Featured Product
Lean Features
Gleb Tsipursky
Here’s the true path to junior staff success
Tina Behers
First, leaders must overcome their fear of failure
Emily Newton
Understand your Wi-Fi environment
Megan Wallin-Kerth
Watch and learn
Bryan Christiansen
MTTR meaning and formula (with calculator!)
More Features
Lean News
Helping organizations improve quality and performance
Quality doesn’t have to sacrifice efficiency
Weighing supply and customer satisfaction
Specifically designed for defense and aerospace CNC machining and manufacturing
From excess inventory and nonvalue work to $2 million in cost savings
Tactics aim to improve job quality and retain a high-performing workforce
Sept. 28–29, 2022, at the MassMutual Center in Springfield, MA
Enables system-level modeling with 2D and 3D visualization, reducing engineering effort, risk, and cost
It is a smart way to eliminate waste and maximize value
More News
Chip Reavley
Lean
Labor Challenges Drive Packaging Automation
Well-designed solutions lower costs and increase revenue
Published: Thursday, February 23, 2023 - 13:02
The business challenges of the past few years—labor shortages, supply chain disruptions, and inflation—have accelerated the long-term trend toward automated packaging operations.  All types of manufacturers and distributors, including food and beverage, pharmaceuticals, automotive, and e-commerce companies, are turning to packaging automation to ease pressures on their business and their employees. 
Evolving packaging technology
Automation solutions range from fundamental capabilities that have been used for decades, such as stretch wrapping, case erecting and sealing, coding and labeling, bagging, and shrink wrapping, as well as industrial robots and autonomous systems that efficiently perform pick and place, boxing, and palletizing.
The technology is evolving, with sensors and machine vision systems that can outperform human capabilities, touchscreen controls that are easier to learn and easier to use, and communications capabilities (including IoT) that facilitate remote system monitoring, preventive maintenance, and performance analysis. 
Packaging automation equipment must work together to meet specific customer goals, production, packaging needs, and shipping requirements.
But the rapid acceleration in adopting automation tends to be driven more by business needs and the current economic conditions than by advancements in technology. The return on investment can be the highest when manual processes are replaced by relatively mature automation solutions.
The challenges and opportunities vary by industry sector. Labor shortages have affected companies of all types and sizes, and labor-saving automation often becomes a business imperative. For some companies, the main driver of packaging automation is the need for higher throughput to compensate for the long lead times caused by supply chain disruptions, or to scale up production in response to spikes in market demand. 
Benefits of packaging automation
Overcoming labor challenges
Although the pure cost of labor has always been a key driver toward increased automation, labor reallocation within operations has become even more critical in today’s world. Three years into the pandemic, businesses are still struggling to find available, reliable labor with the baseline skills needed to operate their shipping and manufacturing facilities and keep operations running smoothly in the event of employee absences.
Productivity and flexibility
Automated packaging machinery is much faster than manual packaging. The speed accelerates throughput and provides much-needed flexibility; think quicker changeovers and responsiveness to volatile demand spikes. Packaging lines can be optimized with the right expertise to reduce bottlenecks and improve the flow of packaging and packaged products through manufacturing and distribution facilities.
Transportation costs
Fuel and related transportation costs are influencing the decision to automate packaging. The right packaging equipment can provide the flexibility needed to downsize materials to reduce dimensional weight. Lighter packages mean lower freight costs. Even as inflation results in higher material costs, businesses can achieve a reasonable or even aggressive rate of return on their automation equipment investments—sometimes as much as three times higher—if packaging setups result in more items being able to ship at one time, or when a product goes out the door at higher speeds.
Quality control
Packaging automation also plays a critical role in quality control. Vision systems are very effective in detecting defects and eliminating waste, considerations that are foundational to companies pursuing sustainability goals and ESG requirements. Automated systems also facilitate traceability and data-driven manufacturing processes.
Safety
Manual packaging is repetitive and can cause employee fatigue and repetitive stress injuries. A safer work environment also improves employee satisfaction and retention, which helps to mitigate labor shortages. In the food industry, automatic packaging also reduces the risk of food contamination.
ROI for packaging automation
When implementing a packaging automation solution, whether choosing stand-alone packaging equipment or installing a complete packaging automation line, the machinery should be ideally suited to the specific application as well as the company’s particular operational, financial, and marketing objectives.  
For example, a snack producer that sells natural beef jerky to supermarket chains couldn’t keep up with customer demand. Employees manually weighed and bagged the product, then labeled and code-dated each bag and inserted a desiccant packet, all by hand. The 10-person team could process a maximum of 4,000 lb per week. This created a dilemma when a large supermarket chain offered a contract for 8,000 lb per week.
After investigating a number of possible solutions, the company called in SupplyOne to provide a complete overhaul of its packaging operations. SupplyOne designed and supplied preprinted bags and installed an inkjet system to automatically print the freshness date, thereby eliminating several manual steps in the packaging operation, with the side benefit of providing more appealing packaging for the retail consumer. 
Automated packing equipment can fill, cap, seal, and label packages of all sizes, with minimal or no human intervention.
A 10-head combination scale was also installed. It can fill one bag every 3–4 seconds at an accuracy of ± 0.1 gr and automatically insert a desiccant pack. Previously, overfills were as much as a half-ounce per bag at $32 per lb. Two people can now weigh and package jerky three times faster than the 10 people who previously did the work.  Production was doubled using one-fifth of the labor, saving $320,000 in direct labor costs annually. The automation solution cost $135,000, paying for itself in five months.
Wide range of automation solutions
A wide range of automation solutions is available for each of the three types of packaging: primary, secondary, and end-of-line. Primary packaging, also known as retail packaging or consumer packaging, is directly in contact with the product itself. The primary packaging machinery is located at the beginning of the packaging line. Examples of automated and semi-automated primary machinery include case erectors, orienteers, fillers, bagging machines, shrink wrappers, tray sealers, vacuum sealers, and labelers.
Secondary packaging equipment packs multiple individual packages into a larger carton or item bundling. Case packers, stretch wrappers, protective packaging equipment, and shrink wrappers are typical examples of secondary equipment. As the term suggests, end-of-line equipment is used to prepare packages for transportation and storage, and includes conveyors and pallet wrappers, to name a few. 
The bottom line
The return on investment for packaging automation is increasingly favorable as companies respond to labor shortages, supply chain disruptions, and inflation. Automation enhances profitability in several ways: It can lower expenses by reducing labor, waste, and transportation costs, and it can increase revenues by expanding throughput and providing the flexibility to respond to spikes in demand and new market opportunities. Moreover, packaging automation makes companies more resilient to labor and supply chain challenges, to the benefit of customers and investors.
Chip Reavley’s picture
Chip Reavley
Chip Reavley is the vice president at SupplyOne. He has years of experience not only in the packaging industry but as a business manager.
