puuuuuuurrrrrrrrrrrr
Anne Trafton
Published: Wednesday, June 3, 2020 - 11:01 When MIT announced in March 2020 that most research labs on campus would need to ramp down to help prevent the spread of Covid-19, Canan Dagdeviren’s lab was ready. For the past two years, Dagdeviren and her lab manager, David Sadat, have run the Conformable Decoders Group using “lean lab” management principles, working closely with MIT’s Environment, Health and Safety (EHS) Office. Every item in their lab has an assigned function and location, and there are strict procedures in place describing how everything is to be used, put away, and replenished. As a result, it took the lab just 15 minutes to close down operations on March 13, 2020. “Given that everyone in our lab is very well-trained with these checklists, everyone took care of their own experiments and the tools that they use,” says Dagdeviren, an assistant professor in MIT’s Media Lab. “I was then able to spend the rest of the time before the campus shutdown communicating with my students, motivating them, and preparing them mentally for this upcoming period of time.” The lean lab approach has had other benefits as well, including cost savings, increased productivity, and a strong safety record, says Dagdeviren, who reported these effects in a paper that appeared May 14, 2020, in the journal Advanced Intelligent Systems. The paper also offers guidance on how other labs might implement this approach. Sadat and Tolga Durak, the managing director of MIT EHS, are also authors of the paper. Dagdeviren joined MIT’s Media Lab as an assistant professor in 2017. As a junior faculty member, she had limited funding and space, so she wanted to maximize her use of the resources that she had. Her lab, the Conformable Decoders Group, develops novel materials and devices that can interact with the environment and with living organisms to detect phenomena such as heartbeats, neural activity, and temperature, among many others. She spent nine months designing and building her 1,000-square-foot cleanroom—a type of workspace whose environmental conditions are rigorously controlled to avoid contamination of experiments. She hired Sadat as a senior lab manager, and he suggested implementing an organizational strategy known as 5S. Sadat and Dagdeviren subsequently partnered with EHS on the lean lab project. This method, which originated in Japan, is used in industries such as auto manufacturing but has not been widely applied in academic settings. The system consists of five guiding principles to organize a workspace for efficiency and effectiveness: sort, set in order, shine, standardize, and sustain. Canan Dagdeviren, an assistant professor at the MIT Media Lab, has implemented lean management principles in her cleanroom lab space, also called “YellowBox.” Credit: David Sadat Working closely with Durak, Dagdeviren and Sadat set out to implement this organization approach in their lab, which they call the YellowBox. One major element of the system is the visual organization of everything in the lab, which includes making sure every item has an assigned location. Each item is color-coded according to its function (e.g., raw materials, instruments, hazardous chemicals), and its location is outlined in colored tape so it can be easily spotted and later returned to the right spot. “The idea behind it is to reduce the amount of mental calculation that a researcher would have to do when they walk in the lab,” Sadat says. “Instead of seeing a cluttered lab and taking time, energy, and brain focus to look for a specific tool, they can walk into the lab and see color-coded and highlighted structures and do what they need to do without thinking much about it.” Dagdeviren’s lab also developed standard operating procedures: step-by-step instructions to help researchers carry out complex experiments, to help ensure consistency in their research. This overall system not only improves workflow in the lab, it also has financial benefits. Between 2018 and 2019, the lab reduced its spending on chemicals by 41 percent and its spending on materials by 52 percent. The lab uses a “just in time” ordering system that works because their setup makes it easy to see when supplies are getting low, so they don’t have to store a lot of extra material, or risk having supplies expire before they are used. These efforts have also translated to a boost in productivity. Between 2018 and 2019, the lab increased the number of fabricated devices it produced by 119 percent. “This is not a practice lab where nothing is happening,” Durak says. “This is a lab where novel research is taking place every day. However, this is also a lean laboratory that is efficient, data-driven, productive, and safe.” Any potentially hazardous item or chemical is marked in yellow and black, and areas for storing those materials are similarly marked. Because each item in the lab, down to the stools, has an assigned location, it’s easier to keep exit pathways clear. Since implementing the 5S system, the lab has had no accidents, injuries, or near misses. Dagdeviren’s lab is also the first research group at the Media Lab to receive MIT’s Green Lab certification, which recognizes labs that use environmentally sustainable practices to reduce resource consumption, waste, and carbon emissions. When Dagdeviren’s lab first started up, members spent more than an hour a day on management and cleaning of the lab, but as everyone got used to the routine and the setup, that dropped to about 10 or 15 minutes a day. “Initially it was a little bit hard for people to understand and apply, but over time they got enough experience to be used to it,” Dagdeviren says. “Now my lab manager can focus on the most important things rather than cleaning the clutter.” Dagdeviren’s students are now continuing their research at home, running computer simulations of experiments in preparation for resuming their experimental work in the lab. When research operations are able to start up again, she expects that the lab will be able to open up nearly as quickly as it was shut down. “This lean lab project has really positioned Canan’s lab so that when it is time, this lab is going to be able to start operating very rapidly, function very effectively in a socially distanced world, and employ fiscal frugality, right off the bat,” Durak says. He says that EHS hopes to be able to pilot the lean lab approach with other types of labs, such as biology or chemistry labs, or maker spaces. “The lean lab project is an exciting project and a true collaboration between the academy and administration with implications that span above and beyond MIT’s campus,” he says. “This project could also serve as a model for labs at other universities, especially those with limited research space.” The research was funded by EHS seed funding and the MIT Media Lab Consortium. First published May 14, 2020, on MIT News. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Anne Trafton is the life sciences writer at the MIT News Office.‘Lean Lab’ Approach Reduces Spending and Increases Productivity
MIT lab offers a model for using 5S to ensure labs are efficient, data-driven, productive, and safe
Maximizing resources
A model for others
Quality Digest Discuss
Anne Trafton
