Featured Product
Lean Features
Gleb Tsipursky
Belief that innovation is geographically bound to office spaces is challenged by empirical evidence
Jamie Fernandes
From design to inspection to supply chain management, AI is transforming manufacturing
James Chan
Start the transition to preventive maintenance
Mark Rosenthal
The intersection between Toyota kata and VSM
Erin Vogen
Eight steps to simplify the process
More Features
Lean News
New video in the NIST ‘Heroes’ series
Embrace mistakes as valuable opportunities for improvement
Introducing solutions to improve production performance
Helping organizations improve quality and performance
Quality doesn’t have to sacrifice efficiency
Weighing supply and customer satisfaction
Specifically designed for defense and aerospace CNC machining and manufacturing
From excess inventory and nonvalue work to $2 million in cost savings
Tactics aim to improve job quality and retain a high-performing workforce
More News
Gene Kaschak
Lean
When Your Lean Supply Chains Feel Out of Control, Focus on What You Can Control
Lean supply is not just about the size of inventory
Published: Monday, September 19, 2022 - 11:03
Many manufacturers that adopted lean principles by applying a “just-in-time” (JIT) mindset to inventory of materials and parts have been burned, sometimes badly, by cascading supply chain disruptions. Broken links in the supply chain have created havoc, especially for smaller manufacturers.
Some have scrambled to build “safety stock” of hard-to-find supplies. Others have sought out redundant sourcing. The reality is that everything is connected in your supply chain, and those connections can be fragile when they are’nt well supported.
No, lean supply chains aren’t dead. It’s quite the opposite. When your supply chain breaks down, lean systems for the rest of your value stream system will help you deal with the issue. Solutions revolve around agility and controls, not masking inefficiencies.
Busting the myth of lean supply: It’s not just about size of inventory
Being lean doesn’t mean having little inventory; that has always been a higher-risk strategy. “Lean supply” means having a defined value of what your inventory levels should be and what risk you are willing to take on. JIT is a lean methodology that includes developing standard inventory buffers in your value stream. It requires strong relationships with suppliers so you can work with them through shortages and price increases.
Smaller manufacturing operations often have had an element of JIT for their hard-to-find inventory. One example is the price of copper, which has fluctuated during the past 15 years. It’s a business decision whether you can absorb the financial impact of storing more copper when the price is low. The size of your copper inventory has to make sense for process flow, cash flow and margin, storage space, and more.
Companies with more agile operations routinely outperform those that carry more inventory. However you adjust to a disruption, the alternative should not create more waste overall or mask inefficiencies.
Disruptions can have vast effects throughout the company
A supply chain disruption can have a significant trickle-down effect through your operation, not just in sourcing but also in how you use newly sourced materials. New components or materials often result in an operational process change, which can be a challenge to manage, whether it is short- or long-term. Some changes in inventory and processes can even be a challenge with your existing plant layout. Potential complications are vast.
For example, electronics manufacturers have struggled with supplies of semiconductors and components. A replacement chip or transistor may have different tolerances and variation in performance. Some engineering development work may be necessary for that component to work effectively in a product.
Uncertainty and temporary solutions can lead to failure to adhere to lean principles, especially if you’re using multiple alternative materials or changing more than one dynamic.
Food manufacturer sees impact of changing one ingredient
A recent case at a food manufacturer illustrates the direct and indirect impacts of disruptions. It also speaks to the power of documenting standard work and the need for strong lean systems.
One of the products the company makes has a white chocolate coating. The company was forced to use an alternative supplier for this coating. The compound of the new white chocolate supply was different and not as reliable, which resulted in a series of changes. The first change was to the recipe, and then to the operational temperature, which changed the way the equipment was run and how the company measured the quality of coating. The new coating even changed how the company had to store the material, keeping it separate from other supplies, and how it had to clean the equipment to ensure compliance for traceability.
The company faced the dilemma of whether these changes were a short-term solution, or whether it needed to update the standard work documentation and training modules—all for one ingredient.
Documenting standardized work and updating controls are essential
Documenting standard work is a cornerstone for lean. Standard work procedures should be updated frequently. But it is a tedious, difficult task, so it is not unusual for small manufacturers to have documentation that is two or more years old.
Changes in materials as a result of supply chain disruption often lead to subtle process changes. You may view this as a temporary situation, with the expectation that you will soon be going back to the original process. However, even a few months can have a big effect. Now you have a new process and new procurement; danger creeps in when you don’t have standard controls in place. Manufacturers can lose sight of this when they are in reactive triage.
It becomes imperative to establish benchmarks and key performance indicators, even as a supplemental standard of work. Stepping back to analyze a situation and re-establish a new standard is a proactive approach. You are in a stronger position to address issues if you are measuring and tracking performance. This is why lean methods apply now more than ever.
Don’t overlook training as a tool for mitigating supply chain disruptions
Disruptions often result in the need for more frequent and varied training, which puts stress on your instructors. When process changes occur, you must update your training program. If you’re shutting down one product line for several weeks due to a material shortage, you may need to cross-train some employees on a different machine or process.
If you don’t update standard work and training, even temporarily, you open the door to other issues, especially with new employees. Lack of documentation with training can lead to process issues, which often cause more tension and quality issues. Additionally, when employees get discouraged, retention issues increase.
Taking a proactive approach is key to mitigating impacts
Supply chain disruptions will have direct and indirect effects on your operation. You may see a dip in overall equipment efficiency or increased waste. Your continuous improvement program will be less effective because you’re in reactive, problem-solving mode. Whatever you do, avoid causing unintended consequences. Take a back-to-basics approach to track performance, and keep more things within your control. Use daily management display boards and follow the plan-do-check-act (PDCA) methodology for any changes you implement.
Here are four keys to help mitigate the effects:
Be proactive vs. reactive: It becomes hard to close a gap if you’re not closely monitoring performance.
Pursue two levels of improvements: Conduct daily operator-level experiments with standards in mind and team-based problem solving.
Leverage relationships: Maintain or improve relationships with suppliers and customers to find what works best for both parties.
Maintain a system of controls: Institute benchmarks, which are critical to making good business decisions.
Local MEP centers can help you with your lean supply chain
A disciplined approach to lean supply chains helps keep you in control of as many variables as possible. When one critical aspect of lean manufacturing is disrupted, the other elements are more important than ever. Experts at your local MEP center can help you manage supply chain disruptions.
First published Sept. 1, 2022, on NIST’s Manufacturing Innovation Blog.
Gene Kaschak’s picture
Gene Kaschak
Gene Kaschak is the director of continuous improvement and lean coaching for the Manufacturers Resource Center (MRC), an MEP center in eastern Pennsylvania.
