Our landlords thank you.
Bruce Hamilton
Published: Tuesday, December 7, 2021 - 13:03 In 1996, the TSSC (Toyota Production System Support Center) began working with my company to create one-by-one production capability in our product assembly. Previous to TSSC’s assistance, we’d moved the furniture and machines into cells, creating the appearance of flow production, but we lacked the problem-solving know-how and management discipline to create real flow. Remarkably, after several months of focusing on our pilot line, it appeared that all of the pieces of the puzzle had been identified and matched, and that impediments to flow had been remediated. Our kaizen support team and assemblers had worked daily to simplify, standardize, levelize, balance, and mistake-proof assembly operations. Conveyance routes were also standardized, providing material just in time at a rate of three kits every 12 minutes to match a customer takt time of four minutes per assembly. It was now time for our first live trial of a full production day with a production goal of one product every four minutes—or 120 products by day’s end. As an organization that had only several years earlier produced to stock in batches five to 10 times greater than customer need, this trial run was a remarkable and exciting milestone. We had previously been, as we joked, “the kings and queens of overproduction,” always busy expediting to fill customer stockouts. Overproduction, sometimes referred to as the worst of the seven wastes because it creates more of the other six, had once been viewed by us as a hedge against long lead-times. Now, however, we’d become aware that excess production was actually the cause. Little by little, with daily kaizen, we’d whittled down the production queues from 12 weeks to two weeks. Then we requested and received TSSC’s assistance. “We’re satisfying customers’ delivery requirements now,” I told Hajime Oba, TSSC’s general manager, “but only through excessive overtime.” Observing the process, Oba responded, “TSSC will assign a consultant to assist you to address your overtime condition.” “Great,” I said. “What do we need to get started?” “Commitment!” Oba said. “Our role at TSSC is to provide information and inspiration to your team, and your role is to be committed to improvement.” Not entirely clear on what I was agreeing to, I nevertheless nodded affirmatively. Working under the guidance of a consultant from TSSC, we (and I) found the process of surfacing and removing problems with flow both energizing and exhausting. The assemblers emerged as stars—the real knowledge workers. The rest of us were there to support. So many “little” problems surfaced every day, and every day we did our best to remove them. This, I think, was the commitment that Mr. Oba was referring to. A key learning point for me was that commitment requires understanding; the more I understood, the more committed I was to improvement. During this focus on our model line, we kept extra resources available—people and inventory—to meet customer demand. Experiments or tinkering that occurred on the model line could not adversely affect customer service. So, up until our full-day go-live trial, everything was still a hypothesis. As a hedge for our pilot, we scheduled a full day on Saturday to “get the kinks out.” On Friday night, we set up the line with a mixed-model sequence list levelized for best flow, and standard work in-process levels for one-by-one assembly. The inventory safety net was removed. Nevertheless, I was confident that we would execute one-by-one production, in sequence, at about 80 percent of plan. I envisioned a carefully choreographed flow of material, smooth hand-offs, and quick remediation of problems. Our assemblers were less optimistic. On Saturday morning, with a full assembly crew and support functions, we set out to test our hypothesis. To this point we had operated with the protection of excess inventory between operations; now there was just one piece of standard work in process between assemblers. As the test began, we watched with anticipation. Work was balanced, and assemblers were experienced; what could go wrong? “Wrong part,” declared the group lead, Jose L. about nine minutes into the day. The line stopped for three minutes while we searched for and replaced the part. During the day, the same problem recurred with other parts. Each time, as the line stopped, the assemblers grew more agitated. Next there were problems with information. Jose showed me, “The customer drawing does not agree with ours.” Then the order of jobs on the in-chute did not agree with the sequence list the assemblers were to follow. The list of problems grew faster than the rate of production. Missing parts, defective parts, tolerance issues, mistakes, computer glitch, broken tool. We stopped each time to try to solve problems, but not all could immediately be traced to root cause, and for each problem solved, it seemed that two more were discovered. By day’s end, after eight-hours of production, out of 120 products planned for assembly, only 17 had been produced. One assembler commented, “This [is] the worst system ever. Anytime something goes wrong, we all stop.” Another declared, “We knew this was going to happen; so many little things go wrong and there’s just no way to keep assembling without a few pieces of extra stock.” Then the material handler spoke up: “You know, because of all the extra material you have squirreled away, most of the problems with parts delivery were invisible to me until today. Harvey C, a former factory foreman and now a member of our kaizen support team, chimed in. “Our problem is not that we can’t fix problems. It’s that with all the inventory protection, we haven’t been able to see all of them.” I agreed. “We learned more today about problems with our process than in the previous three months. We’ve got keep moving forward.” The list of problems we discovered that Saturday was not only huge, it was also just the beginning of discovering delays that were only visible during one-by-one production. Every day for weeks thereafter we battled new problems, inching toward the goal of one-by-one production that Oba had assured me would occur if we showed a commitment to continuous improvement. After six weeks, we hit the production goal along with other significant improvements to productivity. But, more than that, we had developed a broad enthusiastic base of problem surfacers and solvers: everybody, everyday. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Bruce Hamilton, president of the Greater Boston Manufacturing Partnership (GBMP), brings hands-on experience as a manager, teacher, and change agent. Prior to GBMP, Hamilton led efforts to transform United Electric Controls Co.’s production from a traditional batch factory to a single-piece-flow environment that has become an international showcase. Hamilton has spoken internationally on lean manufacturing, employee involvement, continuous improvement, and implementing change. Also, he has contributed to numerous texts ranging from visual control to variety reduction. Hamilton’s blog, Old Lean Dude, is an ongoing reflection on lean philosophy and practices, with an emphasis on keeping good jobs close to home.The Power of Commitment
Continuous improvement means solving problems as they arise
Background
Commitment
New lenses
Hypothesis
The big day
Moment of truth
Consequences
Quality Digest Discuss
Bruce Hamilton
The hardest part of my job is continual improvement. Shop workers know when we improve efficiencies it means less money in their pocket. No more over time. Very hard to get buy in. How do you address the financial shortfall to workers? How will they benefit? More pay? Bonuses? ???? And we can't just say they get to keep their job instead of the plant shutting down becasue we are losing too much money.
Commitment or Perseverance
I prefer the term Perseverance over Commitment, as the former suggests hardship and, in many of these cases, it is being able to put aside our human emotions and continue with the actions to move forward to a successful outcome that matters.
