made more sense from a process point of view; besides, these two interactions were associated with very significant main effects.
We built a second model for the standard deviation response. The standard deviation does not necessarily follow a normal distribution, therefore a log transformation is needed to transform standard deviation data into normality.
Carrier velocity, pad and table velocity, as well as the pad*carrier velocity interaction had significant effects on the logarithm of the standard deviation response, as shown in the Pareto graph below. Again, this was quite logical and confirmed our process knowledge.
The main factor effects are shown in the graph below (log of standard deviation).
The interaction effect is shown in the graph below (logarithm of standard deviation response).
We then compared the predictions from our two models to the real observations from the tests, in order to assess the validity of our model. We were interested in identifying observations that would not be consistent with our models. Outliers due to changes in the process environment during the tests often occur, and may bias statistical analyses.
The residual plots below represent the differences between real experiment values and predictions based on the model. Minitab provides four different ways to look at the residuals, in order to help assess whether they are normally and randomly distributed.
In these diagrams, the residuals seem to be generally random (shown by the right-hand plots, which display the residuals against their fitted values and their observation order) and normally distributed (displayed by the probability plot on the left).
But the observation in row 16 (the blue point that has been selected and brushed in the plot below) looks suspicious as far as the residuals for the removal rate (V A°) response are concerned. It’s positioned farther away from the other residual values. We used the brushing functionality in Minitab to get more information about this point (see the values in the table below). We then eliminated observation number 16, and reran the DOE analysis... but the final removal rate model was still very similar to the initial one.
Click here for larger image.
From our two final models, we used the process optimization tool within Minitab to identify a global process optimum. Two terms were included in the standard deviation model (V carrier: E; pad: D; and V table: F), and three terms plus some interactions were included in the removal rate (V A°) model (down force: A; V carrier: E; and V table: F).
Finding the best compromise while considering conflicting objectives isn’t always easy, especially when different models contain the same parameters. Reducing the standard deviation to improve yields was more important than minimizing cycle times. Therefore, in the Minitab optimization tool, we assigned a score of 3 in terms of importance to the standard deviation response, and a score of only 1 to the V A° (removal rate) response.
The Minitab optimization tool results indicate that the down force needs to be maximized to increase the removal rate (reduce cycle time), whereas carrier and table velocities as well as pad need to be kept low in order to achieve a smoother, uniform surface (a small standard deviation).
Confirmation tests run at the settings recommended by the optimization tool were consistent with the conclusions that had been drawn from the DOE.
Conclusion
This DOE proved to be a very effective method to identify the factors that had real effects by making them clearly emerge from the surrounding process noise. This analysis thus gave us both a pragmatic and accurate approach to adjusting and optimizing the polishing process. The conclusions from the DOE could easily be extended to the operating process.
Bruno Scibilia’s picture
Bruno Scibilia
Bruno Scibilia is a technical training specialist and leads several Minitab public training courses in Paris. He joined the Paris-based Minitab office in 2007 as a technical support specialist responding to customer queries regarding installation and use of Minitab Statistical Software and the project management software, Quality Companion. Prior to joining Minitab, Scibilia worked as a statistical engineer in the semiconductor industry for six years, and was a practitioner of quality improvement statistical techniques within a manufacturing company for a number of years. He has a Ph.D. in design of experiments and he is an ASQ-certified Six Sigma Black Belt.
Fascinating
Cheers, I think DOE and Anova are are some of the most powerful tools engineers can bring to the table. Pure scientific process to accept or reject multiple hypotheses in a structured form. Brilliant writing.
Ken
