Featured Product
Lean Features
Del Williams
8-in. cable and disc systems are comparable to belt or bucket systems
Jeremy L. Boerger
To keep your business running, you need visibility into your IT assets
Kevin Ketels
The baby formula industry was primed for disaster long before a key factory closed down
Joe Vernon
The greatest advantage of CV is its ability to count and categorize inventory
James J. Kline
Quality professional organizations need to adjust their body of knowledge to include an understanding of big data
More Features
Lean News
Sept. 28–29, 2022, at the MassMutual Center in Springfield, MA
Enables system-level modeling with 2D and 3D visualization, reducing engineering effort, risk, and cost
It is a smart way to eliminate waste and maximize value
Simplified process focuses on the fundamentals every new ERP user needs
DigiLEAN software helps companies digitize their lean journey
Partnership embeds quality assurance at every stage of the product life cycle, enables agile product introduction
First trial module of learning tool focuses on ISO 9001 and is available now
Offset-aware programming of spindle transfers and bar pulls helps manufacturers drive multichannel CNC machinery
Freedom platform connects to any industrial asset to provide automated intelligence related to asset availability, utilization, and continuous improvement
More News
Jeremy L. Boerger
Lean
Five Easy Steps for Implementing the IT Asset Management Life Cycle
Published: Wednesday, June 29, 2022 - 12:03
You may not be familiar with the term “information technology asset management” (ITAM), but most businesses deal with it on a regular basis (for better or worse). ITAM is what helps control the costs of computers, servers, software, and services used to create the computing environment modern businesses need to function.
Ideally, the ITAM team (you do have one, right?) should be able to tell their business leadership the exact number of laptops in use by a remote sales force, or if more software licenses are needed to avoid a monstrous audit penalty at year’s end, or the costs of limping along on Windows 7 because that one CAD/CAM tool can’t handle the latest operating system.
But, as anyone who’s ever managed, purchased for, or even just called the IT department knows, ITAM (as an industry) does a pretty poor job of quickly answering these sorts of questions. One major factor in ITAM’s struggles is an inability to automate both the reporting and the processing of the asset life cycle; i.e., the phases any and all IT assets follow as they are consumed by the corporation. Organizations have to rely on manual feedback from work orders and visual inventories to know what kind of hardware and software is actually being used. Worse, the ITAM team then gets a reputation of being untrustworthy because they can never seem to answer the questions from business leaders accurately or in a timely way.
It’s a big problem that, at a minimum, leads to disruption. But it could literally shut down a plant if a critical software license lapses or a hardware upgrade is incompatible with older software.
Five easy steps for an IT asset-management life cycle
To avoid these problems, the ITAM team should be defining IT asset management life-cycle stages in such a way that it’s clear where an asset sits on the life cycle, and so the asset can “self-report” about where it is in that cycle.
Here are five easy steps.
Step one: Procured
AKA: Purchased, acquired, requested
Definition: Money, or the promise of money, has been paid for the possession of or right to use the asset, either hardware or software.
Step two: Inventoried
AKA: Delivered, received, processed, making ready
Definition: The asset has been physically received and is being readied for use in the computing environment. In the case of software, documentation from the publisher acknowledging your organization has more use rights to their software.
Step three: Installed
AKA: In use, deployed, implemented, active
Definition: The asset is active in the computing environment. Again, this works for both hardware and software assets.
Step four: Recovered
AKA: Returned, fit for use, recycled, clawed back, harvested
Definition: The asset has been removed from the computing environment temporarily with the intent that it will be used again.
For software, little evidence is needed to show the use right has moved back into inventory. Best business practice is to ensure the software is uninstalled from the original computer. Otherwise, you could be penalized for it in a software license audit.
For hardware, more manual effort will be required. A technician should really inspect the hardware for defects, ensure it still has some useful life in it, then clean, clear, wipe, and reinstall the base image before declaring it ready for redeployment.
Step five: Disposed
AKA: Retired, lost/stolen, sold, destroyed, trashed, removed from service
Definition: The asset has been removed from the computing environment permanently and is no longer the property or concern of the organization. For both hardware and software assets, some sort of evidence should be generated documenting the handoff between the old owner and the new one.
You’ll notice something very particular about these definitions: They are mutually exclusive. That means something that is in use can’t be in any other stage. For example, something that is disposed can’t be on the shelf in inventory. It’s gone. Something that’s in use can’t be sitting on the truck on its way to be delivered.
The IT asset management life cycle: Look for the data details
With these new definitions in mind, we can identify data attributes that will signal an asset has moved from one asset life cycle stage to another. But let’s change the order a little bit, to make it a little easier to describe.
Installed: If an asset is installed, you should see it active on your network. For hardware, end users should be detected logging into it, it has an IP address and network name, it is consuming power, and it appears on network scans. Software installations should be detected and reported by a “command and control” tool like Microsoft’s MEM, JAMF, or VMWare vCenter.
Disposed: You should have a certification, receipt, or something else that shows your organization no longer has the hardware or software asset in hand (and who now does). If you have such a document, but the asset is behaving as if it’s installed, you have a problem and had better look into it. And, for those of you asking, yes, software licenses can be returned to the publisher—usually under very specific conditions and with very specific paperwork.
Procured: It shouldn’t show up anywhere other than on a purchase order or tracking number. But if it acts like it’s installed, then it’s a good bet that someone skipped a step. And a skipped step could mean skipped protections and unauthorized installations. Both could signal a serious cybersecurity breach.
Inventoried and recovered: This is the trickiest part. We know they’ve been purchased because we have documentation saying so. We know they haven’t been thrown away because we don’t have a document staying so. We know they aren’t deployed because they’re not showing active in the network. Therefore, the only place these devices should be is in your warehouse or staging area. That should be an easy walk to look for and find it.
The asset management life cycle: The big reporting payoff
By reorganizing your hardware around this kind of an IT asset-management life cycle, you will know with a much higher degree of certainty what hardware is being used and what isn’t. Consequently, you’ll know what software needs to be licensed because it’s (almost always) running on the deployed hardware.
The real impact will be felt in the cost-savings initiatives this kind of trustworthy data can provide. For example, a common question asked of ITAM managers is, “How much is our ITAM program saving the company?” The answer is simple: How many assets (either hardware or software) were moved from the “Recovered” state to the “Inventoried” state. Even better, the reasoning is very simple: Every interrupted purchase is money saved.
Jeremy L. Boerger’s picture
Jeremy L. Boerger
Jeremy L. Boerger, ITAM coach, founded Boerger Consulting with the idea of helping organizations “cut their software budget without buying less software.” He also speaks professionally to pass along his more than 20 years’ experience to the next generation of ITAM and SAM professionals. His book, Rethinking Information Technology Asset Management, is in paperback and ebooks. He makes his home in Cincinnati with his wife and three children.
